Old 08-30-2013, 11:41 PM   #1
Pele86
Pele86's Avatar
Drives: Firestorm fr-s
Most ridiculous response from the dealership.
So my tire pressure light came on the other day and i took it to the dealership to have them fix it since it was nearby. Well turns out my tire had a nail in it and they told me it was "repairable" but that it would be better for me to take it to those "mom and pop shops" as he stated to fix it because they'll put a plug while the dealership only puts a patch. Thats fine I can do that if they cant just patch it up which is what the "mom and pop" shop did anyways i dont want them touching my car. Also after all that as i was walking back out to my car a service advisor was out there and i asked him arent tires under warranty? His response was "no anything that is wear and tear on the car is not under warranty. If you want a warranty on a tire you'd have to purchase a tire with a warranty."
So what i got out of that is those "mom and pop" shops can do a better job than an actual dealership, the whole car isnt under warranty because the whole car is wear and tear, and my tires were free when i first purchased the vehicle which i doubt i know i paid every penny for those tires when i bought the car with all the warranties possible.
Anyone ever get stupid responses like this?
Pele86 is offline   Reply With Quote
Old 08-30-2013, 11:50 PM   #2
FRS1010
Drives: 2013 FRS
Usually have to purchase a road hazard warranty to cover the rims and tires for punctures such as a nail.
FRS1010 is offline   Reply With Quote
Old 08-30-2013, 11:56 PM   #3
n0m0h0s
n0m0h0s's Avatar
Drives: #2148 frs 10 series
Send a message via AIM to n0m0h0s
Im a lube tech for toyota. So I can maybe come up with reasons why they would say that. The whole plug patch thing is weird because as far as I know its the law for dealerships (at least for my area) to use the patch with the plug on it. On top of that dealerships have high standards for what is repairable or not. I inspect and decide that really. Those service advisors were maybe being nice to you and were being legit with you by having the "mom and pop" do it since it wouldnt have been "legally" repairable under our local law but still technically be repaired. My dealership would have tried and sell you a new tire and not send u to another shop (bad business practice). And yes warrenty doesn't cover wear and tear part unless they were defective. A nail in a tire is not a defect. Its just bad luck.
n0m0h0s is offline   Reply With Quote
Old 08-31-2013, 12:08 AM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I really think you should go read all the documentation that came with the car before you jump to a conclusion.
In there, there's a small book called "Original Equipment Passenger & Light Truck Tire Owner's Manual & Limited Warranty"
In there, on page 4, is a "What is not covered" section which states that a puncture is not covered.
While the technician is correct in what he stated, it's a bit misleading. Your tires still have warranty, but the warranty only applies to defect under normal driving conditions and with regular maintenance. Your puncture isn't covered under the basic tire warranty, and his response (if only directed at the puncture incident) is 100% correct.
Long story short, read the manual. A lot of things are "wear and tear" but that's not what the point of warranty is, and that's not how you should be viewing/judging warranty coverage for your car.
-alex
Old 08-31-2013, 12:30 AM   #5
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
yeah I added $4/mo to my lease payments for rim and tire hazard insurance
Old 08-31-2013, 12:49 AM   #6
userjack6880
userjack6880's Avatar
Drives: Raven FR-S MT
Same here. I do enough road trips and live in pothole city. $4/mo is a small price to pay after having several shredded tires and bent rims on previous vehicles.
2013 Scion FR-S - Build Thread
2015 Ford Mustang GT
1978 Triumph Spitfire 1500
userjack6880 is offline   Reply With Quote
Old 08-31-2013, 07:52 AM   #7
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
You really thought the tires had a warranty on them for a nail? Is this your first new car?
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 08-31-2013, 09:07 AM   #8
FirestormFRS
Running over a nail would not be a warranty repair. Tires are on a separate warranty from the tire manufacturer. The dealership was actually pretty honest with you, they could have fixed the tire and charged you normal repair rates.
Be thankful they didn't take advantage of you based on your lack of understanding of how warranties work they could have ripped you.
FirestormFRS is offline   Reply With Quote
Old 08-31-2013, 09:09 AM   #9
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Legally, I believe they have to patch a radial tire with a patch from the inside, requiring the tire be removed from the car and unmounted from the rim. Probably didn't want to be bothered doing the labor or charging you what it would have cost. Mom & Pop places often use a plug and goop from the outside while the tire is still mounted and on the car. I've had both done and never noticed much difference. I wouldn't recommend using a patched / plugged tire at the track however.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 08-31-2013, 09:12 AM   #10
ZionsWrath
Thanks
ZionsWrath's Avatar
Is this your first car? The dealer should have said consumables are not under warranty, as in items that will ALWAYS wear out and can wear out A LOT faster depending on proper/improper/hard use.
Then there are things like a clutch that shouldn't wear out fast but if it does they will look at it and if they see it was "abused" they will not warranty it. Same with your engine and "the whole car".
Old 08-31-2013, 09:25 AM   #11
BRZnut
Drives: BRZ DGM Limited
Tire damage not covered by standard new car warrantee. Tire repairs and purchases are much more expensive at the dealership. Go somewhere else.
Old 08-31-2013, 05:22 PM   #12
Turbowned
Turbowned's Avatar
Your tires are not warrantied against road hazards unless you purchases a tire/wheel protection plan. They are only warrantied against manufacturer defect. Wear items and adjustments are covered, however (clutch lining, brake pads, wiper blades).
Old 08-31-2013, 08:45 PM   #13
fa5tco
fa5tco's Avatar
Drives: 2013 Firestorm FRS
If you buy your tires from Discount Tire you can buy "certification," or as they call it "certs," and it would cover the replacement of the tire if theres a nail. No manufacturers warranty is going to cover your tires, breaks, clutch, because those are wear items.
fa5tco is offline   Reply With Quote
Old 08-31-2013, 08:58 PM   #14
fistpoint
Drives: Supercharged Golf Cart
Most tire shops do tire repairs for free.
fistpoint is offline   Reply With Quote
Throttle Response CamryDS Northern California 27 03-31-2015 03:35 AM
NY/NJ/CT/PA - Local Group Buy RIDICULOUS PRICE on the FA20CLUB Stage 1 Turbo Kit!!! 468Power NY / NJ / CT / PA 119 12-09-2013 01:25 PM
Okay, am I just being ridiculous? (Cracked window weatherstripping) suaveflooder Issues | Warranty | Recalls / TSB 10 03-12-2013 04:17 AM
How's the throttle response? SFTiofoso Scion FR-S / Toyota 86 GT86 General Forum 9 08-14-2012 11:50 AM
