CANADA Canada
Old 05-05-2013, 11:04 PM   #1
nabil_frs
nabil_frs's Avatar
Drives: Argento FR-S
HELP! WRONG GAS IN CAR
Hey guys so my dad accidentally put 87 instead of the premium 91 he only put 20$ so about 16L but i noticed a pinging noise more then usual and i asked him and he realized he put the wrong gas in the tanks half empty now but WHAT DO I DO!!!! HELPPPPPPPP
nabil_frs is offline   Reply With Quote
Old 05-05-2013, 11:11 PM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
put some octane booster in it and don't WOT, keep mixing in proper gas until replenished
Old 05-06-2013, 01:00 AM   #3
DjDATZ
EightSixClub Co-Founder
DjDATZ's Avatar
Drives: Selina (FR-S), Rondo EX V6 & fortwo
Get the tank as empty as possible, and then throw in premium. One tank of 87 won't hurt.
Meet Selina, my Asphalt FR-S MT6.
Like EightSixClub on FB, and follow us on Twitter!
DjDATZ is offline   Reply With Quote
Old 05-06-2013, 06:59 AM   #4
Enemies
Drives: '13 SWP Sport-Tech (Limited)
What the first guy said. Octane boost.
I wouldn't try to run the tank on empty with 87 in it.
Have 94 gas available? I'd fill up with that the next go around and run it as close to empty as you can and then go back to 91 as per usual.
Enemies is offline   Reply With Quote
Old 05-06-2013, 07:52 AM   #5
Chinadian
Chinadian's Avatar
Drives: FRS Whiteout
What happens to your engine when you use lower octane? just curious.
Chinadian is offline   Reply With Quote
Old 05-06-2013, 09:44 AM   #6
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
It prevents your engine from running as much timing advance as it can. Take it easy on this tank and it won't hurt anything. After you fill up with 91, pull your negative cable for 5 minutes to reset the ECU. Your car will have pulled timing to reduce detonation and you can eliminate this by resetting it.
Thorpedo is offline   Reply With Quote
Old 05-06-2013, 10:14 AM   #7
B L U E S L A T E
Drives: BMW E84
Go get some 100 octane gas.
B L U E S L A T E is offline   Reply With Quote
Old 05-06-2013, 10:47 AM   #8
For what its worth from a random guy on the Internet, I wouldn't worry about it.
I'm about 99% sure mine was delivered with 87 in it in the first tank, as I watched the dealer do it and was so excited about getting the car it completely passed by me until the first time I put gas in it at the same pump and realized what had happened.
You could go ahead and fill it up which will even it out some, or put octane booster in it, but the car will run on the 87 fine.
Old 05-06-2013, 10:54 AM   #9
wparsons
wparsons's Avatar
If you're hearing pinging at part throttle there's something else wrong besides a tank of 87 octane.
Drive the care nicely, keep the revs down and your foot away from WOT and you will be 100% fine.
That said, the ECU is smart enough to pull timing when it detects pinging, so even if you were to beat on it you would be ok, just at a reduced power output.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Dadhawk (05-06-2013)
Old 05-06-2013, 03:49 PM   #10
djdnz
1337
Drives: 2013 BRZ WRB S/C
You'll be fine don't worry. As others have said, fill the rest up with either 91 or 94 and take it easy this tank.
djdnz is offline   Reply With Quote
HELP! WRONG GAS IN CAR nabil_frs Issues | Warranty | Recalls / TSB 85 04-01-2014 01:44 AM
Drifting gone wrong!! F3dzo Scion FR-S / Toyota 86 GT86 General Forum 25 03-04-2013 02:16 PM
What's wrong with my HID kit? seven Cosmetic Modification (Interior/Exterior/Lighting) 17 11-28-2012 07:36 PM
am I doing something wrong? shiud Scion FR-S / Toyota 86 GT86 General Forum 20 07-17-2012 05:21 PM
Was I in the wrong? D4ng3r Off-Topic Lounge [WARNING: NO POLITICS] 18 06-15-2012 01:46 AM
