Old 08-17-2012, 12:53 AM   #1
pinoyplaya
Drives: WRB MT-BRZ LMTD
Auto Lock (Doors)
Does anyone know if this feature is available on the BRZ/FRS?
I know that on my other car, after I've reached a certain speed after starting the vehicle, the car will automatically lock itself.
I havent seen that on my BRZ and I feel like someone could just easily open the door while im at a stop light.
Too lazy to lock the door manually and when you try to get out of the car, it doesnt unlock itself either.
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM
Traded for Black 2013 Camaro 2SS RS
pinoyplaya is offline   Reply With Quote
Old 08-17-2012, 07:37 AM   #2
Stu baru
Official Cobb beer knurd
Stu baru's Avatar
Drives: 2013 BRZ-L MT SWP
If it were, it would be on by default I'm guessing.
Don't text while driving, everyone around you will appreciate you not endangering their lives.
Stu baru is offline   Reply With Quote
Old 08-17-2012, 08:17 AM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
It was already discussed in another thread. It is not available.
Old 08-17-2012, 08:26 AM   #4
Foobar
SLO NO MO
Foobar's Avatar
It's not present on our cars, but even if it were, I wouldn't be too sure about it being on by default. Some things that are off by default: Gear indicator, shift indicator for maximum economy, rev indicator, anti-theft alarm.
Old 08-17-2012, 11:12 AM   #5
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Wait - the alarm is defaulted OFF?!!
OP - just hit the power lock button when you get in if it concerns you. That's what it's there for.
ashtray is offline   Reply With Quote
Old 08-17-2012, 11:55 AM   #6
Giccin
Giccin's Avatar
Thought you could just tinker with the eletrical system a bit and you'd be able to do it.
But you guys say there's no way, so... lets just go with that. lol
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Old 08-17-2012, 12:08 PM   #7
Yruyur
Yruyur's Avatar
Wonder if Visconti could put this in the ecu flash
Sent from my PH44100 using Tapatalk 2
Old 08-17-2012, 12:10 PM   #8
xwd
Yes the BRZ alarm is off by default. There is a sequence you have to go through to enable it or have the dealer do it.
Old 08-17-2012, 06:51 PM   #9
Subie
Seρor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
Door locking, etc. is controlled by a different computer AFAIK.
Subie is offline   Reply With Quote
Old 08-17-2012, 07:00 PM   #10
Aetyrno
Drives: 98 Camry
Try honking the horn. Our Camry doesn't auto-lock the doors unless you hit the horn with the engine running :P
Aetyrno is offline   Reply With Quote
Old 08-17-2012, 07:17 PM   #11
Thefuzz
Drives: 2009 VW GTI <SOLD> 2013 SWP BRZ 6MT
Do you know where the shift indicator should be set for max economy?
Thefuzz is offline   Reply With Quote
Old 08-17-2012, 08:17 PM   #12
Foobar
SLO NO MO
Foobar's Avatar
To my knowledge, you can't change the shift points for the indicator - I believe it's hard coded somewhere between 2 and 3K.
Old 08-17-2012, 08:17 PM   #13
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
If you use the gear indicator function it gives you a little up arrow as a shift indication for the best possible fuel economy. It's usually right around 2000rpm. Depending on your driving conditions, there is no reason you should do this. I improved my fuel economy by 0.1mpg doing this...and since then I've done better by NOT being so frugal with the big pedal. Shifting at ~3k (before the torque dip) will give you great fuel economy and all the confidence of not pissing off the prius behind you for going too slow.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 08-17-2012, 08:31 PM   #14
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Drives: 2013 BRZ Limited
There is no autolock feature. I'd guess we'd have to get an aftermarket option to make that happen. I wish it had that too.
ZC6BRZ is offline   Reply With Quote
86 with Lamborghini Doors quik1987 Cosmetic Modification (Interior/Exterior/Lighting) 102 04-10-2018 09:32 PM
lambo doors. What you think? FLIPs_FR-S Cosmetic Modification (Interior/Exterior/Lighting) 43 04-10-2018 09:13 PM
Nagisa Auto D-Lock Super Low Seat Rail poormans_LFA Cosmetic Modification (Interior/Exterior/Lighting) 3 11-06-2012 04:35 PM
Auto-lock locking me out of car! Bobasaur BRZ First-Gen (2012+) — General Topics 15 07-06-2012 04:37 PM
lock-to-lock Lexicon101 Scion FR-S / Toyota 86 GT86 General Forum 4 01-13-2010 10:04 PM
