Drives: '13 SSM BRZ Limited 6MT
LED bulb upgrades not working :/
I bought a whole set from a vendor here and have only gotten the dome lighting to work. door, vanity, license plate and reverse aren't working though. should just be plug and play right?
i've only plugged in the driver's side for the lights that aren't working above (to compare to stock), but i have the vanity bulbs both sides in. could it be that i need both sides installed for them to work? i won't be able to try this until tomorrow morning though. |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Try flipping the LED's the other way around... Could be a polarity thing; unless you have CANBUS LEDs...
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
| The Following 2 Users Say Thank You to DaJo For This Useful Post: | Tim_Asphalt_FRS (09-04-2013), tracerit (09-04-2013) |
Drives: Silver AT Limited
^ that - flipping the bulbs usually fixes it
| The Following User Says Thank You to mechaghost For This Useful Post: | tracerit (09-04-2013) |
Drives: Scion FR-S Asphalt
There are small, metal pins on the bulbs. If they aren't making proper contact with the copper strips in the sockets, they will not light up. Usually, flipping the bulb 180 degrees will fix the issue (sometimes when you insert, it's backwards since there is a polarity to the bulbs.) Also, moving the metal pins out towards the edge of the base of the bulb usually helps too. It's really all just about making sure that proper electrical contact is made. It's highly unlikely that all of the bulbs you received from whatever vendor you purchased them from are DOA, but if the above mentioned advice fails, it could be the case.
In any regard, if you are looking for anymore LED lighting or are unhappy with what you purchased, we offer some really great LED options at affordable pricing. We've been a vendor on here for almost a year now, and have the feedback from the community to back it up. We also have a great looking website that you can check out all of the products and options we offer! www.ViciousLED.com We hope that this advice helps you out! Cheers
| The Following User Says Thank You to Vicious LED For This Useful Post: | tracerit (09-04-2013) |
That sounds like it could be it. I'll try it bout tomorrow
FT86Club Vancouver
Cheers and good luck! :happy0180: I'm quite certain this is the case.
couldn't sleep without confirming it the solution is that easy but turns out flipping it around worked! now i can sleep easily
| BRZ HID Bulb Swap | JPxM0Dz | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 01-24-2014 09:06 PM |
| HID BULB FLICKERING HELP!! | ijuliusx | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 05-24-2013 03:18 AM |
| BRZ HID Bulb + HID Fogs | delusional | DIY (Do-It-Yourself) Guides | 4 | 02-05-2013 05:09 AM |
| bulb size for frs | brichard0625 | Exterior Parts - The Rest | 4 | 07-23-2012 03:33 PM |
| BRZ D4S bulb ? | MRZ415 | BRZ First-Gen (2012+) — General Topics | 82 | 06-28-2012 07:18 PM |
