Old 09-13-2013, 05:37 PM   #1
JRP
JRP's Avatar
Drives: 2013 Perl White FR-S
Removing a fuse to reset the ECU?
For Toyota's, you can remove the EFI fuse for 5 minutes to reset the ECU; is there a fuse on the 86 I can remove to reset the ECU? I'm hoping not to have to remove the negative cable from the battery. I searched but couldn't find anything on this site and my FR-S has 4 EFI fuses, and I'm not even sure removing all or some of them would reset the ECU. I want to reset the ECU because I put on a new catback and intake and feel it won't hurt to reset the ECU.
Jim
JRP is offline   Reply With Quote
Old 09-13-2013, 05:39 PM   #2
Hardrock4445
Hardrock4445's Avatar
The time it takes you to find that information, ou could have already removed and crossed the battery cables for 10 minutes, reconnect and be done.
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
Old 09-13-2013, 05:42 PM   #3
onefitz
Drives: 13 GBS BRZ
Just pull the negative.
onefitz is offline   Reply With Quote
Old 09-13-2013, 06:08 PM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I guess if he plans on do it more than say 5 times, it will be worth finding the info out one time over removing bat. connector every time.
Old 09-13-2013, 06:13 PM   #5
JRP
JRP's Avatar
Actually I'm sitting at my desk at work so I have the time to wait to see if someone has the answer. I'm trying to avoid reprogramming the radio, syncing my phone etc. Pulling the negative takes more time than pulling a fuse.
Jim
Old 09-13-2013, 06:17 PM   #6
Lytheum
Drives: 2013 BRZ Premium 6MT
the brz radio saves my settings when unhooking the battery. i do have to turn the gear indicator back on everytime though.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
The Following User Says Thank You to Lytheum For This Useful Post:
Sportsguy83 (09-13-2013)
Old 09-13-2013, 06:43 PM   #7
JRP
JRP's Avatar
In looking at the wiring diagram found on this forum, it looks like the 7.5 amp EFI +B fuse is the one to pull which is the same for a Toyota. This runs from the battery directly to the BATT pin on the ECM.
Jim
The Following 2 Users Say Thank You to JRP For This Useful Post:
jliongh (12-02-2016), Sportsguy83 (09-13-2013)
Old 09-13-2013, 08:14 PM   #8
Hardrock4445
Yeah, only thing you loose is shift indicator and MPG counters. Which I believe you loose over fuse pull as well. But more power to you for figuring it out. I re read that post and it kind of sounds like it, but I wasn't being an ass. lol
Old 09-24-2013, 02:20 PM   #9
JRP
JRP's Avatar
Just as a follow up on this; I pulled the fuse and it did do a reset and I didn't loose anything like mpg counters, etc. After the fuse pull, the first time I hit the key it didn't even crank, the second time it did. I ended up doing the fuse pull a second time because I did not idle the car for the recommended 5 minutes and the car was running pretty poorly. After the second time all was fine.
Jim
Old 05-15-2014, 04:47 PM   #10
21_nola_05
21_nola_05's Avatar
Drives: 2014 scion FR-S
witch fuse did you pull exacly ? thx
21_nola_05 is offline   Reply With Quote
Old 05-15-2014, 06:26 PM   #11
calibrz
Turbo 86
Drives: GT86
just pull the negative cable, much easier. done it multiple times without any issues.
10 - 1 = 0
real math
calibrz is offline   Reply With Quote
Old 05-16-2014, 05:01 AM   #12
Sphirit
Drives: GT86
any issues with keyless entry sistem?
Sphirit is offline   Reply With Quote
Old 05-16-2014, 09:33 AM   #13
steve99
What is actually achieved by resetiing ecu ?
Other than resetting DTC [cel codes] and a couple of counters like time since dtc reset and distance since dtc reset.
Fuel trims and knock learning parameters appear to be a continuous learning process so i am unsure what you guys reckon you are achieving by resetting the ecu.
As far as i can work out the ecu will learn as far as its parameters and limits allow on its current tune any changes that are made ie difference in fuel or small mods.
Yes resetting the ecu will set these parameters back to the default levels but they would 'learn' anyway, would it learn faster ? the ecu is monitoting parameters and learning all the time it never stops doing so.
watch the ecu learn differences in ethanol content on e85 tunes or it learn new timing when you put in 91 or 87 octane, unlikely resetting ecu will achieve much. It will learn this stuff in seconds.
Old 05-16-2014, 10:33 AM   #14
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
In a word, nothing.
Sellout is offline   Reply With Quote
Reset ECU...? Capstan Scion FR-S / Toyota 86 GT86 General Forum 11 08-29-2021 11:36 PM
TPMS reset charge FRiSson Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 03-09-2014 02:22 PM
Anyone have the nav reset? Gunman Electronics | Audio | NAV | Infotainment 3 08-03-2013 09:26 PM
ECU reset after Break-In paros28 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 02-19-2013 06:41 PM
When do you reset the Avg MPG? WRXcellent BRZ First-Gen (2012+) — General Topics 50 01-16-2013 11:30 PM
