Old 10-22-2013, 01:05 PM   #1
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Sway bar option list
I think it's a good idea to start a list like this to help users to make their choices easily.
Stock OEM bar FR-S/BRZ/GT86
Solid
Front : 18mm
Rear : 14mm
% = the % Stiffer than Stock
ST suspensions
Front : 19mm,
2 position 41% & 76%
Rear : 17.5mm
3 position 20%, 58% and 133%
Witheline
Solid
Front : 20mm, 22mm
20mm Fixed or 2 position in option,
Soft Setting - 118.5%
Hard Setting - 174%
22mm 2 position
Soft Setting - 212%
Hard Setting - 288%
Rear : 16mm
3 position
Soft Setting - 40.48%
Medium Setting - 88.78%
Hard Setting - 176.58%
18mm
Soft Setting - 114.63%
Medium Setting - 178.04%
Hard Setting - 263.90%
http://www.whiteline.com.au/do_segue...ehicle=2012-ON
Cusco
Front : 16mm, 20mm
1 position
Hollow
16mm 79%
Solid
20mm 174%
Rear : 14mm, 16mm
Hollow
1 position
14mm 73%
16mm 168%
http://www.cuscousainc.com/vehicle-r...&modelname=475
TRD Stabilizer Set
TRD Site
Jparts Site
Eibach
Hollow
Front : 25mm
2 position
P1 = 88 N/mm (500 lbs/in) +255%
P2 = 103 N/mm (585 lbs/in) +314%
Rear : 19mm
2 position
P1 = 45 N/mm (255 lbs/in) +126%
P2 = 60 N/mm (338 lbs/in) +200%
http://performance-suspension.eibach...-roll-kit_2013
Hotchkis
Hollow
Front : 25.4mm
2 position
500 lbs/in 170%
630 lbs/in 245%
Rear : 19mm
4 position
320 lbs/in 200%
405 lbs/in 275%
520 lbs/in 385%
700 lbs/in 550%
http://www.hotchkis.net/scion-frs-sp...sway-bars.html
Perrin
Front : 19mm, 22mm
2 position
19mm Hole #1 25%
19mm Hole #2 72%
22mm Hole #1 130%
22mm Hole #2 218%
http://perrinperformance.com/i-13324...-fr-s-brz.html
Rear : 16mm, 19mm, 22mm, 25mm
3 position
16mm Hole #1 30%
16mm Hole #2 65%
16mm Hole #3 116%
19mm Hole #1 150%
19mm Hole #2 243%
19mm Hole #3 347%
22mm Hole #1 400%
22mm Hole #2 535%
22mm Hole #3 729%
Tanabe
% Stiffer compared to Japan OEM.
Front : 22mm
1 position 205%
Rear : 18mm
1 position 235%
http://www.tanabe-usa.com/rnd/?tag=/fr-s
Strano FSB
Front : 22mm
1 position
85% Stiffer than 18mm OEM bar
http://www.stranoparts.com/partdetails.php?PartID=928
SuperPro
Front : 20mm, 22mm
Rear : 18mm, 20mm
http://www.fastwrx.com/suswbafbr.html
RaceComp
Hollow
Front : 25mm (22mm solid equivalent)
2 position
P1 = 60 N/mm (335 lbs/in)
P2 = 80 N/mm (455 lbs/in)
Rear : 19mm (16mm solid equivalent)
2 position
P1 = 33 N/mm (188 lbs/in)
P2 = 45 N/mm (257 lbs/in)
http://www.racecompengineering.com/i...sway-bars.html
Progress
Front : 20.5mm
Rear : 17.5mm
2 position
http://www.progressauto.com/products.../productID/759
ST
Solid?
Front : 19mm
1 position
Rear : 17mm
1 position
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 10-22-2013, 01:10 PM   #2
Unicorn
Drives: GT86
Dear Mikepage,
Sounds a bit sexist.
Yours faithfully,
Unicorn
Unicorn is offline   Reply With Quote
Old 10-22-2013, 01:15 PM   #3
Mikepage
Mikepage's Avatar
Sorry, it's better now...am Canadian you know, my first language is french.
Then correct me when am wrong
o= FR-S =o
Old 10-22-2013, 01:24 PM   #4
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Originally Posted by Mikepage View Post
I think it's a good idea to start a list like this to help users to make her choices.
He's just messing around with you. You put her in place of their in your OP.
I think this is a good idea as well.
Being the OEM nutbag that I am:
TRD Stabilizer Set -
TRD Site http://trdparts.jp/conceptcar/86_per...uspension.html
Jparts
http://www.japanparts.com/db/parts_d...=23&submit.y=4
Beyer Subaru is offline   Reply With Quote
Old 10-22-2013, 02:29 PM   #5
Ocean-Grown 86
It was fun
Ocean-Grown 86's Avatar
Drives: Dirty FR-S
The rear sway bar from a 2008+ (correct me if i'm wrong) WRX will fit. I swiped one off of NASIOC for 35 shipped
Ocean-Grown 86 is offline   Reply With Quote
Old 10-22-2013, 02:32 PM   #6
mfbmike
Drives: 2013 FRS, 2008 R32
Sure, it fits. But does it improve handling at all? How so, why?
Sway bars are one of those things I see people often install on their cars for no real rhyme or reason but do it just to do it and sometimes hurt their car's handling in many cases.
mfbmike is offline   Reply With Quote
Old 10-22-2013, 03:36 PM   #7
Ocean-Grown 86
It was fun
Drives: Dirty FR-S
That's why^. I was bored.
Old 10-23-2013, 11:19 AM   #8
Mikepage
Mikepage's Avatar
People change parts to change parts without ask any questions why.
The goal is to make changes to improve something you want.
o= FR-S =o
Old 10-23-2013, 11:36 AM   #9
Unicorn
Drives: GT86
Dearn Ocean-Grown 86,
You may find the below links somewhat relevant:
http://www.ft86club.com/forums/showthread.php?t=28221
http://www.ft86club.com/forums/showthread.php?t=37006
Yours sincerely,
Unicorn
Old 10-23-2013, 12:55 PM   #10
Calum
That Guy
Drives: 2013 asphalt FRS MT
@CSG Mike & @Racecomp Engineering do sway bar manufacturers always use the same material? In not, how much of a difference can that make to the stiffness of the bar?
@Mikepage could you add the stock bars to the list?
Old 10-23-2013, 03:32 PM   #11
Kostamojen
Don't forget the Strano FSB
Old 10-25-2013, 11:47 AM   #12
Mikepage
Mikepage's Avatar
I will update tonight for sure.
Sent from my iPhone using Tapatalk - now Free
o= FR-S =o
Old 10-25-2013, 11:52 AM   #13
simpleisbest
Senior Citizen
Drives: Scion FR-S
Tanabe
22mm
Hollow
1 position
simpleisbest is offline   Reply With Quote
Old 10-29-2013, 01:26 PM   #14
Mikepage
Mikepage's Avatar
Do you have a link for this?
o= FR-S =o
New F/I option SnapOv3st3r Forced Induction 41 03-24-2013 09:44 PM
Leather Option. l0aded Scion FR-S / Toyota 86 GT86 General Forum 20 03-02-2013 08:59 PM
Diffuser Option on the BRZ Markone AUSTRALIA 25 01-14-2013 03:21 AM
Scion FR-S Option list Crashoverride Scion FR-S / Toyota 86 GT86 General Forum 38 04-18-2012 03:37 PM
Considering this as another option 2011 WRX Draco233 Other Vehicles & General Automotive Discussions 5 04-01-2012 10:01 PM
