Northwest AK, ID, OR, WA
Old 01-09-2013, 04:08 AM   #1
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Adapters.
Because I'm not patient enough to hear what the wheel/tire/hub forum section of the forum says. Ill post to my fellow NW owners. So to sum it up. I'm interested in a set of bbs that came off an evo 8 MR, doing the research. The bolt pattern is different. So I started looking at adapters. After I figured they do exist and I know I could make it go on the 86. I'm curious if anybody had any experiences with adapters in the past. I understand how they work. But are they track friendly? Reliable? Thanks in advance!
Chen is offline   Reply With Quote
Old 01-09-2013, 04:51 AM   #2
NickFRS
Drives: 2013 Asphalt FRS
I had some adapters for a pair of STi wheels on a old WRX. 5x100 to 5x114. They basically act as a spacer as well.... but they are really spendy and not really worth it. Hard to resale also.
http://www.iwsti.com/forums/subaru-b...heels-brz.html
NickFRS is offline   Reply With Quote
Old 01-09-2013, 12:19 PM   #3
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Spacers may effect handling from what I've heard over the years. I would avoid using them and just sell/trade your wheels and get a set that does fit.
stockysnail is offline   Reply With Quote
Old 01-09-2013, 02:05 PM   #4
Chen
Regional Moderator
Chen's Avatar
Holy crap. Your right. Like 60-100 for a decent set
Noted. Less work in the future.
Old 01-09-2013, 06:37 PM   #5
NickFRS
I have 10mm spacers in the rear. Tech with the 8in wide rim i'm running and the offset the inside contact patch nearly identical to stock if you do the math. The tires just come out by the fenders. Then camber lots because of my low. It really depends on the wheels+spacers. I would never run more then a 10 though. At that point get new wheels... and i'm only running a spacer in the rear because I didn't want a different looking wheel in the rear of my car due to width n offset + that means more weight for the car to turn + wouldnt look as good... + the rear end of our car has more wide then the front. So Justifying a spacer in the rear is easy. But like I said anything over 10 is overkill and if I see someone using front spacers i'm going to face palm.... Get different wheels!
Old 01-10-2013, 12:11 AM   #6
Chen
Regional Moderator
Chen's Avatar
Lol but what about adapters! I'm looking to see if anybody has used them in the past!
adapters Chen Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 01-10-2013 11:16 AM
Subaru Audio door speaker adapters JoeBoxer Audio/Visual, Electronics, Infotainment, NAV 0 12-16-2012 11:13 PM
FS: 3/4" PVC Speaker Spacers/Adapters for the BRZ/FR-S phenryiv1 Audio/Visual, Electronics, Infotainment, NAV 1 08-22-2012 05:03 PM
Single din adapters? -max- Electronics | Audio | NAV | Infotainment 7 07-18-2012 03:30 PM
