Old 09-16-2013, 02:15 PM   #1
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
MT Upgrade
It seems like every part of this car has a stronger upgrade for it aside from the manual transmission. I thought by now there would a PPG set or something out for this transmission.
Aside from swapping it out for a stronger one that includes custom fab work and more headache than its worth, is there a way to make this transmission handle a decent amount of power?
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 09-16-2013, 02:32 PM   #2
boxer 2.5
Drives: 2007 Impreza, 2013 BRZ
The crawford build is holding up to 450hp, so I'd say it isnt doing too bad
just my 2cents
boxer 2.5 is offline   Reply With Quote
Old 09-16-2013, 02:56 PM   #3
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
just my 2cents
the crawford build blew up twice, and wrecked a mclearn . The Tranny isnt rated for high hp, and has been a hit or miss with people at high HP
Old 09-16-2013, 03:07 PM   #4
Dezoris
Dezoris's Avatar
Evasive is working on a replacement trans. Don't know details though.
Old 09-16-2013, 03:09 PM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I have seen very few failures, so I don't know where this view is coming from. What do you consider "a decent amount of power"? Have you been talking to Don & John?
Old 09-16-2013, 03:12 PM   #6
SkullWorks
Drives: SSM LT MT BRZ
The fundamental issue with "upgrading" a transmission internally is, the real limit is found when the case starts to deform from the pressure of the gears trying to push eachother away.
Old 09-16-2013, 03:14 PM   #7
Tansey86
Tansey86's Avatar
Yeah Don has a tranny swap available but im more specificly interested in making the stock unit stronger, if at all possible.
Old 09-16-2013, 03:50 PM   #8
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by SmsAlSuwaidi View Post
the crawford build blew up twice, and got wrecked by a mclaren . The Tranny isnt rated for high hp, and has been a hit or miss with people at high HP
fixed your post.
Old 09-16-2013, 04:24 PM   #9
Tansey86
Tansey86's Avatar
Evasive Motorsports? Talked to them and they have no plans on doing any replacements.
Old 09-16-2013, 04:36 PM   #10
utekineir
blowhard
Drives: frs, project forester
http://forums.nasioc.com/forums/show....php?t=2395474
This sort of thing is offered for the subaru 5speed.
Moore Performance BlastPlates™
Retail price: $400
Group-Buy Price: $350 (10) $325 (15) $300 (20+)
Quantity needed to meet GB price: 3
Have a Subaru 5-speed manual transmission, and can’t seem to sleep well after a night full of Stage 3 highway pulls? Sleep better, and help those poor gears out, with Moore Performance’s BlastPlates™: The quick and effective way to stave off that pesky case flex.Using both heavy case reinforcement and a higher clamping load, The Moore BlastPlate™ kit is wise insurance for those Subaru owners trying to get the most out of their 5-speed gearbox. Heavy steel plate is jigged, then TIG-welded for ultimate strength and excellent fitment. Gloss-black powdercoating makes ‘em look pretty. And last but not least, the included class 10.9 hardware ensures that your case can be torque’d up to our race-proven specs!
utekineir is offline   Reply With Quote
Old 09-16-2013, 07:09 PM   #11
lexusb3
Drives: FRS
mine holds up well i changed the fluid and added the stiff trans mount still going
lexusb3 is offline   Reply With Quote
Old 09-16-2013, 07:26 PM   #12
mike the snake
Adding a pump and oil cooler will go a long ways towards your transmission holding up under higher loads.
When I was researching transaxles for a race car I wanted to build, I found Porsche transaxles rated for 180hp were magically uprated to 219hp with the only difference being an oil cooler.
A simple, inexpensive setup could use tapped filler and drain plugs with a pump. More elaborate setups have internal spray bars and other stuff.
Bad juju happens when things gets hot.
Old 09-18-2013, 03:11 AM   #13
boxer 2.5
link to it blowing? Thanks!
Old 09-18-2013, 01:57 PM   #14
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Yeah it does. When we flat bottom our STi race car the transmission always mysteriously fails so yes cooler gear oil does improve longevity. I'm not sure it miraculously increases it's power capability for something like drag racing or dyno work however.
Element Tuning is offline   Reply With Quote
The big 3 upgrade crazyfrenchbiker Electronics | Audio | NAV | Infotainment 22 12-19-2018 04:26 PM
Need to upgrade the oil pan for the FRS/BRZ? Hanakuso Engine, Exhaust, Transmission 5 12-28-2014 12:54 PM
HU upgrade briang0901 Electronics | Audio | NAV | Infotainment 15 11-05-2012 11:17 AM
Anyone Looking To Upgrade Their LSD? SpeedBRZ Engine, Exhaust, Transmission 27 07-19-2012 06:33 PM
FR-S HID Upgrade? frsinpa Cosmetic Modification (Interior/Exterior/Lighting) 25 06-18-2012 08:43 AM
