Old 10-12-2013, 01:10 PM   #1
TazMotorsports
Drives: 2013 FRS
bug removal
Here in S. Florida we get love bugs on our cars constantly! What is the best way to remove them if you didnt get them off right away?
TazMotorsports is offline   Reply With Quote
Old 10-12-2013, 01:38 PM   #2
dehydratedH2O
Drives: 2014 BRZ Limited DGM
Use a special bug remover/degreaser to get them off, then replace the wax that was stripped by the degreaser with a sealant and thick coat of wax to get them off easier next time.
dehydratedH2O is offline   Reply With Quote
Old 10-12-2013, 04:09 PM   #3
Whiteout_FRS
Whiteout_FRS's Avatar
Drives: 2013 Scion FRS
Dip a dryer sheet in your soap bucket, then use on front of car. Works like a charm
Whiteout_FRS is offline   Reply With Quote
The Following User Says Thank You to Whiteout_FRS For This Useful Post:
batmobilefrs (10-12-2013)
Old 10-12-2013, 04:34 PM   #4
batmobilefrs
batmobilefrs's Avatar
Drives: Raven FRS
Have similar problems here in SC never thought about that. Gonna have to give it a whirl.
batmobilefrs is offline   Reply With Quote
Old 10-13-2013, 12:59 AM   #5
midnightfrolic
Drives: Scion FRS A/T raven
thoroughly wash your car. I just use a good touchless wash. Then proceed with this:
I've had many issues with bird poo and bug splats. This takes care of them EVERY time.
If you forego the wash, just let it soak a bit longer. Clean off and then wash later. Also removes tough residue left behind after repeated washes.
midnightfrolic is offline   Reply With Quote
The Following User Says Thank You to midnightfrolic For This Useful Post:
FRyeS (10-13-2013)
Old 10-13-2013, 01:33 AM   #6
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
This works great. Also FYI I discovered this from a friend. Had a large drop of tree sap. If you spray the bug/tar remover let it soak for about 10 min. then boil some water dip ur car sponge/MIT in the hot water and it will come off in 1 swipe. And I had a drip that was about 1/2 an ich wide and 7-8 inches long right down the side of my door. Damn Oregon trees! I'm sure this trick would help if u have anything that's extra hard to get off.
FRSfan111 is offline   Reply With Quote
The Following User Says Thank You to FRSfan111 For This Useful Post:
midnightfrolic (10-14-2013)
Old 10-13-2013, 01:43 AM   #7
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
I have to say I just used this for the first time today on bug stains from over a month ago (I've been lazy). I didn't think it'd work but it worked really well. The only thing that sucks is my arms are about to fall off from all the hard scrubbing. I was afraid to let it sit too long, does this kind of stuff damage paint if left on too long? I got a bug scrubber (sides) like below but am looking for something that requires less pressure.
http://www.walmart.com/ip/Microfiber-Sponge/16817500
oldpueblo is offline   Reply With Quote
The Following User Says Thank You to oldpueblo For This Useful Post:
Old 10-13-2013, 10:16 AM   #8
R.S-HawK
Drives: '13 Gen Coupe 3.8 R
+1
Also, this works like a charm when you use them together.
http://shop.advanceautoparts.com/web...ontent=general
R.S-HawK is offline   Reply With Quote
The Following User Says Thank You to R.S-HawK For This Useful Post:
Old 10-13-2013, 10:21 AM   #9
trigger happy
Bang Bang
trigger happy's Avatar
Drives: 2013 Raven FR-S
thanks for the tip. never tried it gonna have to give it a shot
Raven 6MT//Injen CAI//VDS UEL//Invidia N1//OFT//ST Coilovers
trigger happy is offline   Reply With Quote
Old 10-13-2013, 10:49 AM   #10
dnieves
Drives: FR-S 10 Series
Clear bra and tons of wax over it?
dnieves is offline   Reply With Quote
Old 10-13-2013, 11:06 AM   #11
FRyeS
Drives: 2013 FR-S Asphalt 6MT
+1 for the turtle wax stuff - I use it along with a "bug sponge" (GIS it) and it does a great job.
FRyeS is offline   Reply With Quote
Old 10-13-2013, 11:40 AM   #12
AznBRZer
Drives: 16 CBS WRX Limited
In my experience, Tarminator works better then Turtle's or RainX's products. Practically spray on and wipe off with relatively no dwell time.
AznBRZer is offline   Reply With Quote
Old 10-13-2013, 02:32 PM   #13
frs10
Drives: tezla
dont buy those things...
2 dryer sheets
1 empty spray bottle
1 latex cleaning glove
water
fill the spray bottle with a bit of water and roll a dryer sheet and put in the spray bottle, let soak for 5 mins.
shake the solution and spray on liberally on the bug covered areas. let soak for a few seconds and use the 2nd dry sheet as a towel and rub them off... if there is still residue, spray again and work at it... it doesnt take much pressure to get them off... when ur done you might wanna rinse off the area with some clean water and dry... will look brand new.
total cost < $5.00
i did it today and it all came off with ease... took about 10 mins total
frs10 is offline   Reply With Quote
Old 10-14-2013, 05:43 PM   #14
aghuman
aghuman's Avatar
Drives: 2013 Asphalt FR-S
I try to get the bulk of it off initially while finishing up my regular wash, carefully not applying too much pressure, then i finish up with my regular soap and clay. It works great for me and doesn't leave any marring on the paint plus I really like that it it not very aggressive and its safe for the finish.
aghuman is offline   Reply With Quote
DIY ECU removal Hawaiian DIY (Do-It-Yourself) Guides 21 02-05-2023 01:19 AM
Pillar Removal? kmbkk Electronics | Audio | NAV | Infotainment 2 07-12-2015 11:55 AM
Oil Filter removal Perihelion Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 71 11-12-2013 05:52 PM
BRZ spoiler removal? Superhatch Cosmetic Modification (Interior/Exterior/Lighting) 1 04-29-2013 01:12 PM
Clear bra removal. Any one try it? digital_assassin Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 07-13-2012 02:30 PM
