Old 08-25-2013, 04:08 PM   #1
mike the snake
diff bushing questions
I'm looking at the different bushings available for the BRZ/FRS.
I found these Whiteline pieces. Do I use both of these together?
http://www.frsport.com/Cradle---Supp...Z_p_65543.html
http://www.frsport.com/Differential-...Z_p_64252.html
And what about these?
http://www.frsport.com/Solid-Differe...Z_p_64218.html
Old 08-25-2013, 05:28 PM   #2
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
As far as the whiteline, they are different solutions. The first link is an insert, they work with the existing oem bushings. The second link is a complete replacement. I have the inserts, and they do their job very well.
The third link appears to be a metal version of link one for whiteline. You can expect more NVH.
Zach3794 is offline   Reply With Quote
Diff swap help wootwoot Engine, Exhaust, Transmission 30 06-10-2013 11:05 AM
Where can I buy the trans and diff washers? ngabdala Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 05-09-2013 12:35 AM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 03:11 PM
Whiteline transmission bushing and Perrin shifter bushing review. Superhatch Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-09-2012 08:40 PM
So what is the Big Diff? (pun intended sorry) Erik @ GBox Engine, Exhaust, Transmission 22 10-21-2012 09:21 AM
