Old 12-06-2012, 09:28 PM   #1
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
The big 3 upgrade
Has anyone performed this upgrade on their system. If so, what's your current RMS draw from your audio gear and what gauge wire did you upgrade to?
crazyfrenchbiker is offline   Reply With Quote
Old 12-06-2012, 09:36 PM   #2
2forme
Ummm whats the big 3.....
Old 12-06-2012, 09:40 PM   #3
crazyfrenchbiker
Hot Lava 6MT
The “Big 3” upgrade is a swap or addition to these three cables:
1) Alternator positive cable that runs to the positive terminal of the battery
2) Negative battery cable that runs from the battery to the vehicles chassis
3) Chassis grounding cable that runs to the engine block
Old 12-06-2012, 09:51 PM   #4
ProTekk
ProTekk's Avatar
Drives: Whiteout FR-S
Haven't done it yet but I absolutely need to due to my audio equipment. Once I get everything in order I plan on doing a DIY.
ProTekk is offline   Reply With Quote
Old 12-06-2012, 10:01 PM   #5
crazyfrenchbiker
Hot Lava 6MT
Any idea what the stock gauge is? I'm thinking of upgrading mine to 4 gauge, but I am not sure if it's worth it.
Old 12-06-2012, 10:42 PM   #6
mashal
DADA
mashal's Avatar
Drives: 2013
What system are you planning to run ? I have never seen anyone do this unless they are pushing more than like 3000watts
I-Tapatalk
mashal is offline   Reply With Quote
Old 12-06-2012, 10:48 PM   #7
crazyfrenchbiker
Hot Lava 6MT
The total system should be around 2500W RMS.
Old 12-07-2012, 12:02 AM   #8
mashal
DADA
mashal's Avatar
Drives: 2013
Lol what are you running ? That trunk is never gonna be the same with that much poundage
I-Tapatalk
Old 12-07-2012, 12:15 AM   #9
crazyfrenchbiker
Hot Lava 6MT
I-Tapatalk
Wait for the post and see
Old 12-15-2016, 03:07 PM   #10
koast2koast
Drives: 2015 Toyota 86 high spec Auto, TRD
Did you ever get around to doing this? I'm keen to do it on my 86.
koast2koast is offline   Reply With Quote
Old 12-15-2016, 03:32 PM   #11
jasonojordan
Drives: 2013 satin white brz limited
Well since this was 2012 when the last post was made I think its safe to assume that the system we are here to "wait and see" killed him.
jasonojordan is offline   Reply With Quote
Old 12-15-2016, 04:10 PM   #12
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
The trunk probably rattled itself apart with that much power. Thank god it did.
PandaSPUR is offline   Reply With Quote
Old 12-15-2016, 04:17 PM   #13
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I have run two amps in my FR-S off one 2awg wire. Had zero issues. Had a cap too, but did not need it, so did not install it.
I imagine that you would need some very hungry amps and subs to need this upgrade. I ran 2 15" earthquakes with a 2000W Lanzar bridged to each one, and a 4 channel amp run to the interior speakers. My headlights dimmed in my Acura.
And, now I can't hear. WHAT???
Old 12-16-2016, 12:35 AM   #14
koast2koast
ha ha ha!
Need to upgrade the oil pan for the FRS/BRZ? Hanakuso Engine, Exhaust, Transmission 5 12-28-2014 12:54 PM
HU upgrade briang0901 Electronics | Audio | NAV | Infotainment 15 11-05-2012 11:17 AM
Anyone Looking To Upgrade Their LSD? SpeedBRZ Engine, Exhaust, Transmission 27 07-19-2012 06:33 PM
FR-S HID Upgrade? frsinpa Cosmetic Modification (Interior/Exterior/Lighting) 25 06-18-2012 08:43 AM
What will be the first upgrade you buy for your FR-S / BRZ? HitTheGas Off-Topic Lounge [WARNING: NO POLITICS] 9 02-26-2012 07:30 PM
