Old 10-09-2013, 04:21 PM   #1
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Stoptech S/S brake lines: same between stock caliper vs big brake kit?
I'm checking pictures and was hoping someone can verify:
Stoptech Big Brake Kit for FRS/BRZ: front stainless lines, are they the same as the standard off-the-shelf stainless line upgrades for factory calipers?
@FT86SpeedFactory pics from their big brake kit sales thread:
versus...
@RallySport Direct pics from their front stainless line (factory caliper) listing on their site:
The part numbers are the same... can anyone verify?
Also: for other big brake kits, do they also reuse the factory banjo fitting?
Thanks in advance.
-alex
Sportsguy83 (10-09-2013)
Old 10-09-2013, 04:32 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thanks in advance.
-alex
Just got off the phone after talking with Roger from Stoptech. He said the lines are different. The ones included in the BBK are specifically made for their caliper.
What we can do is I can send you my "for stock caliper" goodridge lines and you send me the ones included in the BBK kit (just like we are doing with the Pads).
Good thinking!
Sounds like a plan?
Old 10-09-2013, 04:55 PM   #3
mav1178
mav1178's Avatar
Odd that the two are listed with the same part number. From an inventory control perspective, this isn't the best way to figure out what works with what...
I'll put the BBK lines in the box.
-alex
Old 10-09-2013, 05:04 PM   #4
Sportsguy83
Drives: Limited BRZ
-alex
Maybe try to call yourself to double check? I forgot to tell him that part number thing. It seems odd IMHO too...
He sounded extremely confident. Like immediately told me no, they are not the same.
Sent from my HTC One X using Tapatalk 4
Old 10-09-2013, 06:27 PM   #5
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Good thinking!
Sounds like a plan?
Getting a Beebeekaay ?
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Old 10-09-2013, 06:42 PM   #6
CSG Mike
CSG Mike's Avatar
This probably doesn't help, but the Speigler lines we sell work for most BBK as well as the stock caliper.
mav1178 (10-09-2013), Sportsguy83 (10-09-2013)
Old 10-09-2013, 08:40 PM   #7
mav1178
mav1178's Avatar
Hmmm the mystery deepens... I know a lot of aftermarket big brake makers nowadays are using banjo fittings, but when I last had a BBK (Rotora/Endless on my S13) those were flared fitting ends.
Interesting. Will dig into this deeper and report back.
-alex
Old 10-09-2013, 09:29 PM   #8
CSG Mike
CSG Mike's Avatar
I believe the stock (and spiegler) is a banjo fitting, but I don't know the technical terms for a lot of parts...
Old 10-10-2013, 01:52 AM   #9
mav1178
mav1178's Avatar
What the pic shows is a banjo fitting, what most OEM single/2-piston sliding calipers use.
A lot of aftermarket calipers and/or previous OE 4 piston calipers (see: Nissan Z32 and Z33) uses flare fittings, similar to what goes into the brake master cylinder.
http://www.eastwood.com/Brake_article for what they look like.
I only care about this because it may come in handly for those of us looking to jump up to larger brakes, but already have stock caliper S/S line upgrades.
-alex
Old 10-17-2013, 10:35 AM   #10
Sportsguy83
Drives: Limited BRZ
-alex
I called them again yesterday to ask a question regarding the rear rotors, but again asked about the SS lines. Again they responded they are different I asked how and he said the ones with the BBK are usually longer...
I STILL call BS on this because how can you control this with same part number, but will be installing the Stoptech lines just to err on the safe side.
Old 10-17-2013, 11:41 AM   #11
Excelerate
Excelerate's Avatar
Drives: Crystal Black BR-Z Limited
Just got off the phone with Stoptech. I called in just referencing the part number, not the vehicle, for our cars which is 83.827.4300.xx which is the ST40 328mm front kit. I asked what the SS line replacement part number was and they said 950.44034. I then proceeded to ask what the replacement lines for 83.827.002G.xx (rear ST22 345mm kit) were and they said 950.47508.
I then asked what the part numbers were for the BR-Z and FR-S stock SS lines. SAME. They are the same part. It's not a common thing but in this situation the stock lines and the BBK lines from Stoptech are the same.
I spoke with Roger.
Excelerate is offline   Reply With Quote
The Following 3 Users Say Thank You to Excelerate For This Useful Post:
asnatlas (05-10-2016), CSG Mike (10-17-2013), Sportsguy83 (10-17-2013)
Old 05-10-2016, 07:14 PM   #12
asnatlas
Drives: 2013 - BRZ - SWP
Post
I spoke with Roger.
Thanks for the info...
asnatlas is offline   Reply With Quote
FS: Stoptech SS Brake Lines xman11 Brakes, Suspension, Chassis 6 08-12-2013 01:53 PM
FRS/BRZ StopTech Brake Pads, Rotors and Lines at Redline360 Redline360 Brakes, Suspension, Chassis 4 01-13-2013 02:42 AM
FS: Stoptech Brake Lines FRS2000 Brakes, Suspension, Chassis 1 12-17-2012 04:07 PM
Stoptech Front Stainless Steel Brake Lines Pekingduck Brakes, Suspension, Chassis 1 10-21-2012 10:29 PM
StopTech Stainless Brake Lines (Front and Rear) for BRZ/FR-S at Redline360 Redline360 Brakes, Suspension, Chassis 1 07-19-2012 01:41 PM
