Old 09-14-2013, 11:14 AM   #1
Djen
Drives: GT86
Angry emission test Wont Pass P0441
Greeting. if some Experter help me out we well be much appreciate it to him.
my car running only afew miles. I have FBM Turbo kit and now im having one issues belong to Randomly thrown same Code P0441 all time. I send my car to the shop who installed the kit we inspectd some hoses looks like everything hoocked up correctly even we we check it the gas cap we couldn't find any more then a small leak in turbo oil feed line and already fixed with new gasket and selant silicon. eveytime I clear the code with Ecutek it com randomly during crusing in afew days later asame code. keepin the dashbored with check engine and TRC Lights on!!
Djen is offline   Reply With Quote
Old 09-14-2013, 11:23 AM   #2
jamesm
do you have the ecutek boost control that uses the evap solenoid hookup? that's an evaporative emissions code.
Old 09-14-2013, 11:32 AM   #3
Djen
Drives: GT86
sorry but im not sure what your taking about. i have FBM manual boost controller and ECUtek tune done by FBM
Old 09-14-2013, 11:33 AM   #4
Djen
Drives: GT86
can you explain this and how can we check for this ?
Old 09-14-2013, 11:35 AM   #5
Frs300
Frs300's Avatar
Drives: Pile of junk
if you have mbc that came with fbm kit then you dont have the mbcs that hooks to the evap system to control boost through ecutek
unless they switched. last i heard LJ was using a reg old mbc for boost
Frs300 is offline   Reply With Quote
Old 09-14-2013, 11:36 AM   #6
Djen
Drives: GT86
yeah i have FBM manual boost controller installed with my vaccum hoses already.
Old 09-14-2013, 02:19 PM   #7
Gen
Drives: Scion FR-S
I had the same code after installing my FBM turbo. It went away on its own...
Gen is offline   Reply With Quote
Old 09-14-2013, 02:32 PM   #8
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I have the same issue with P0451. It happened after I disconnected the EVAP sensor to try the ECUtek boost control. the only way I got rid of it was by telling my tuner to disable it.
No other way around it so far...
Old 09-14-2013, 10:21 PM   #9
ATSAaron
Drives: 2013 Raven FR-S
There is no check valve on the evap system, right? And the evap system is set to open at higher loads (I think) to allow the engine to suck the fumes in. But if the valve open under boost it's possible that the turbo is pressurizing the evap system.
Just my guess.
Aaron
ATSAaron is offline   Reply With Quote
Old 09-14-2013, 11:04 PM   #10
mad_sb
Drives: 2013 Asphalt FR-S
I am guessing no one zip tied the connections on the EVAP solenoid and one of the lines popped off.
See here for the fix
Just my guess.
Aaron
Good thinking, if the lines have not popped off then this may be something to look into.
Evap system description and test procedure begin on page 1135 of the FRS manual posted on this site. LOTS of good info.
In short P0441 is associated with evap stuck, open, evap stuck closed, or a gross leak. My guess is the latter
Old 09-15-2013, 09:54 PM   #11
Calum
That Guy
Drives: 2013 asphalt FRS MT
Did you ever get this figured out?
Old 09-16-2013, 11:12 AM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
My guess is something is wrong with one of the vacuum lines for the fuel vent system. I would make sure that all the lines are connected properly from where the metal fuel vent line ends near the quick disconnects for the fuel lines to where the valve gets vacuum from the bottom of the intake manifold. The vent line was probably disconnected during the install of the fuel injectors.
Old 09-16-2013, 03:48 PM   #13
Cessblood
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
I got the same code. Well I had the same code.
Cessblood is offline   Reply With Quote
Old 09-16-2013, 04:22 PM   #14
Sportsguy83
Drives: Limited BRZ
Had? How did you fix it?
Will headers cause me to not pass smog? 67corvette Engine, Exhaust, Transmission 39 11-13-2018 11:12 AM
emission standards? rainmonkey Northern California 10 04-23-2013 07:50 PM
Will the borla headers pass emmision test? Frsexxxy Engine, Exhaust, Transmission 3 03-24-2013 09:39 AM
Does the US BRZ meet emission standards of all 50 states? slowbrz BRZ First-Gen (2012+) — General Topics 11 11-15-2012 01:31 AM
Emission and noise restriction in DMV guy Mid-Atlantic 6 11-14-2012 12:30 PM
