Old 02-29-2012, 12:14 PM   #1
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Details: Interior dims, glass, light bulbs
If you haven't seen it yet, there are some tidbits on the Toyota Japanese site about the 86 that certainly pertains to the FR-S and BRZ.
Questions about the 86
Things like:
*GT Limited & GT trims [i.e. USDM] = 215/45R17 87W, 17 × 7J aluminum 5x100, offset= +48, hub bore = 56mm, bolt hole = 14.5mm
*Loudspeaker specs:
Dash tweeters are 1", 2.5W rated, 35W max
Door woofers are 6.3", 20W rated, 40W max
Rear panel speakers are 2.5", 10W rated, 35W max
[doesn't mention the assumed two midranges in the dash we get in the USDM car]
*Lighting:
Halogen low beams are H11, high beams H3B
HID bulbs are D4S
Taillights are 12 LED's per side
*Glass
Windshield passes 79% visible light, blocks 99% UV
Side windows pass 73% visible, blocks 91% UV
There's "green" and "privacy" rear glass, not sure which the USDM gets
*Interior dimensions!
Depth of trunk with rear seats up is 810mm at bottom, 670mm at top
Height of trunk is 340mm min, 390mm max
Max width of trunk is 1395mm, and 1075mm between wheel arches
...also dims with rear seats folded and front seats full-rearward
1435mm from bottom rear of trunk to back of front seats, and 1250mm from top of trunk to upper back of front seats
Enjoy!
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 02-29-2012, 12:31 PM   #2
gt86mods
Toyobaru Obsessed
gt86mods's Avatar
Drives: 97' Civic Coupe
Will the FR-S come with HID's from the factory? I know they are projected but a lot of cars out there have projected halogens. May be an option or something. I haven't done any searching on the forums about this but I'd assume nobody would know for sure yet. On a car with such a low base price I'd imagine they would stick with halogen to cut costs.
Canon Photographer - My Website - Flickr Gallery
Originally Posted by 86'd View Post
That's it. I'm cancelling my pre pre-order.
gt86mods is offline   Reply With Quote
Old 02-29-2012, 12:33 PM   #3
KidWonder
Drives: 2004 Volkswagen Passat Turbo
The Scion FR-S will not come with HID lights. Scion is not a luxury brand.
KidWonder is offline   Reply With Quote
Old 02-29-2012, 12:40 PM   #4
AX_FRS
Drives: 05 Ford Focus ZX4
Cool, now people can get the tape measure out and figure out if they can fit all their stuff in the back. I am going to be measuring my dog crate when I get home. I don't know if it would slide in the trunk when broken down, but maybe go the roundabout way and put it in the passenger compartment with the seats down and then put the seats up once it's in the trunk.
AX_FRS is offline   Reply With Quote
Old 02-29-2012, 12:45 PM   #5
AX_FRS
Ford isn't a luxury brand and they are making HIDs standard on the 2013 Mustang. It's probably more of a way to distinguish between Subaru and Scion in the US and also to lower cost on the Scion to better match what the brand is meant to be for. Get young people in nicely equipped and reliable cars to try and gain some Toyota brand loyalty at an earlier age since most Toyotas are boring looking cars that young people aren't that interested in.
Edit: also, pretty sure Subaru isn't a luxury brand, either
Old 02-29-2012, 01:07 PM   #6
Ryephile
Hot Dog
Ryephile's Avatar
Scion FR-S = Halogen
Toyota 86 = Halogen, optional HID [with LED eyebrow DRL]
Subaru BRZ = HID [with C-shaped light-pipe DRL]
Old 02-29-2012, 02:38 PM   #7
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
Well if I have to get the Scion, due to pricing or whatever, I like the fact that it's a H11 housing for the headlight.
You can "upgrade" them with a H9 halogen bulb, for an increase in output, but with a shorter life.
After recently driven in a new car (Ford Fiesta) with halogen headlights I was surprised in how well they performed, if the Scion performs as well, then the only reason I'd get the BRZ is for the "cooler" looking headlights. Hrmmm...
86'd is offline   Reply With Quote
Old 02-29-2012, 02:42 PM   #8
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
It will be a matter of weeks before some companies make OEM Toy86 hid headlight packages with all the wires/switches. Market for them will be huge.
