Old 05-01-2013, 03:05 PM   #1
Perihelion
Unemployed DIY Ninja
Perihelion's Avatar
Drives: 2013 SWP BRZ, 1983 MB SD300
Oil Filter removal
Kinda feel like a newb here, but I can't seem to unscrew the oil filter. Any trick to this?
Perihelion is offline   Reply With Quote
Old 05-01-2013, 03:10 PM   #2
cnk
Drives: '13 DGM BRZ Limited
Get a oil filter cap from Pep Boys or Autozone. You could also use a oil filter strap or Sears has one that rotates with 3 prongs to grip the filter. Usually the first oil filter change is the most difficult since we all know OEM's use gorillas to torque the filters down.
cnk is offline   Reply With Quote
The Following User Says Thank You to cnk For This Useful Post:
JDM FRS (09-26-2013)
Old 05-01-2013, 03:13 PM   #3
p00mba
p00mba's Avatar
Drives: FR-S :)
i use the oil filter strap works like a charm everytime.
p00mba is offline   Reply With Quote
Old 05-01-2013, 03:14 PM   #4
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
My last change the filter was to tight to do by hand. I had put it on the previous oil change.... anyway I didn't have a filter wrench or strap. I managed to get it loose by a rubber mallet and large blade flat screw driver and gently tapping the top edge of the filter.
FRSFirestorm is offline   Reply With Quote
Old 05-01-2013, 03:19 PM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
The Following 16 Users Say Thank You to 7thgear For This Useful Post:
Bonburner (07-22-2013), CrazyWookiee (10-12-2013), donutfilling (05-02-2013), DookDookDGM (05-09-2013), eljefe (05-07-2013), finch1750 (10-08-2013), flippy (05-06-2013), FriedRicr (11-04-2013), Guff (08-26-2013), M-17 (05-01-2013), roddy (05-01-2013), sklimo (05-06-2013), Sportsguy83 (05-06-2013), suaveflooder (05-01-2013), Trojan_SC (06-08-2013), yuicebox (07-13-2013)
Old 05-01-2013, 03:44 PM   #6
suaveflooder
I just did this the other day. It's on pretty tight, I just had to muscle it out. I might have to try the strap people are talking about.
suaveflooder is offline   Reply With Quote
Old 05-01-2013, 03:56 PM   #7
Hanakuso
Like what others said but when worse comes to worse you can jam a screwdriver in it and twist it off. Be prepared for a mess.
Hanakuso is offline   Reply With Quote
Old 05-01-2013, 04:07 PM   #8
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
First of all, wipe the filter dry and clean so you get maximum grip, warm up the car, take it off, if all else fails, wait another hour and try again. If that fails, wait tomorrow and try again. It "always" come off the second day for me, dont know how or why.
LeeMaster is offline   Reply With Quote
Old 05-01-2013, 04:10 PM   #9
leon78
leon78's Avatar
Drives: 13 Whiteout
Use some MAN!
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
The Following 3 Users Say Thank You to leon78 For This Useful Post:
DrDuquette (11-11-2013), JDM FRS (09-26-2013), Tart (09-03-2016)
Old 05-01-2013, 04:11 PM   #10
ayau
Drives: Some rust bucket
Lay a dish washing glove (or any type of rubber glove) on top of the oil filter and twist.
The Following User Says Thank You to ayau For This Useful Post:
Old 05-01-2013, 04:16 PM   #11
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
if you just wanna get it off, and have another handy, and aren't afraid to go to town on it, cut a hole in the top and insert tool to aid in adding torque.
Sometimes you dont wanna buy stuff, you'll never use.
killerkid08 is offline   Reply With Quote
Old 05-01-2013, 04:59 PM   #12
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
I have found that wrapping sandpaper around the filter provides the grip required to remove it.
Otherwise just buy an oil filter cap for a few bucks and call it a day.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
The Following User Says Thank You to deucethemoose For This Useful Post:
tCsonfrs (07-14-2013)
Old 05-01-2013, 10:03 PM   #13
Perihelion
Perihelion's Avatar
Thanks for the advice! I'll try again tomorrow
Old 05-06-2013, 11:00 AM   #14
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
The original filter was too tight to take off by hand on my car, so I drove a screw driver into the side of it and used it as a lever to take it off.
Once you get that filter off, you should NEVER need a tool to tighten or remove a filter again.
Proper filter installation:
Make sure the old gasket from the previous filter is not stuck to the filter seat, then clean the seat by wiping off any oil and dirt. Don't worry if you get some down into the little hole. It will get flushed up into the new filter when you start the engine.
(If this engine had a filter than hung from underneath, you'd fill the new filter with oil at this point. But since our cars have it up top, you'll skip this step.)
Coat the gasket on the new filter with oil. You can use old or new oil, just don't be stingy. We don't want the gasket to snag on the seat when were're tightening the filter.
Now spin the filter onto the post until it stops against the seat.
Finally, grab the filter and turn it one HALF turn to tighten it.
You're done. Your filter will not leak and you'll be able to remove it at your next oil change with just your hand. With a Fumoto drain valve, this car is a tool-less oil change.
The Following User Says Thank You to Draco-REX For This Useful Post:
Pizzman (11-11-2013)
DIY ECU removal Hawaiian DIY (Do-It-Yourself) Guides 21 02-05-2023 01:19 AM
Scratch Removal? feldy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 05-15-2014 10:12 PM
Buzzer removal Micene DIY (Do-It-Yourself) Guides 33 03-14-2013 10:51 PM
Does anybody know exactly what filter the injen Sri uses? I want to get a new filter Frsexxxy Engine, Exhaust, Transmission 13 02-19-2013 10:04 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
