View Poll Results: Would you like variable ratio steering?
like latest Golf GTI thats a Yes 0 0%
No 7 100.00%
Voters: 7. You may not vote on this poll
Old 09-13-2013, 01:51 AM   #1
notout86
Drives: GTS 86 auto
steering turn-in
Compared with our previous car we find the '86 is very different in that it does not turn into angle parking spaces as quickly. Is there anything we can do to quicken the steering progression without messing up the more straight ahead range? I know it sounds pathetic but after six months I still overshoot.
At least I have become adept at handbrake skids
notout86 is offline   Reply With Quote
Old 09-13-2013, 03:23 AM   #2
autobrz
Drives: Mazda 3
You can change the tires and front camber and caster so the front responds faster and follows steering input better.
autobrz is offline   Reply With Quote
Old 09-13-2013, 06:06 AM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I am suggesting it is more of a problem with the operator than the machinery.
Old 09-13-2013, 06:49 AM   #4
Muskokan
Drives: white Sport-tech
I'm not sure I understand, are you saying the turning radius is to long?
Muskokan is offline   Reply With Quote
Old 09-13-2013, 10:55 AM   #5
jhstealth
Drives: 13 FR-s, 84 911
You can drive slower lol. I keed I keed.
jhstealth is offline   Reply With Quote
Old 09-13-2013, 10:59 AM   #6
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
the car has a pretty low steering ratio as it is... what car did you have previously?
Old 09-14-2013, 02:31 AM   #7
notout86
Drives: GTS 86 auto
I agree with you all and you are all correct but I JUST REMEMBERED.
Our previous car was said to have a small degree of passive rear-wheel steering built in. That would also explain the feeling I have always had that the back of the '86 is never coming round like I expect.
FYI the old car was a 1994 Nissan 200SX turbo, rear wheel drive, and at lowish speeds it would glide around a constant radius bend as if it was anchored on the end of a cable.
Old 09-14-2013, 02:45 AM   #8
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
The only way to do it quicker would be to drive faster, but be careful not to oversteer going in. Haha
I have to agree though. Out turn radius isn't that great.
Old 09-14-2013, 03:33 AM   #9
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
If you think the turn radius isn't great in our cars, try owning a Evo 9! Worst turning radius ever. I was embarrassed when trying to do any kind of turn arounds on a street as it would take about 5 lanes to do a u-turn.
stockysnail is offline   Reply With Quote
Old 09-14-2013, 06:26 AM   #10
SortaFlushed
SortaFlushed's Avatar
Drives: Raven Black
Lol i know your struggle.
SortaFlushed is offline   Reply With Quote
Old 09-14-2013, 10:45 AM   #11
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Toe out works much better for this. About half an inch each side should do the trick. The car may wander a bit at highway speeds but parking should be a breeze.
In fact, matching rear toe out should tighten up the whole turning circle and make the handbrake turns more effective.
Suberman is offline   Reply With Quote
Old 09-14-2013, 10:46 AM   #12
Suberman
He's talking about steering rack rate, not ultimate turning circle.
I'm fairly sure he's pulling your leg, also. Australians are known for this.
Old 09-14-2013, 12:23 PM   #13
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Rear toe-out is a VERY tricky thing to set up and use. It can very easily turn into uncontrolled oversteer. Best to leave the rear at 0 toe or a little toe-in.
Old 09-14-2013, 07:27 PM   #14
wbradley
Sarcastic SOB
wbradley's Avatar
At first I thought your old car was a 240SX. Then you might have had Super HICAS, with 1 degree of mechanical turn-in that operates in opposite phase at low speeds to turn sharper for parking. Maybe that's what you need. Passive rear steering like Mazda and others claimed in the 90's is negligible.
DIY: Turn In Concepts Solid Aluminum Steering Rack Bushing Install (and review) Sithspawn DIY (Do-It-Yourself) Guides 38 08-10-2018 11:07 AM
Turn in Concepts (TiC) solid aluminum steering rack bushings review CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 08-14-2017 08:24 PM
Turn in Concepts Steering Rack Bushing review Dave-ROR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 04-26-2015 07:48 AM
Turn In Concepts BRZ/FR-S SCCA LEGAL steering Rack Bushings Turn in Concepts Groupbuys 35 04-29-2013 11:57 PM
"From the first turn of the steering wheel, this car needs to be fun and special" Matador Scion FR-S / Toyota 86 GT86 General Forum 15 12-26-2009 07:54 PM
