Old 10-29-2012, 09:49 AM   #1
Ingen
Drives: Ultramarine FR-S 6MT
Cold / Wet weather brake issue?
I was driving home last night in the rain and noticed what might be a problem with my brakes. It seemed like the brakes did not work very well for the first 1/2 second after I pressed the pedal, then I would typically press a little harder and they would bite and slow the car down normally. I haven't had any trouble with them up to this point, but I also have not gotten them very wet or let them get cold before last night.
The weather was kind of crap last night - about 40*F and pouring rain, so I wondered if the brakes might have gotten cold and needed a moment to heat up before they were able to really stop the car. Alternatively I wondered if all the water could have something to do with it. As a third option, maybe I'm paranoid and there's nothing wrong at all.
Any thoughts from anyone?
edit: wat-ectomy.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Last edited by Ingen; 10-29-2012 at 10:09 AM. Reason: Tried to make it make more sense.
Ingen is offline   Reply With Quote
Old 10-29-2012, 09:54 AM   #2
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Originally Posted by Ingen View Post
I was driving home last night (around 10) in the rain, about 40*F outside. I noticed that for about the first 1/2 second of brake application, they aren't all that powerful. This is a new thing for me - in the dry they have been totally fine. I was wondering if anyone else has had any trouble with the brakes when they're cold or wet? Once I put a little more pedal pressure on them they shaped right up, but I wondered if they were burning the water off first or something.
wat
chulooz is offline   Reply With Quote
Old 10-29-2012, 10:09 AM   #3
Ingen
Originally Posted by chulooz View Post
wat
Fixed.
Old 10-29-2012, 10:56 AM   #4
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Probably just wet brakes. That's why it's always a good idea to drive slower and follow at a greater distance when it's raining
Freeman is offline   Reply With Quote
Old 10-29-2012, 11:19 AM   #5
Neziah
Drives: 2013 HotLava FRS, 2005 Legacy
wet brakes, normal.
HotLava FRS MT
Neziah is offline   Reply With Quote
Old 10-29-2012, 11:36 AM   #6
TheSt|G
TheSt|G's Avatar
Drives: BRZ L 6MT, 128i 6MT, E39 M5, E36 M3
Many cars(like modern BMWs) apply the brakes lightly here and there as you drive in the rain to keep everything at peak performance. Being a cheap car, it looks like they cost saved that feature.
3.2 911 5MT
BRZ Limited 6MT
BMW E82 128i 6MT
BMW E39 M5 6MT
BMW E36 M3 5MT
TheSt|G is offline   Reply With Quote
Old 10-29-2012, 11:42 AM   #7
Turbowned
Turbowned's Avatar
Wet brake rotors. You have to be mindful of it. As TheSt|G mentioned, some newer, mostly high-end cars have automatic brake disc wiping, so if you've been driving around something like that before, you may never have experienced wet brakes. The first time it happened to me, I totalled my car. Whoops!
brake
Pretty sure car hates the cold weather HuntingtonFRS Issues | Warranty | Recalls / TSB 28 10-21-2012 04:52 PM
wet weather MikesFRS Southern California 1 10-09-2012 01:17 PM
weather shields for the 86.. Slide Scion FR-S / Toyota 86 GT86 General Forum 11 01-18-2012 05:04 AM
FR-S in inclement weather kounkong23 Scion FR-S / Toyota 86 GT86 General Forum 39 05-27-2011 11:16 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
