Old 10-20-2013, 08:55 PM   #1
grostoine
Drives: Subaru BRZ
Aftermarket Engine Mount
I wanted to know if there is anyone who install some engine mount on their car yet?
Perrin?
megan racing?
cusco?
Wich is best?
grostoine is offline   Reply With Quote
Old 10-21-2013, 07:06 AM   #2
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Perrin?
megan racing?
cusco?
Wich is best?
I installed sti group N mounts. Pretty happy with them. Cusco will be the stiffest since they are solid. Sti are the same as stock except the rubber is harder. No real noticeable increase in nvh but stiffens everything up nicely. I really don't like the design of the Perrin mounts, seems like just an afterthought like their swaybars.
industrial is offline   Reply With Quote
Old 10-21-2013, 07:38 AM   #3
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
I have the Perrin mounts and unlike the above post, I think they were the most thought out. Far easier to pull the motor once the Perrin mounts are installed. I'm very happy with them.
chadstyle is offline   Reply With Quote
Old 10-21-2013, 08:48 AM   #4
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Far easier to pull the motor out? Two bolts or two nuts will hardly make a difference when pulling the whole motor. I say the Perrin seems like an afterthought because the mount seems like its the ej mounts they sell with an adaptor plate. Was not designed for our car but adapted to work with it. Probably works just fine though.
Old 10-21-2013, 09:31 AM   #5
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Looking into a pair myself. How were your install experiences guys? I've heard they can be a huge PITA.
Did you leave the header on or take it off when installing them?
Old 10-21-2013, 10:11 AM   #6
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Have you seen the stock mounts? They are basically the exact same way. EJ mounts with an extra square raised section added to the backing plate.
Running the Perrin mounts on my car at the moment. With the over pipe unbolted from the header and front pipe, and raising the motor about 2 inches, the install was super easy. There was a ton of room.
FrX is offline   Reply With Quote
Old 10-21-2013, 10:13 AM   #7
mrk1
Drives: Sterling BRZ Ltd
I have the STI mounts designed for the BRZ and love them, they are similar in hardness to the Group N mounts sold for other subis
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 10-21-2013, 11:21 AM   #8
vgi
Drives: frs
there is DIY on here which says to remove tranny mounts. did you unbolt anything else overpipe (tranny mount, headers)?
vgi is offline   Reply With Quote
Old 10-21-2013, 11:32 AM   #9
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I have Perrin mounts and like them.
Old 10-21-2013, 11:49 AM   #10
FrX
The two largest nuts (that go into the slotted holes on the aluminum cross brace) on the tranny mount were undone to prevent damage to it from flexing.
Old 10-21-2013, 03:28 PM   #11
ducks
Drives: car
i also have the perrin mounts and like them.
ducks is offline   Reply With Quote
Old 10-21-2013, 05:40 PM   #12
Calum
That Guy
Drives: 2013 asphalt FRS MT
How's the NVH with them?
Old 10-21-2013, 05:44 PM   #13
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Wasn't too bad man. Don't be afraid to jack the engine way up there... I did the header and mounts at the same time and it seemed like it was easier with the overpipe loosened up and header out. Took about 2 hours total with a lift for both parts and I was moving pretty deliberately.
Old 10-21-2013, 08:34 PM   #14
Sportsguy83
Drives: Limited BRZ
IMHO, it is only noticeable in 6th gear, 30 mph and putting load on the engine. Aside from that, I don't notice much.
Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic ecko04 Electronics | Audio | NAV | Infotainment 10 05-05-2018 03:47 PM
What will happen to the aftermarket for this car after the engine bump? enjoi23 Scion FR-S / Toyota 86 GT86 General Forum 19 10-13-2013 02:08 AM
*Raceseng Tow Hook w/ Go Pro Mount Built In Front/Rear Mount -fteightysix* 86SPEED Exterior Parts - The Rest 2 08-20-2013 01:37 AM
DIY: Making a GoPro camera mount with a GrimmSpeed front plate mount PMok DIY (Do-It-Yourself) Guides 2 06-11-2013 10:58 AM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
