Old 08-19-2013, 12:11 AM   #1
Noob4Life
86 Noob
Drives: Firestorm FR-S
Got 99 problems and an HIDs 1
So this started happening shortly after I installed my amp/subs. Any idea what's going on?
The kit is a 50w TRS H11 kit
[ame="http://www.youtube.com/watch?v=SO_3Etm00_E"]YouTube[/ame]
Having the same problem in my retrofitted VW Jetta. Running a 50w D2S kit from TRS and the passnegers side goes out whenever it feels like it. I have to turn the lights off then back on.
Are these ballast issues?
Noob4Life is offline   Reply With Quote
Old 08-19-2013, 12:22 AM   #2
mashal
DADA
mashal's Avatar
Drives: 2013
your video is private
mashal is offline   Reply With Quote
Old 08-19-2013, 12:29 AM   #3
Noob4Life
86 Noob
Should be fixed now, thanks for the heads up
Sent from my SAMSUNG-SGH-I317 using Tapatalk 4
Old 08-19-2013, 12:30 AM   #4
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
The problem is it's not a BRZ
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 08-19-2013, 12:31 AM   #5
Noob4Life
86 Noob
Your right I shouldve paid more for the same car with less looks! Lmao jping
Old 08-19-2013, 12:32 AM   #6
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
Yeah this happened to me.. I thought it was a faulty light bulb n I threw it out n got a new one.. But then found out it was the ballast.. Sigh..
Minovsky is offline   Reply With Quote
Old 08-19-2013, 12:33 AM   #7
Noob4Life
86 Noob
Guess ill have to buy two new ballasts. What are the odds 2 TRS ballasts from 2 different kits would crap out on me -.-
Thanks!
Old 08-19-2013, 12:37 AM   #8
Sbeezy
Drives: 2001 ZX2, WRBP BRZ (soon hopefully)
did you run new harnesses for the 50w kits? if not that may be your issue most factory lighting systems are 35w systems so i would either run a 35w system or upgrade to a harness capable of supporting a 50w ballast. you wouldn't run a true 3kw amp on a 80amp fuse and 10ga wire would you?
Sbeezy is offline   Reply With Quote
Old 08-19-2013, 12:43 AM   #9
Noob4Life
86 Noob
Im running my amp on 4g wiring and a 150amp fuse. And no I relay all my hids lol I have a 50w headlight and 35w foglight hids both running off two sep relays on the jetta and the 50w is relayed on the fr-s
Old 08-19-2013, 01:15 AM   #10
Sbeezy
is there a warranty on the ballasts?
Old 08-20-2013, 01:27 AM   #11
Noob4Life
86 Noob
Looks like a 5 year warantty so hopefully I can get both ballasts replaced for free. I'm emailing TRS as we speak. Thanks for the help all
Where to look for HIDs? kALMIGHTY Cosmetic Modification (Interior/Exterior/Lighting) 18 04-23-2013 03:17 PM
HIDs 8k DAmarcus28 Cosmetic Modification (Interior/Exterior/Lighting) 37 10-31-2012 04:26 AM
Halo HIDs? ExWhyZer0 Cosmetic Modification (Interior/Exterior/Lighting) 1 10-12-2012 01:59 PM
Hids Sh4rp CANADA 3 07-30-2012 12:25 PM
HIDs plus CA intake Symbiont Engine, Exhaust, Transmission 1 06-26-2012 04:49 PM
