Old 02-07-2013, 10:08 AM   #1
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Turn in Concepts Steering Rack Bushing review
Concept:
These TiC SR bushings replace the factory Subaru/Toyota SR bushings and are designed to remove play from the rack's mount. The OEM bushings are soft rubber pressed around a metal sleeve and then pressed into the rack. The problem with the OEM bushings is two-fold: 1) They consist of a VERY SOFT rubber which is grooved providing lots of space for the bushing to move around and 2) The bolts holding the bushings to the subframe are smaller (by ~2mm) than the metal sleeve in the middle of the bushing. The reason for the soft rubber, etc is to reduce NVH. TiC instead uses solid bushings made of Aluminum with rubber o-rings around them and bolts that fit in the bushings perfectly without any play. The pros of a design like this is that you feel more through the steering wheel than you would with the OEM bushings and the car responds quicker to steering input. The cons are an increase in NVH (basically feeling more through the steering wheel).
Pics of the box and parts:
Installation:
Installation DIY by @Sithspawn is located here: http://www.ft86club.com/forums/showthread.php?t=27727
The only things I did differently was that I used a two-jaw puller (swing arm design) as seen below:
Also I just used some dish soap to lubricate the o-rings for installation.
Like Sithspawn, my car does need an alignment after installing the bushings. The reason for this is simply because my steering rack is now centered, it was not centered (going back to the play in the bushing sleeve and the bolt) when the factory put it together.
Installation Note: Make sure that you use anti-seize on the bolts during installation.
So, does it work?
I wanted to make sure I paid special attention to anything that would bother people the most, which is NVH. In this case, there is no NVH increase exactly, but you do feel even more through the wheel which some may conclude is an increase in V and H. In reality it’s just the car communicating that much more clearly to you than it could before. I noticed a difference in road feel especially (as opposed to bumps/etc) and could now feel exactly what the surface conditions of the road are while driving the car. It’s also more instantaneous than it was before. I used to feel details through both the wheel and the chassis at more or less the same time, not it feels like I get feedback from the wheel ever so slightly before I feel it through the chassis. It feels like you have a direct connection to the front tires now instead of the slight isolation that the OEM bushings had and that increase in feel (and how quickly you receive that communication) will be awesome on track. Since the bushing install, I haven’t had the car on track yet (2/23-2/24 I will though) so I will be updating this review after the car sees more track time. In terms of response, there is a slight increase in response but it’s still less responsive than an S2000 for example. That’s not an issue with these bushings, but we will need to address more parts of the car’s steering system to continue to improve its responsiveness for those who desire it. Since the car does respond a little quicker, turn-in is also more immediate as expected. Also, we must remember that these cars are basically new still so give the OEM bushings time to age and the differences will be even more noticeable/obvious than they are now with basically new OEM bushings that everyone currently has. Give these cars a few more years and maybe 60-80k on the odometer and I bet the difference in response would be shocking.
Any issues?
Obviously this isn’t a long term review, but there are no issues that I foresee with these bushings. “Negative NVH” is non-existent IMO but if you don’t want more feel/communication through the steering wheel then these bushings are not for you.
Conclusion:
In summary, I feel the biggest strength of these bushings is the increase in communication/feel that you receive from the front tires. Information is priceless in every area of life and driving shouldn’t be any different IMO. The increase in response is always welcome and I’d love to see what other tricks TiC might have up their sleeve to continue to increase the responsiveness of the FRS/BRZ steering system. I went into this testing process with the thought that I’d want to save my old bushings in case the NVH tradeoffs overpowered the benefit and I’m happy to report that the OEM bushings will NEVER be reinstalled on my car (well unless I’m selling the car maybe ). I love the increase in feel and I don’t want to return to what it was stock (not that it was bad before). There is no question that if I ever build another 86 (like a dedicated FRS track car) these bushings will be one of the first things ordered.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 17 Users Say Thank You to Dave-ROR For This Useful Post:
Acree (02-07-2013), Anthonytpt (10-21-2013), Calum (02-07-2013), cobrabyte (02-07-2013), CounterSpace Garage (02-07-2013), CSG Mike (02-07-2013), DriftEightSix (07-16-2013), Mikepage (11-12-2013), MikesFRS (04-19-2014), normancw (02-13-2014), OrbitalEllipses (02-07-2013), Ornelas66 (04-26-2015), Sithspawn (02-14-2013), Spaceywilly (02-07-2013), track_warrior (02-07-2013), tripjammer (02-07-2013), Turn in Concepts (02-07-2013)
Old 02-07-2013, 05:47 PM   #2
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Great post. I'm glad I'm already on the group buy.