Scion is kinda dumb not to offer them as port or dealer upgrades - free profit.
Khyron686 is offline   Reply With Quote
Old 02-29-2012, 02:48 PM   #9
Double4Free
Ashes to ashes.
Double4Free's Avatar
Drives: Asphalt FR-S
Wonder how hard it will be to put in an LED strip on the headlights yourself. Sucks that they wont be offering that along with HID, even as an option. I mean stock halogens sure, but some people wouldn't mind dropping a little more change for the upgrade.
Double4Free is offline   Reply With Quote
Old 02-29-2012, 02:51 PM   #10
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Things like:
*Loudspeaker specs:
*Lighting:
HID bulbs are D4S
*Glass
Enjoy!
Nice, thanks for posting!
I don't care what people say, I'm going to put a D4S 4300K HID bulb into the OEM Halogen projector housing.
http://www.theretrofitsource.com/pro...oducts_id=3180
Old 02-29-2012, 03:16 PM   #11
Longhorn248
Hook 'em
Longhorn248's Avatar
You realize there's a little bit more involved than just sticking some HID bulbs in there right?
Longhorn248 is offline   Reply With Quote
Old 02-29-2012, 03:31 PM   #12
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
I am going to order the Toyota 86 HIDs and put them in or maybe the BRZ HIDs.
This car deserves HIDs.
tripjammer is offline   Reply With Quote
Old 03-01-2012, 01:20 AM   #13
CoryUyede
NisSubuGuru?
CoryUyede's Avatar
Drives: 2011 Subaru WRX
For Anyone interested in Doing HID's the RIGHT way, i'll share some insight. I'm a Guru for stuff like this so i'll elaborate.
I can say i'm very hopeful for this car If the North American spec DOES have the H11 projectors. I'm Going to go out on a small limb and say they are the Halogen Projectors from EITHER the Toyota Camry OR Subaru IMPREZA. I can't verify which one until i see the bowl design.
(The "Lazy" hid install)
Either one is a VERY Decent Candidate for the "lazy" plug and play hid installs if you bend down the "squirrel finder". I don't condone plug and play kits though! so please don't flame me! But by plug and play standards they're a 9 out of 10 performance, you could do ALOT worse. Anyone concerned about blinding oncoming traffic, bending the "squirrel finder" gets rid of like 95% of that glare. which was already minimal.
Here's a pic of camry HALOGEN projectors w/ installed H11 HID (4300K) with properly modified Glare shield and New Lenses.
http://i1233.photobucket.com/albums/...r/214aa114.jpg
(The PROPER retrofit way, AKA swapping projectors)
-if they're IMPREZA projectors- It's tougher. "TheRetroFitSouce" make a decent D2S setup that MAY work
http://www.theretrofitsource.com/pro...roducts_id=254
Or else you can find the 2006-2012 STI HID projectors and It's literally a Direct Bolt on. Possibly even the BRZ HID projectors could be the same model.
-if they're the Camry Projectors- This is what i'm hoping for! If they are, A lexus RX350 Projector swap could be a very simple fix to get amazing lighting. The RX350s are some of the best projectors available. The only variables are actual space INSIDE the headlight.
TRS ALSO make a kit for the Camry, so it SHOULD apply here too. I believe the projectors offered on the Camry Kit are alot better than the projectors they offer on the Impreza Fitment.
If anyone has any questions feel free to ask!
My first mod to the FR-S is likely a retrofit..lol
Past to Present
CoryUyede is offline   Reply With Quote
Old 03-01-2012, 04:30 AM   #14
Sasquachulator
Pavement Grey
Those trunk specs:
The smallest dimensions indicate the trunk is 8.7cubic feet. (With the way a trunk is shaped, theres a little more room to be had than this, how much more is the question)
The largest dimensions indicate the trunk is 15.6cubic feet (with the way a trunk is shaped, no chance of it being this big)
Im guessing trunk size is somewhere around 10 cubic feet.
Third brake light...(top mount) Slide Cosmetic Modification (Interior/Exterior/Lighting) 103 02-22-2017 02:47 PM
New set of Toyota FT-86 interior photos from the studio (some great details) Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 52 09-15-2013 01:29 PM
Red tail light photoshops OwenK FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 68 02-06-2013 03:48 PM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 03:53 PM
