Drives: Subaru BRZ Limited
Car slow to start?
I have less than 5k miles and had only had my car since June. Today when I tried to start it up the engine just stayed cranking for about 5 seconds and then it finally started. This is the first time it's happened. I've already had my first oil change at 3250 miles.
Should this be happening so soon? I'm thinking about taking it to the dealership just to be safe. Has anyone else had this happen so early on? |
#2 | |
Grip>Slip
Keep Calm And Drift On~
Drives: Scion FR-S WhiteOut 6 Speed Manual
You could bring it in and have your battery load tested. If it fails it would be replaced under warranty. Although what they dont tell you is the replacement batter is NOT under warranty and next batter change will be out of pocket but that battery WILL be covered .
LOL crazy huh... |
Drives: BRZ DGM Limited
I have had the car since Nov and it has happened to me twice but both times it was a warm re-start. (parked for 15 min)
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
This happened to me 3 times over the winter. It only seems to do it if I turn the key all the way in one motion. If I turn the ignition on, let the tac sweep then start, it's never done it. Maybe the fuel pump isn't priming the direct infection pump? No idea
Sent from my Nexus 4 using Tapatalk 4
Nolan
Drives: 2013 BRZ Ltd. MT
Port injection fuel pressure may be around 40-60 psi, while the direct injection fuel pressure may be 2000-3000 psi, quite a bit higher. The high pressure fuel pump takes a little while to build that much pressure in the system – it needs time.
When I get into my BRZ, I first turn all the electronics to ON (I press my START button twice), then adjust my seat and put on my seatbelt. By then my fuel pump has had time to build the required pressure. The engine starts immediately, now. |
#7 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
#8 | |
Drives: 2005 Toyota Camry
[ame="http://en.wikipedia.org/wiki/Common_rail"]Common rail - Wikipedia, the free encyclopedia[/ame]
Keep in mind there's two pumps on our car. -alex |
#10 | |
I am aware of that but he mentioned High pressure lines and what not
#11 | |
Drives: 2013 Subaru BRZ
If you have a long crank time, it may be related to the cam sensor signal issue, for which there is a Subaru TSB. |
| Sales start to slow down? | motofan | Scion FR-S / Toyota 86 GT86 General Forum | 37 | 04-03-2013 07:39 PM |
| Pop-Start with Push-Button Start | cmspooner | BRZ First-Gen (2012+) — General Topics | 5 | 03-22-2013 02:45 PM |
| slow start | GREATNEESSS | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 12-30-2012 08:49 PM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 03:44 AM |
| Why IS TRD so slow..... | SF-FRS | Engine, Exhaust, Transmission | 10 | 07-10-2012 03:11 PM |
