Old 10-16-2013, 12:21 AM   #1
NOHOME
Drives: RAVEN
Seems to stumble at idle?
Is a stumble during idle normal for this engine?
NOHOME is offline   Reply With Quote
Old 10-16-2013, 12:24 AM   #2
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Need more information. But it is most likely the a/c compressor is turning on and off.
Muaddib is offline   Reply With Quote
Old 10-16-2013, 01:05 AM   #3
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
It's been happening to me when the engine is cold these mornings.
At stop signs it almost feels like it's going to stall when idling.
Only until maybe 3-4 minutes into it, it warms up and my idle doesn't seem so uneasy.
drewbot is offline   Reply With Quote
Old 10-16-2013, 01:16 AM   #4
humfrz
I'd say not normal, if the engine is warm.
When it's cold, you may consider letting the engine do its little warm up routine (about 15-20 seconds) before you head out....
humfrz
Old 10-16-2013, 02:00 AM   #5
Akabadaz
Drives: FRS
Hmm...when I am stopped at idle such as waiting for someone there is definitely some stumbling/purring occasionally...I also have always had this in my tacoma.
Also, I have driven hundreds of rentals for my job and they do similiar so I'm under the impression that it is normal unless it starts sounding like it is about to turn off...
It would seem to be common normalty but if I'm wrong I would need to get my cars checked out or like the other person said perhaps it has to do with the AC?
Akabadaz is offline   Reply With Quote
Old 10-16-2013, 02:05 AM   #6
Tromatic
The AC compressor also runs if you have it on "defrost".
Tromatic is offline   Reply With Quote
Old 10-16-2013, 09:47 AM   #7
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
Mine does this as well, seems to dance between 500-1000 rpm when at idle with the AC on. Pretty sure it has something to do with the compressor as I hear it click when the RPM fluctuates. I recall my brothers tacoma doing the same thing.
lickitysplit is offline   Reply With Quote
Old 10-16-2013, 01:38 PM   #8
strat61caster
strat61caster's Avatar
I get a 'stumble' as well when coming to a stop as the rpm drops after I depress the clutch (mostly when cold, seems more stable when warm). Barring the A/C compressor (which results in idle hunting for me) I think it's a consequence of setting the idle as low as possible to squeeze a couple 1/10ths of an mpg out of the car during the city cycle. People with tunes have raised the idle and it seems to get rid of the stumbles and hunting. But I'm just going off of hearsay.
Unless it stalls or you get a check engine light nobody is going to fix the problem for you, it'll be called 'normal operation'. Bleh makes me nervous.
ineedyourdiddly
Old 10-16-2013, 02:02 PM   #9
MAPerformance
Drives: Asphalt FRS
You may be experiencing the "idle dip" that these cars have stock. Mine idled pretty low and rough too when I got it. A good tune with a raised idle helped ten fold. Its soooo smooth now.
MAPerformance is offline   Reply With Quote
Old 10-16-2013, 02:40 PM   #10
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Mine does this as well. A few stumbles here and there during a complete cold start but I think it's normal.
hmong337 is offline   Reply With Quote
Old 10-16-2013, 08:59 PM   #11
hushypushy
ビーアールゼット
hushypushy's Avatar
Drives: WRB BRZ '18
What did you raise your idle to?
hushypushy is offline   Reply With Quote
Old 10-16-2013, 10:04 PM   #12
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
I am having similar issues
TruRace is offline   Reply With Quote
Old 10-17-2013, 12:23 AM   #13
jflogerzi
jflogerzi's Avatar
My tuner did this as well. I think its around 800rpm
Old 10-17-2013, 11:12 AM   #14
MAPerformance
Drives: Asphalt FRS
I think its around 850 right now.
AC weak at idle qoncept Issues | Warranty | Recalls / TSB 15 03-23-2014 05:49 PM
Idle Misfire/Stumble Nightbringer Issues | Warranty | Recalls / TSB 20 09-19-2013 12:27 AM
Possible Idle Issue???? Help please soontobrz Issues | Warranty | Recalls / TSB 2 07-08-2013 08:34 PM
FR-S cold start stumble - video whtchocla7e Issues | Warranty | Recalls / TSB 11 04-17-2013 08:02 AM
Idle dip ONLY with COMPRESSOR on #87 Issues | Warranty | Recalls / TSB 2 11-14-2012 12:12 PM
