Drives: FRS, IS300, 911sc
silencer on muffler delete pipe
Ok, this is a very weird question, but probably a question from everyone with a race pipe muffler delete.
All race pipe muffler delete are LOUD. it's so loud that it violates my local autox 92db limit. I still want to run it because it saves lots like 20lb easily. I wanted to add a silencer on it. but seems like silencers are made for exhaust tips with 3.5" to 4" diameter only. The race pipe is only 2.5". Suggestions? |
#2 | |
Boosted
Drives: Not a supra....yet
you could look into building something similar edit: like this thing http://www.vividracing.com/catalog/i...c2catback1.jpg
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Supertrapp.
The other option depends on how close you are to the limit. Using a turn down tip will reduce the recorded decibels as well. But only so much. A supertrapp will let you adjust the flow and volume by increments to just sneak under the limit. |
Depending how much you're over the limit, it might hurt you worse to run a silencer. They'll choke down the flow a lot.
#5 | |
Drives: 2013 Black FR-S
I went through the process of trying to find silencers and stuff. I even installed the APEXI ECV which didn't really work because you restrict flow so much you can't accelerate and you risk melting your valves etc. It didn't even quiet the sound by much. I was like you at first. So stoked to drop weight! After months of driving it I couldn't stand it anymore and installed two mufflers in the rear to quiet it down. I am so relieved now and enjoy driving my car again. Good luck.
at stock weight 20 lbs is only worth the eqivalent of about 1.5hp so if you loose more than 1.5hp to save those 20 lbs you may hurt more than you help.
Easier ways to loose 20lbs. But, there are a few single exit catbacks that save more than 20lbs and claim to stay under 93db.. have a look at the tanabe for example on ft86speedfactory.com..
~Namaste~ |
#7 | |
Drives: 2013 Raven FRS
Lose, not loose.
Boosted
Drives: 2013 FR-S, 2012 MCS
I've heard the single exit deletes are quite modest under 4k rpm and sound great throughout. Is there something I'm missing here? Dual deletes with other exhaust mods are when it becomes unbearable right?
#10 |
I used to sit next to a guy that corrected everyone's grammar and spelling at work, now he sits on the other side of the building because no one can stand to be near him... true story.
~Namaste~ |
| silencer on muffler delete pipe | Turbo Den | Engine, Exhaust, Transmission | 1 | 08-27-2013 09:57 AM |
| Berk track pipe with tip/muffler delete. | Stealthx | Engine, Exhaust, Bolt-Ons | 6 | 07-24-2013 09:26 PM |
| FS (BC): BERK technology muffler delete pipe | stanm | Canada Classifieds | 16 | 01-03-2013 11:32 AM |
| Mach V BRZ / FR-S Muffler Delete Pipe REVIEW | Turn in Concepts | Engine, Exhaust, Transmission | 1 | 10-16-2012 11:15 AM |
| X-Pipe with Muffler delete | dav0777x | Engine, Exhaust, Transmission | 3 | 06-21-2012 10:30 AM |
