Drives: Scion FR-S 2013 Raven
Sway bar option list
I think it's a good idea to start a list like this to help users to make their choices easily.
Stock OEM bar FR-S/BRZ/GT86 Solid Front : 18mm Rear : 14mm % = the % Stiffer than Stock ST suspensions Front : 19mm, 2 position 41% & 76% Rear : 17.5mm 3 position 20%, 58% and 133% Witheline Solid Front : 20mm, 22mm 20mm Fixed or 2 position in option, Soft Setting - 118.5% Hard Setting - 174% 22mm 2 position Soft Setting - 212% Hard Setting - 288% Rear : 16mm 3 position Soft Setting - 40.48% Medium Setting - 88.78% Hard Setting - 176.58% 18mm Soft Setting - 114.63% Medium Setting - 178.04% Hard Setting - 263.90% http://www.whiteline.com.au/do_segue...ehicle=2012-ON Cusco Front : 16mm, 20mm 1 position Hollow 16mm 79% Solid 20mm 174% Rear : 14mm, 16mm Hollow 1 position 14mm 73% 16mm 168% http://www.cuscousainc.com/vehicle-r...&modelname=475 TRD Stabilizer Set TRD Site Jparts Site Eibach Hollow Front : 25mm 2 position P1 = 88 N/mm (500 lbs/in) +255% P2 = 103 N/mm (585 lbs/in) +314% Rear : 19mm 2 position P1 = 45 N/mm (255 lbs/in) +126% P2 = 60 N/mm (338 lbs/in) +200% http://performance-suspension.eibach...-roll-kit_2013 Hotchkis Hollow Front : 25.4mm 2 position 500 lbs/in 170% 630 lbs/in 245% Rear : 19mm 4 position 320 lbs/in 200% 405 lbs/in 275% 520 lbs/in 385% 700 lbs/in 550% http://www.hotchkis.net/scion-frs-sp...sway-bars.html Perrin Front : 19mm, 22mm 2 position 19mm Hole #1 25% 19mm Hole #2 72% 22mm Hole #1 130% 22mm Hole #2 218% http://perrinperformance.com/i-13324...-fr-s-brz.html Rear : 16mm, 19mm, 22mm, 25mm 3 position 16mm Hole #1 30% 16mm Hole #2 65% 16mm Hole #3 116% 19mm Hole #1 150% 19mm Hole #2 243% 19mm Hole #3 347% 22mm Hole #1 400% 22mm Hole #2 535% 22mm Hole #3 729% http://perrinperformance.com/i-13324...-fr-s-brz.html Tanabe % Stiffer compared to Japan OEM. Front : 22mm 1 position 205% Rear : 18mm 1 position 235% http://www.tanabe-usa.com/rnd/?tag=/fr-s Strano FSB Front : 22mm 1 position 85% Stiffer than 18mm OEM bar http://www.stranoparts.com/partdetails.php?PartID=928 SuperPro Front : 20mm, 22mm Rear : 18mm, 20mm http://www.fastwrx.com/suswbafbr.html RaceComp Hollow Front : 25mm (22mm solid equivalent) 2 position P1 = 60 N/mm (335 lbs/in) P2 = 80 N/mm (455 lbs/in) Rear : 19mm (16mm solid equivalent) 2 position P1 = 33 N/mm (188 lbs/in) P2 = 45 N/mm (257 lbs/in) http://www.racecompengineering.com/i...sway-bars.html Progress Front : 20.5mm Rear : 17.5mm 2 position http://www.progressauto.com/products.../productID/759 ST Solid? Front : 19mm 1 position Rear : 17mm 1 position
o= FR-S =o Last edited by Mikepage; 04-23-2014 at 11:54 PM. |
Drives: GT86
Dear Mikepage,
Sounds a bit sexist. Yours faithfully, Unicorn |
Sorry, it's better now...am Canadian you know, my first language is french.
Then correct me when am wrong
o= FR-S =o Last edited by Mikepage; 10-25-2013 at 11:48 AM. |
#4 | |
Drives: 2013 BRZ SWP 6AT Ltd
I think this is a good idea as well. Being the OEM nutbag that I am: TRD Stabilizer Set - TRD Site http://trdparts.jp/conceptcar/86_per...uspension.html Jparts http://www.japanparts.com/db/parts_d...=23&submit.y=4
It was fun
Drives: Dirty FR-S
The rear sway bar from a 2008+ (correct me if i'm wrong) WRX will fit. I swiped one off of NASIOC for 35 shipped
#6 | |
Drives: 2013 FRS, 2008 R32
Sway bars are one of those things I see people often install on their cars for no real rhyme or reason but do it just to do it and sometimes hurt their car's handling in many cases. |
It was fun
Drives: Dirty FR-S
That's why^. I was bored.
People change parts to change parts without ask any questions why.
The goal is to make changes to improve something you want.
o= FR-S =o |
#9 | |
Drives: GT86
Dearn Ocean-Grown 86, You may find the below links somewhat relevant: http://www.ft86club.com/forums/showthread.php?t=28221 http://www.ft86club.com/forums/showthread.php?t=37006 Yours sincerely, Unicorn |
#10 |
That Guy
Drives: 2013 asphalt FRS MT
@CSG Mike & @Racecomp Engineering do sway bar manufacturers always use the same material? In not, how much of a difference can that make to the stiffness of the bar?
@Mikepage could you add the stock bars to the list? |
#11 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
Don't forget the Strano FSB
#13 |
Senior Citizen
Drives: Scion FR-S
Tanabe
22mm Hollow 1 position |
#14 |
o= FR-S =o |
| New F/I option | SnapOv3st3r | Forced Induction | 41 | 03-24-2013 09:44 PM |
| Leather Option. | l0aded | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 03-02-2013 08:59 PM |
| Diffuser Option on the BRZ | Markone | AUSTRALIA | 25 | 01-14-2013 03:21 AM |
| Scion FR-S Option list | Crashoverride | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 04-18-2012 03:37 PM |
| Considering this as another option 2011 WRX | Draco233 | Other Vehicles & General Automotive Discussions | 5 | 04-01-2012 10:01 PM |
