Old 09-20-2013, 06:23 PM   #1
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
BRZ Front Plate Relocation - No (visible ) Holes
I've been driving my BRZ for 5 months without a front license plate. Yesterday I got pulled over (didn't get a ticket...the officer was shocked to see an old man driving the car) and I decided it was time to install a front plate. When I went out to install the factory plate to the black bar I just couldn't bring myself to drill the first hole. Holding the bracket in my hand up-side down it occurred to me that with a little modification I could have the plate extend below the black bar rather then in front of it.
First step was to locate where I wanted the holes in the frame. I drilled two holes as close to the 90 degree bracket using a nut as a guide. I then cut the front plate holder so I had just enough room to capture the top mounting holes in the plate. I used a cut off wheel and got this:
A cut off wheel actually melts the plastic, so I used a knife edge to debur the plastic:
I had a license plate frame sitting in my garage so I used that reinforce and strengthen the plate:
I also reused the hardware that came with the factory plate kit. I cut a 3/16 long piece of hose to use as a spacer:
I inserted the 10mm bolt through two holes that I made in the plastic frame and held those in place with my hose-spacers:
I then drilled two holes from below the black bar. I used the clip nut from the factory kit to ease installation. Here's the result. Total cost $0.00
There are no visible holes so if I ever move to a state that doesn't require a front plate I wont have to replace the black bar. I also think this is a more natural looking location for the plate. Plenty of room for airflow too.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Help covering front bumper license plate holes JLMIAMI Cosmetic Modification (Interior/Exterior/Lighting) 56 01-27-2018 05:39 PM
Free front plate relocation Takumi788 Cosmetic Modification (Interior/Exterior/Lighting) 5 09-09-2013 08:45 PM
WTB. Stock white front bar with no licence plate holes. jet86 Exterior Parts (Aero, Lighting, Etc.) 0 03-15-2013 02:08 AM
Front plate relocation now in stock @ JRP Stav Canada Classifieds 2 09-07-2012 06:45 PM