-Acree
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 07-15-2013, 06:39 PM   #3
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Wow no posts at all after... Dave do you have any update?
TouchMyHonda is offline   Reply With Quote
Old 07-15-2013, 08:06 PM   #4
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'm not Dave, but I've had mine installed for a while and they feel great. NVH is up a touch, but it's more information then anything. It's certainly well worth the money and time to install.
The Following User Says Thank You to Calum For This Useful Post:
Turn in Concepts (07-16-2013)
Old 07-16-2013, 08:28 AM   #5
vgi
Drives: frs
i had mine installed recently, agree with the posters above.
vgi is offline   Reply With Quote
The Following User Says Thank You to vgi For This Useful Post:
Old 07-16-2013, 10:02 AM   #6
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Very good review!!! I was looking at the whieline bushing but I think you've convinced me. Reason I wasn't convinced before was the extra noise from. The would bushing but as you say its not there and it adds great benifot thanks!!
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 07-16-2013, 01:03 PM   #7
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
would you suspect the derlin bushings to yield drastically different results? Im wanting to stay within stx rules and limitations
supramkivtt2jz is offline   Reply With Quote
Old 07-16-2013, 03:04 PM   #8
Turn in Concepts
Turn in Concepts's Avatar
No, actually you can not tell the difference between the two. The delrin is SOLID just like the aluminum, you get the same steering response the same feeling it just happens to be class legal for STX!
Turn in Concepts is offline   Reply With Quote
The Following 2 Users Say Thank You to Turn in Concepts For This Useful Post:
mokinbird87 (07-10-2014), supramkivtt2jz (07-16-2013)
Old 07-16-2013, 03:23 PM   #9
bakerr6
Drives: 2013 raven black fr-s
I'm still waiting to install mine until I have all my suspension pieces in. I figure I might as well hit everything in the same day haha.
Greg knows which parts I'm waiting on
bakerr6 is offline   Reply With Quote
Old 02-13-2014, 10:40 PM   #10
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
By the way, I am still using these with no ill effects. I still like them!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
normancw (02-13-2014), wparsons (09-17-2014)
Old 04-19-2014, 05:28 PM   #11
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Looks like the aluminum bushing is no longer offered? Just the delrin one now? I'm sure it feels just the same, but is there any change in NVH?
unsurety is offline   Reply With Quote
Old 04-19-2014, 06:09 PM   #12
Calum
That Guy
I could barely feel an increase in NVH going from stock to aluminum. The only difference I felt was an increase in information an a mild increase in turn in.
Old 04-21-2014, 01:38 AM   #13
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Yeah I keep waiting to see the aluminum ones pop back up...
Old 09-14-2014, 01:45 PM   #14
Weasel Soup
Veteran RallyCrosser
Weasel Soup's Avatar
Drives: 10 Series FR-S, 95 Escort Rally Car
I ordered one of these kits last week. I ordered the delrin but recieved the aluminum. No big deal for me, but others might want to be aware since I ordered direct from the TiC website, which said they had a stock of 5 at the time and now it shows 4. Also, it was much easier for me to do the install after disconnecting the steering rack from the coupler and the disconnecting the tie rod ends from the steering knuckles.
Everything should be attempted twice. Once to satisfy curiosity, and the second time to see if you like it.
My Journal
2016 SCCA RallyCross National Champion - Prepared Rear Wheel Drive
Weasel Soup is offline   Reply With Quote
tic, turn in concepts
DIY: Turn In Concepts Solid Aluminum Steering Rack Bushing Install (and review) Sithspawn DIY (Do-It-Yourself) Guides 38 08-10-2018 11:07 AM
Turn in Concepts (TiC) solid aluminum steering rack bushings review CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 08-14-2017 08:24 PM
GROUP BUY - TiC BRZ/FR-S steering rack bushings Turn in Concepts Groupbuys 186 03-19-2013 08:04 AM
Whiteline transmission bushing and Perrin shifter bushing review. Superhatch Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-09-2012 08:40 PM
"From the first turn of the steering wheel, this car needs to be fun and special" Matador Scion FR-S / Toyota 86 GT86 General Forum 15 12-26-2009 07:54 PM
