OEDC
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Radar dector mounting
So I ran some permanent cabling for my radar dector place up on the passenger side of the rear view window, and with alot of siliva I got the suction cups to mount onto the black checkerboard piece of the windshield.
After about 3 months of it falling off once a week and reapplying it with silva I filled the suction cups up with krazy glue and it worked like a charm. Which brings us to today, had a cold snap last night (turned on my TMPS sensors since I don't have nitrogen in them ATM) and it popped off my radar dector, so I'm looking for a way to mount it to the windshield that will withstand a cold snap, anyone have any ideas? Or have suffered thru this and came up with something that works? Thanks.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there. please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback |
OEDC
@Sportsguy83 @king_tut @sti448hp
My BRZ FI Build
Hail Magnet
You need to stick it to the plain glass, not the honeycomb-type stuff up higher--its not a flat enough surface to keep it on there (hence why it kept falling off). My detector has yet to fall off, and its been mounted since the early spring.
Also, the reason a cold snap made it fall off was because you glued it. Cold has always made my suction cups stick better, in my experience. |
#4 | |
OEDC
My BRZ FI Build
#5 | |
Hail Magnet
EDIT: Actually, the only places they are illegal in passenger cars are Virginia and DC (and on military bases) [ame="http://askville.amazon.com/states-radar-detectors-legally-allowed/AnswerViewer.do?requestId=889372"]LINK: Where are Radar Detectors Illegal?[/ame] |
OEDC
I go to Virginia alot.
My BRZ FI Build
Hail Magnet
Fair enough...but they have radar detector "detectors" that they use, so if they catch you with the detector, it doesn't matter where you put it.
blowhard
Drives: frs, project forester
Just picked up a v1 to replace my aging rx65.
The visor clip seems to keep the detector in a much better location for not being apparent outside the vehicle. |
Drives: 2013 Scion FRS
Dependant on your radar detector go onto ebay or amazon and get a bracket that mounts it to your rear view mirror. Then it is perfectly centered in your car and it hangs down so it can read front and back without any obstructions in the way like a lower roof line in the rear or windshield wipers in the front.
You can see where mine mounts in the pic below.
#10 | |
OEDC
So as long as you buy a good detector, it matters 100% where you put it.
My BRZ FI Build
#11 |
OEDC
My BRZ FI Build
#12 |
#13 |
blowhard
It was stated.
He drives through va, where the detectors are illegal. Don't matter if its one of the "undetectable" ones if its sitting in the windshield. Havent had it long enough to tell if it affects sensitivity, let alone changing models, so i cant speak for any sort of comparison on effectiveness. But I really like the visor spot so far. A) i'm too tall to use my visors b) the car is so low only a midget or crouched person could see the detector. |
#14 | |
I Love custom Turbo kits
Drives: Limited BRZ
![]() I have it mounted like @FR-Shadow with a bracket to the rearview mirror I summon @xjohnx I believe he did a stealthy install.
| Tags |
| radar dector mounting |
| Mounting a radar detector | Bg8780 | Cosmetic Modification (Interior/Exterior/Lighting) | 24 | 02-06-2014 12:39 PM |
| Mounting HID Ballasts? | mmieszanek | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 03-27-2013 04:41 PM |
| Next mod: Radar dector | jwbrocloud | Scion FR-S / Toyota 86 GT86 General Forum | 39 | 01-27-2013 01:04 PM |
| Mounting radar detector video | ayau | BRZ Photos, Videos, Wallpapers, Gallery Forum | 10 | 06-07-2012 11:29 AM |
| where are you mounting your plates??? | poormans_LFA | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 01-31-2012 04:41 AM |
