Old 09-09-2013, 12:18 AM   #1
Dsmith1992
10 Series Colorado
Drives: Scion FR-S 10 Series
add RCA adapters for the 10 series frs and 2014 frs
I think i just found a solution for us owners of the 10 series frs, and 2014 frs. since the 6.1" touchscreens do not have RCA outputs and are pioneer units, pioneer makes a device that makes it so that lets you add em, and it connects directly into back of head unit.
http://www.radioshack.com/product/in...tent=CT2032325
Dsmith1992 is offline   Reply With Quote
Old 09-09-2013, 02:00 AM   #2
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
the site says they are RCA auxiliary inputs, not outputs.
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
Old 09-09-2013, 09:51 AM   #3
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
either way, an input is actually what u want. and if this was designed anything lik the 2013 bespoke then good luck. on 13 all RCA is thru iphone only (the only problem i have)
lbroskee is offline   Reply With Quote
Old 09-09-2013, 05:54 PM   #4
Dsmith1992
10 Series Colorado
i just want to add an amp so i can put in one or two type-r 10" subs. cause 12 or 1400 for OEM audio 400+ system when i can just do it all myself for 600 tops, I have added a 2female 1male Aux cord adapter and had one run to the amp and the other for the phone audio, only downside is that the phone is the only way to control the bass output
Old 09-16-2013, 01:15 AM   #5
M_Dubbs
Drives: My lil bro has a white BRZ limited
That product creates an aux input to any pioneer head unit with a "P" in the model number. It uses the ip-bus input to allow auxillary devices to be used. For example, my old radio I got seven or so years ago had an ip-bus input that allowed satellite radio, ipod adaptor, cd changer, and a few other things. I got an Android phone for a short period of time and was unable to use the audio from this source through my stereo. I was able to use Peripheral's version of that (available at stores to this day) to create an auxillary input to allow anything with a headphone jack to play through my car stereo. A line out converter or an amp with high-level inputs will be the solution you are looking for. Feel free to message me as I am in Colorado too (Aurora) and I can help point you in the direction that will work best for you. That being said, both FRSs I've had the radios out of had RCA outputs that can be turned on the menu of the radio when turned off which will output an adjustable subwoofer signal. This adjustment will come up in the menu where Bass and Treble are.
M_Dubbs is offline   Reply With Quote
Old 09-16-2013, 09:03 AM   #6
PITTFRS
Drives: 2013 FR-S Hot Lava
this is an input, not a preamp out for an amp. However, there are converters out there that wire into the speaker wires you can use for a sub with a stock radio with preamp outs.
Originally Posted by Gaiakai View Post
If you're not driving like your car runs on the blood of virgins, you're doing it wrong.
PITTFRS is offline   Reply With Quote
Old 09-16-2013, 12:19 PM   #7
Dsmith1992
10 Series Colorado
ya i figured that out after i posted it, you dont have to post its description i already read it several times
Old 09-16-2013, 12:50 PM   #8
mid_life_crisis
Drives: FR-S 10 #103 AT
Don't forget that there are active crossovers that will take a high level input. There are also some decent amps that will do the same thing. There is a thread dedicated to how to tap the leads to the factory amp. The signal being supplied to the amp is full range, supposedly. You can split that as you see fit and if you want to take the time to make up a harness, you can do it without cutting the wires.
Old 11-07-2013, 09:21 PM   #9
madpcsupreme
Drives: 95 accord
has any1 figured out which ones are the (sub) pre-out for the 2014 HU yet?
madpcsupreme is offline   Reply With Quote
Old 12-21-2013, 06:40 PM   #10
Dsmith1992
10 Series Colorado
There are now sub pre amps on the 14 HU i am tapping into the amp in the trunk using positaps and a rockford rfi2sw cable its a high level to rca
Sent from my XT910 using Tapatalk 2
Old 12-21-2013, 08:18 PM   #11
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Really?! I was going to do the metra harness repin but that may not be necessary then. Can you post a picture of the back of the head unit? How would you control the subwoofer output? Through the amp I'm guessing unless there's a menu I'm unaware of.
the new guy is offline   Reply With Quote
Old 12-28-2013, 03:55 PM   #12
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
I don't think this is true
gatorbushmen is offline   Reply With Quote
Old 01-03-2014, 11:34 PM   #13
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
@Dsmith1992 So is your setup working and can you give us a trip report on how to tap off of the stock amp? I have a powered subwoofer I just picked up that comes with low level RCA or high level inputs, wondering which I should use.
oldpueblo is offline   Reply With Quote
Old 01-05-2014, 01:08 AM   #14
lightdir
Drives: 2013 Raven FRS 6MT
you will need something like this.
http://www.audiocontrol.com/t34/1761...-AccuBASS.html
lightdir is offline   Reply With Quote
Frs 10 series or 2014 ultramarine Frs Stzheng716 Scion FR-S / Toyota 86 GT86 General Forum 42 10-24-2013 02:40 AM
adapters Chen Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 01-10-2013 11:16 AM
Adapters. Chen Northwest 5 01-10-2013 12:11 AM
Edmunds 2014 Coolest Cars 2014 FR-S Convertible Wizneber Scion FR-S / Toyota 86 GT86 General Forum 21 07-26-2012 08:51 PM
Single din adapters? -max- Electronics | Audio | NAV | Infotainment 7 07-18-2012 03:30 PM
