Old 09-03-2013, 06:13 PM   #1
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
Mach V Motorsports differential cover
We started working on our own milled aluminum, CNC-machined diff cover more than a year ago. It's been a good bit of work, but it's finally here, and ready for the public.
It's machined from a single very large chunk of aluminum. We designed in extra fins that hang down from the cover to catch some actual airflow. There are two holes for installation of an external diff cooler (not included), and one hole for a diff temp sensor probe.
The cover holds about 50% more fluid than the stock one.
I'm not sure if I'm allowed to talk about pricing in this forum; I'll have another post over in the Vendor Classifieds. The diff covers are in stock, and you can buy one today, HERE.
We figure people who would be most interested in this will be high-powered cars that run at the track, whether it's road race, drift, or hill-climb. I know some of the Japanese race teams had some trouble with overheating the rear diff early on.
More pics...
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
Old 09-03-2013, 06:22 PM   #2
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
That is one SeriousBusiness diff cover. Beautiful!
Nightbringer is offline   Reply With Quote
Old 09-03-2013, 08:17 PM   #3
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
How do you jack up the rear of the car with this?
Old 09-03-2013, 08:32 PM   #4
White64Goat
Very Carefully I'd assume.................
Old 09-03-2013, 08:52 PM   #5
Mach V Dan
You could just jack on the diff casing forward of the cover. Or just use the factory pinch weld jack point below the door sill.
--Dan
Mach V
Old 09-03-2013, 09:36 PM   #6
Draco-REX
Corner Junkie
Draco-REX's Avatar
Two hockey pucks then.
Old 09-03-2013, 09:38 PM   #7
37
degrees
37's Avatar
Drives: 6MT BRZ
Looks great! Bead blast and hardcoat anodize it black.
37 is offline   Reply With Quote
Old 09-03-2013, 09:38 PM   #8
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
So does this strengthen the differential?
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 09-03-2013, 10:11 PM   #9
Mach V Dan
Well...the differential case is thick and heavy cast steel. I'm not sure it's going to care what kind of aluminum cover it has. I'd guess our cover is stronger/stiffer than the stock cover, for what it's worth. As for the differential itself, inside the case? No effect on its strength.
--Dan
Mach V
Old 09-03-2013, 10:14 PM   #10
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
custom colors available?
86_ZN6 is offline   Reply With Quote
Old 09-03-2013, 10:45 PM   #11
FirestormFRS
Very nice work on that. Tooling cost must be pretty high to CNC that much out of a billet.
FirestormFRS is offline   Reply With Quote
Old 09-03-2013, 11:07 PM   #12
Mach V Dan
Sorry, not at this time.
Yes.
--Dan
Mach V
Old 09-04-2013, 02:37 AM   #13
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Looks crazy sick!
Old 09-04-2013, 12:43 PM   #14
Mach V Dan
More pics added.
--Dan
Mach V
diff cover, differential cover, mach v, mach v diff cover
Differential adjustment Dipstik-sportech Engine, Exhaust, Transmission 7 07-22-2013 11:16 AM
The cover store car cover for sale. FRSfan111 Northwest 2 06-21-2013 04:49 PM
Eww rear differential goo LeeMaster Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 04-10-2013 09:17 PM
What Differential fluid is in your BRZ/FRS? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-12-2012 08:57 PM
Get your Cusco Differential Cover from Kronos! KronosPerformance Transmission and Driveline 5 07-04-2012 09:33 PM
