Old 10-14-2013, 05:33 PM   #1
thebucketmouse
Drives: brz
OEM audio +... did i do something wrong?
So I just finished installing the OEM Audio + system in my BRZ. While it certainly sounds better, and the sub is a good addition, I am not very impressed with the new tweeters. Highs like cymbal hits are still a "tshhhh" sound rather than "tssss". For those that have the system, did you notice a big increase in highs clarity?
thebucketmouse is offline   Reply With Quote
Old 10-14-2013, 05:36 PM   #2
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
I noticed the highs sounded bright at first. It'll smooth out after some time.
JDKane527 is offline   Reply With Quote
Old 10-14-2013, 07:35 PM   #3
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
We have the Reference 400 with the deleted mid, the sound with the new tweeters is clear, very clear.
I should preface it by saying the car is very well insulated with Raammat & Ensolite, not sure how that affects the highs coming from the windshield. The doors hit harder than ever.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 10-15-2013, 05:21 PM   #4
thebucketmouse
Drives: brz
hmm... I wonder if mine is less clear because I did not fold the foam material out on the tweeters. the video told you to do that, but I did the install with only the written instructions included with my box and it didn't say anything about folding the tweeter foam
Old 10-15-2013, 05:24 PM   #5
tonystewart
Should be an easy fix
Dealer set the wrong Car Type in FR-S base audio pkny Electronics | Audio | NAV | Infotainment 112 05-08-2017 10:04 AM
HELP! WRONG GAS IN CAR nabil_frs CANADA 9 05-06-2013 03:49 PM
FR-S Audio Build - SQ (Illusion Audio/Mosconi) DekaMori Electronics | Audio | NAV | Infotainment 28 04-17-2013 04:34 AM
What's wrong with my HID kit? seven Cosmetic Modification (Interior/Exterior/Lighting) 17 11-28-2012 07:36 PM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 09:45 PM
