Old 09-05-2013, 09:38 PM   #1
ZackZ
Drives: '13 Scion FR-S Black 6sp man
Clutch Adjustment Concern
I just adjusted the clutch pedal so it sits slightly above the brake pedal. If i would adjust it any further the clutch would make a rattling sound when i let my foot off the clutch also when in neutral and rolling if i stepped on the brakes i would also hear a small rattling sound. My present adjustment doesnt make any sounds but i do notice some slight clanking after i shift especially from 1st to 2nd. Not sure if its just in my mind. Today i also noticed there were drip spots on my driveway of hydraulic fluid. Do you think the slave cylinder or clutch master cylinder seals were messed up after the adjustment. Im very concerned and i hope this simple adjustment did not ruin my clutch system. If it is, this car is a lease so how should I deal with the situation.
ZackZ is offline   Reply With Quote
Old 09-06-2013, 03:01 PM   #2
ZackZ
Anyone??
Old 09-06-2013, 03:11 PM   #3
MrMista
Drives: 2013 BRZ, Satin White Pearl, MT
Maybe you accidentally adjusted it to the point where it was slightly engaged while you were driving.
MrMista is offline   Reply With Quote
The Following User Says Thank You to MrMista For This Useful Post:
whitefrs (09-06-2013)
Old 09-06-2013, 03:32 PM   #4
DarkSunrise
DarkSunrise's Avatar
Are you saying your engagement point is set slightly above your brake pedal? That's where mine is and it's fine, no issues.
2022 BRZ Build
2013 FR-S Build
Old 09-06-2013, 03:42 PM   #5
Steve201brz
IMO, i would undo and adjustments you made and take it to the dealer. don't admit to making any adjustments of your own, i've seen dealers (not necessarily yours) try and put the fault on the owner. maybe tell them you're noticing fluid on the driveway, or that it doesnt shift like it did when you drove it off the lot. just my .02, sorry i couldn't be more useful
Steve201brz is offline   Reply With Quote
The Following User Says Thank You to Steve201brz For This Useful Post:
ZackZ (09-06-2013)
Old 09-06-2013, 03:52 PM   #6
ZackZ
Yeah its a couple mm above the brake pedal because anything lower would not feel right so i dont know how some people have it below the brake pedal. Could that small of an adjustment really mess up anything?
Old 09-06-2013, 03:53 PM   #7
ZackZ
What is that point because i only lowered it very little.
Old 09-06-2013, 04:47 PM   #8
DarkSunrise
Yeah it shouldn't. I've had mine adjusted that way for a while and no issues. Do you have a hard time shifting into 1st or R with the clutch fully depressed?
2022 BRZ Build
2013 FR-S Build
Old 09-06-2013, 05:51 PM   #9
ZackZ
It feels a little notchy when i first put it into those gears but if i bring it back to neutral and put it back into gear its fine.
Old 09-06-2013, 05:55 PM   #10
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Probably in your head. Adjusting the pedal will NOT affect the hydraulic system, you are adjusting the pedal, not the "engagement" point of the clutch itself (The pressure plate will hold it just as strong as before). The noise was probably there before and you are just taking too much notice of it, it's a very noisy clutch, I had like 8-10 speed bumps to get to my appartment and it was click and clacking whenever I tried to modulate the clutch.
If you lower the pedal too much you won't be able to release the clutch completely, and you'll know it you'll grind every gear and won't be able to put it in reverse at all.
Rayme is offline   Reply With Quote
The Following User Says Thank You to Rayme For This Useful Post:
ZackZ (09-06-2013)
Old 09-06-2013, 06:54 PM   #11
ZackZ
I appreciate it you really eased my mind. :happy0180:
Old 09-06-2013, 07:31 PM   #12
ZackZ
Oh i also hear a clicking noise when i let out the clutch in neutral near the catch point.
Old 09-06-2013, 07:37 PM   #13
ZackZ
Could that noise be the gear indicator and cruise control switch? It does not make the noise when the car is off
Old 09-07-2013, 01:28 AM   #14
unlimited86
Drives: s2000
For some reason after changing the clutch back to close to stock position, it feels a little less notchy and I don't really feel much of that 3rd gear grind. I'm starting to wonder if the clutch adjustment affected all those grinds that people are experiencing.
unlimited86 is offline   Reply With Quote
Clutch Adjustment Issues!! FT-86- Scion FR-S / Toyota 86 GT86 General Forum 39 05-28-2015 09:29 PM
Clutch Pedal Adjustment? EAGLE5 Northern California 41 05-20-2015 01:10 AM
Quick Question when doing clutch Adjustment Number 6 BRZ First-Gen (2012+) — General Topics 3 03-13-2013 11:18 PM
Quick Question when doing Clutch Adjustment Number 6 Scion FR-S / Toyota 86 GT86 General Forum 2 03-09-2013 04:31 PM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 05:01 PM
