Any experience with calculating these gains?
Engine:
Perrin crank pulley Clutch: Undecided, lightweight street clutch and flywheel Driveshaft: DSS or PST carbon fiber driveshaft Fuel: e85 and 91 tunes, likely with OpenTablet Exhaust: Borla UEL (sound profile, not max HP) Perrin overpipe Perrin catted front pipe Invidia N1 exhaust Wheels: (maybe) Undecided, lightweight Anybody have an idea what this shopping list might net me as far as HP goes? My overall goal is for the car to be more of what it already is... Just increasing how quickly it revs and allowing it to breathe easier... Overall, a more "peppy" car.
Setup 1: KW C38, Grams 550, Grams 265, 4bar, FlexFuel, Delicious
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor Last edited by SPCorBUST; 09-29-2013 at 01:37 AM. |
Not trying to be a ****
Drives: BRZ - 6MT - GBS
Header?
Search and read up on it
-EvilBeaverFace - My 2013 Subaru BRZ - 6MT - Galaxy Blue Silica
Inland NW 86 Owners Club on Facebook (Spokane, WA/CDA, ID area) FRS/BRZ/GT86 Enthusiasts Facebook Group |
Drives: Pavement MT GR86
Headers over pipe and a tune will give you a solid 20whp. And cost less than your list.
Light weight battery and the aluminium ds would be good if shedding weight is a primary goal.
GR86 MT premium
| The Following User Says Thank You to SPCorBUST For This Useful Post: | EvilBeaverFace (09-29-2013) |
#5 | |
Carbon DS > Aluminum as far as weight goes, debating on the weight savings for the battery. i'm less concerned about overall weight loss, more about shedding weight in the rotational mass.
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
The Driveshaft Shop driveshaft is lighter and cheaper than the PST. I'll definitely be going Driveshaft Shop once the time comes, unless someone can outdo them between now and then.
I've researched pretty deep into brakes, and the AP Sprint kit seems to be the best bang for the buck as far as weight and effectiveness are concerned. You can go a bit lighter than the Sprint kit, but you'll be hard pressed to have better functioning brakes if you go lighter, from what I've learned. They'll set you back ~$2,100, but it's a lot of unsprung rotating weight, and up front which is best for getting that 50/50 front/rear balance.
| The Following User Says Thank You to Anthony For This Useful Post: | SPCorBUST (09-29-2013) |
Weight Nazi
Oh, and for batteries, the two best that I know of would be:
4.96lbs - Shorai LFX36L3-BS12 - ~$350 3.90lbs - Super B 10P - ~$750 I'm actually considering dropping the $750 for that battery one day. Yeah, that's silly-expensive, but apparently it fully charges within 5 minutes of driving and lasts a really long time. Could actually be cheaper in the long run if it really does last as long as it's supposed to. And 3.9 pounds for a battery...
#8 | |
Drives: Subaru BRZ Limited
Thanks. |
Never mind I didn't read the post lol
GR86 MT premium
| The Following User Says Thank You to StormTrooper For This Useful Post: | Anthony (09-30-2013) |
#10 |
Weight Nazi
Are you talking about the balance of the whole car? Such as front:back and driver's:passenger's sides? If so, it does effect the balance, but in a good way. Most of the weight is in the front of the car, so that's where the priority for weight reduction is.
| The Following User Says Thank You to Anthony For This Useful Post: | cslntuee (09-29-2013) |
#11 | |
This is the rout I'm going as well. It may not be a horsepower beast, but it'll still be quick |
| The Following User Says Thank You to suaveflooder For This Useful Post: | SPCorBUST (09-29-2013) |
#12 | |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
DSS Carbon Driveshaft - 12.2 lbs $1000 DSS Aluminum Driveshaft - 13.2 lbs - $438 Axle Exchange Aluminum Driveshaft - 12.? lbs - $425 How is Carbon DS > Aluminum? Explain that one to me. An extra $600 - $700 to save potentially 1 extra pound of ratational mass does not seem "better" to me. And the only reason I say potentially saving 1 pound is if you were only looking at the DSS. You could potentially save approximately 1 pound of rotational mass AND save $675 if your two options were PST and Axle Exchange. Just food for thought.
| The Following User Says Thank You to Dustin For This Useful Post: | cslntuee (09-29-2013) |
#13 | |
How about the noise level of driveshaft between carbon fiber and Aluminum? Thanks. Last edited by cslntuee; 09-29-2013 at 10:00 PM. |
#14 | ||
Twin Screw You
I doubt with these mods anyone would be worried about the noise level of adding a driveshaft.
| The Following User Says Thank You to Dustin For This Useful Post: | TheseColorsDontRun (09-29-2013) |
| TRD CAI and Exhaust HP Gains | tennisfreak | Engine, Exhaust, Transmission | 51 | 11-08-2016 09:30 PM |
| ECU HP gains? | ender2664 | Engine, Exhaust, Transmission | 45 | 03-31-2013 04:33 PM |
| Torque gains, what does the job? | JoeBoxer | Engine, Exhaust, Transmission | 21 | 10-01-2012 06:46 AM |
| Biggest gains | yomchi1989 | AUSTRALIA | 5 | 09-28-2012 08:31 PM |
| Exhaust HP Gains | FoolCyclist | Engine, Exhaust, Transmission | 79 | 06-22-2012 01:47 AM |
