Drives: Whiteout FR-S
Torque gains, what does the job?
I have a Motiv test pipe, Cosworth air filter, Perrin pulley, and Visconti Stage 1 flash coming with the group buy shipment. I know most are going for 200whp NA which i would like to see also when I get the E85 tune after on the fly map switching is available.
I really want to see more low to mid range torque even if its at the expense of a few hp. I'm going ask John if he can do my E85 flash for more torque but what else can i do? Nameless mentioned to me they have a couple header designs one being for the torque gains I want which I will probably get but which cat back or axle back exhaust do you guys think will offer the most low end power? |
Registered you sir
Drives: 99 impreza coupe
Id say enjoy your ride now while waiting for some proven header designs; may not necessarily be the first to show gains in the market.
Drives: '06 AM V8V Coupe
The only bolton that will really buy you low end torque at the expense of high end is some detuned cams.
#4 | |
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
I come from Golf R32 who have VVT and their it's been prouved by many Dyno that: - 264/260 make more torque around 3000 rpm than OEM cam and more high end hp -268/264 make more torque around 3000 rpm than 264/260 cam and more high end hp - 272/272 make same torque around 3000 rpm than 268/264 cam and more high end hp When going for more duration on VVT you often get a win win. |
#5 | |
Of course I'm not totally sure but I think the evidence is pretty strong that the cams are somewhat high end oriented. |
Cams may be an option down the road but i will keep that in mind. Do you guys think i need to keep some backpressure in the exhaust or get as free flowing as possible? I know turbo applications are different but Full Blown picked up a lot of torque when they added their 3" exhaust to their car.
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Honestly, the last E85 dyno John posted is pretty good low end. It is actually really good for a 2.0L 4-cyl NA. Take a look at the dynos from some other NA 2.0L engines.
A small turbo, a roots blower, or a bored/stroked bottom end will be the only ways to get a significant amount of additional low-end torque. Some cams may increase power across the board, who knows... but I don't think the low-end will be much improved. |
Yeah i should hold off on the exhaust until after the E85 tune i suppose and go from there.
Drives: 2013 Asphalt FR-S
John didn't pick up that much power with exhaust on his E85 tune. And you already have the motive pipe. I would put the money elsewhere. Not sure what more you're expecting. Its an N/A 2.0l 4 cyl. Johns tune alone makes the low end and midrange much stronger.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
#10 |
Yeah so far the tunes plus parts at least with the E85 tunes hasn't really made much difference. Not sure how things are with 93, but I've seen tuning results from another vendor which shows gains with parts plus tuning. But the E85 tune so far has by far the biggest effect on mid range torque apart from a turbo kit.
#11 |
the timing changes are huge after applying the stage 1 map...on pumpgas
cant wait to try e85...psyched! |
#12 |
form follows function
Drives: RIP '13 BRZ
A final drive ratio change might give you what you want at the expense of higher cruising rpm. Poor man's supercharger.
#13 |
Joe, how much torque are you shooting for? My car just put down 162 to the wheels. I don't have a ton of mods.
#14 |
What do you have done? I was looking at the E85 dyno sheet showing about 153 i was hoping for 165-170 but the numbers aren't the main thing just would like nice gains that aren't all the way at the top of the rev band.
| Biggest gains | yomchi1989 | AUSTRALIA | 5 | 09-28-2012 07:31 PM |
| Exhaust HP Gains | FoolCyclist | Engine, Exhaust, Transmission | 79 | 06-22-2012 12:47 AM |
| What kinds of gains do you expect with E / I and tune? | Partial Stall | Engine, Exhaust, Transmission | 66 | 05-10-2012 11:56 AM |
| What kind of gains without Turbo | Surge101 | Engine, Exhaust, Transmission | 18 | 01-25-2012 09:23 PM |
| Estimated HP gains - bolt on mods and reflash? | ahausheer | Engine, Exhaust, Transmission | 207 | 01-14-2012 06:14 AM |
