Old 09-18-2013, 01:26 PM   #1
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
Idle Misfire/Stumble
Apologies for creating a new thread, but I'm not certain what the actual issue falls under. On cold startup the car idle surges between 400-1800 RPM, with audible misfires especially in the lower rev ranges. In the video I'm holding 30% throttle to keep it running. If left to it's own devices, it will either completely die or keep tach-bouncing and popping becomes horrific.
It sounds very similar to the DI seal issue, however once it's warmed up the car drives as normal and I believe DI seals would be a constant.
My only theory at this point is a cam gear issue---when the oil is cold it doesn't actuate properly, and then resolves itself once the oil warms up.
This initially presented ONLY on the Visconti pumpgas map several months back, but is now happening on ALL maps including stock. Only modification is catless 2.75" J2 frontpipe, catback and K&N drop-in. I realize the danger in letting it run this way, but as it hasn't popped any CEL's yet after a clear (even when it dies), Toyota will not commence diagnostics. Only made the video for the sake of getting it documented.
Open to any suggestions or ideas you guys may have.
https://plus.google.com/u/0/10312936...45/posts/p/pub
Let me know if the video doesn't work.
Nightbringer is offline   Reply With Quote
Old 09-18-2013, 01:56 PM   #2
Carwhisperer
Drives: A lot of supercars.
Exact same scenario. At least our cars didn't catch fire.
Carwhisperer is offline   Reply With Quote
Old 09-18-2013, 02:06 PM   #3
Nightbringer
Drives: Scion FR-S
I remember reading about this but don't remember the end result. Were you able to solve it? A friend's car had a cam gear fail and it acted just like this. Once it's up to temp it drives fine, but even on pumpgas, I can barely get the car to stay running now. :\ Don't know why it'd present on John's tune two months ago, and only show up NOW on my other tunes. Something must've exacerbated the underlying issue. I'm just at a loss here.
I've got some logs of the startup if anyone's clever enough to assist. I'm a newbie at best. Only thing I can identify is that it's running really lean now once it starts trimming. Previously I'd get 20-25% positive LTFT on John's tune, but now i'm seeing 32-40%. :\
I'd say it just needs to be retuned with more fuel thrown into the cold start maps, but I've seen other folks get away with header+full catless exhaust and start just fine on the stock map, so I can only assume I've now got a mechanical problem to contend with.
Old 09-18-2013, 02:31 PM   #4
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Video does not work. The page is blank for me. You sure you are not hearing the cat warm up ect?
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 09-18-2013, 02:35 PM   #5
mid_life_crisis
Drives: FR-S 10 #103 AT
Interesting that today was my first cool morning with the new FR-S and the car stumbled at first then idled very high for a bit.
Was fine when I came out at lunch though.
No mods yet except to get rid of that stupid cabin noise assembly.
Old 09-18-2013, 02:37 PM   #6
Nightbringer
Drives: Scion FR-S
Yeah this is not the usual catalyst warmup pinging. This is a loud bang/misfire through the exhaust every other second. Sounds like the "fireworks" description for DI seal failure. I've always had a light idle stumble on cold mornings (I drove it in winter, so I'm used to it high-idling), especially on E85, but it always pops to high rev and smooths out. This just continuously fluctuates, and bangs constantly. The car WILL stall, every time, without immediate throttle input after firing.
I'll try to find an alternative host for the video and the data logs.
Old 09-18-2013, 03:43 PM   #7
feldy
feldy's Avatar
Hmm... I dont think its the di seals. You have a automatic. we have yet to see a case with the auto and di problems.
Old 09-18-2013, 03:55 PM   #8
Nightbringer
Drives: Scion FR-S
It appears that it may be a fueling issue. I sent John a log and he responded within an hour with ideas and explanations. Looks like I may have joined the disintegrated filter club and it's restricting fuel flow.
Old 09-18-2013, 04:00 PM   #9
feldy
feldy's Avatar
Oh man.
How long have you been on e85?
I have been on and off all summer on the corn. about two weeks ago I threw a high circuit code and I went back to pump gas and have not looked back.
I would drain it out and go back to a stock tune for a bit and see if that helps.
Old 09-18-2013, 04:07 PM   #10
Nightbringer
Drives: Scion FR-S
I don't believe it's E85. Plenty of people with tens of thousands of miles on their E85 setups. It's just a postulated fuel problem at this point, I haven't investigated the filter housing or lines to see if there's debris. Just the only thing I could think of as I haven't heard of pump failures (crickets don't count).
Old 09-18-2013, 04:11 PM   #11
feldy
feldy's Avatar
Let me know if you find an issue.
Old 09-18-2013, 04:29 PM   #12
Mikem53
Drives: FR-S 6MT
That would also explain the lean conditions you are also experiencing..
Mikem53 is offline   Reply With Quote
Old 09-18-2013, 04:30 PM   #13
Nightbringer
Drives: Scion FR-S
Yep. Fuel trims steadily climb. It makes sense, I'm just praying that debris hasn't made it's way into all the fuel lines, all eight injectors, etc. That would be a bad day.
Old 09-18-2013, 04:37 PM   #14
lychee
Iris- Blue breezy
Drives: Galaxy Blue Silica BRZ Limited 6MT
Is your a/c on during cold start up? If so, turn it off.
lychee is offline   Reply With Quote
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
FR-S cold start stumble - video whtchocla7e Issues | Warranty | Recalls / TSB 11 04-17-2013 07:02 AM
Misfire Jono AFRICA 49 12-12-2012 06:01 AM
ECU replaced. Still has slight misfire, rough idle xomp Issues | Warranty | Recalls / TSB 1 11-01-2012 08:53 AM
Idle Fluctuation FIX empower-auto Issues | Warranty | Recalls / TSB 2 09-14-2012 02:36 PM
