Old 08-26-2013, 07:29 PM   #1
Turbo Den
Drives: FRS, IS300, 911sc
silencer on muffler delete pipe
Ok, this is a very weird question, but probably a question from everyone with a race pipe muffler delete.
All race pipe muffler delete are LOUD. it's so loud that it violates my local autox 92db limit. I still want to run it because it saves lots like 20lb easily.
I wanted to add a silencer on it. but seems like silencers are made for exhaust tips with 3.5" to 4" diameter only. The race pipe is only 2.5".
Suggestions?
Turbo Den is offline   Reply With Quote
Old 08-26-2013, 07:48 PM   #2
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Suggestions?
my buddy club spec 2 pipe comes with a slip on type muffler that slides into a 2.5"
you could look into building something similar
edit: like this thing http://www.vividracing.com/catalog/i...c2catback1.jpg
Old 08-26-2013, 07:56 PM   #3
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Supertrapp.
The other option depends on how close you are to the limit. Using a turn down tip will reduce the recorded decibels as well. But only so much.
A supertrapp will let you adjust the flow and volume by increments to just sneak under the limit.
Old 08-27-2013, 09:59 AM   #4
wparsons
wparsons's Avatar
Depending how much you're over the limit, it might hurt you worse to run a silencer. They'll choke down the flow a lot.
flickr
Old 08-27-2013, 01:51 PM   #5
sw20kosh
Drives: 2013 Black FR-S
Suggestions?
The tip silencers posted above might work a a tad.
I went through the process of trying to find silencers and stuff. I even installed the APEXI ECV which didn't really work because you restrict flow so much you can't accelerate and you risk melting your valves etc. It didn't even quiet the sound by much.
I was like you at first. So stoked to drop weight! After months of driving it I couldn't stand it anymore and installed two mufflers in the rear to quiet it down. I am so relieved now and enjoy driving my car again.
Good luck.
Old 08-27-2013, 02:57 PM   #6
mad_sb
at stock weight 20 lbs is only worth the eqivalent of about 1.5hp so if you loose more than 1.5hp to save those 20 lbs you may hurt more than you help.
Easier ways to loose 20lbs.
But, there are a few single exit catbacks that save more than 20lbs and claim to stay under 93db.. have a look at the tanabe for example on ft86speedfactory.com..
The Following User Says Thank You to mad_sb For This Useful Post:
Turbo Den (08-27-2013)
Old 08-27-2013, 05:59 PM   #7
Frostyman
Drives: 2013 Raven FRS
Lose, not loose.
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline   Reply With Quote
The Following 2 Users Say Thank You to Frostyman For This Useful Post:
ftc~brz (08-27-2013), Tim_Asphalt_FRS (08-27-2013)
Old 08-27-2013, 06:09 PM   #8
SmsAlSuwaidi
Boosted
Originally Posted by Frostyman View Post
Lose, not loose.
Name:  Willy-Wonka-Meme-Oh-You-corrected-someones-grammar-How-productive-of-you_thumb.jpg
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
mad_sb (08-27-2013)
Old 08-27-2013, 06:34 PM   #9
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
I've heard the single exit deletes are quite modest under 4k rpm and sound great throughout. Is there something I'm missing here? Dual deletes with other exhaust mods are when it becomes unbearable right?
Old 08-27-2013, 06:47 PM   #10
mad_sb
Lose, not loose.
I used to sit next to a guy that corrected everyone's grammar and spelling at work, now he sits on the other side of the building because no one can stand to be near him... true story.
Ad8707 (12-23-2013)
silencer on muffler delete pipe Turbo Den Engine, Exhaust, Transmission 1 08-27-2013 09:57 AM
Berk track pipe with tip/muffler delete. Stealthx Engine, Exhaust, Bolt-Ons 6 07-24-2013 09:26 PM
FS (BC): BERK technology muffler delete pipe stanm Canada Classifieds 16 01-03-2013 11:32 AM
Mach V BRZ / FR-S Muffler Delete Pipe REVIEW Turn in Concepts Engine, Exhaust, Transmission 1 10-16-2012 11:15 AM
X-Pipe with Muffler delete dav0777x Engine, Exhaust, Transmission 3 06-21-2012 10:30 AM
