Old 04-19-2013, 03:28 AM   #1
kALMIGHTY
Drives: TRD Ultramarine '13
Where to look for HIDs?
Just like many of you, I hate the halogen headlights on the FR-S and would love HIDs, but at the same time, I don't want to just half-ass it and get a cheap HID kit for the halogen projectors, because then I'd have to retrofit LED's as well, and that's just a lot of work.
I was thinking of getting either GT86 headlights from Europe, or hopefully get them from Scion if they can be ordered after the Series 10's are released, or maybe from some wrecked BRZs.
Where could I get them for the cheapest? And where should I go about looking for headlights from wrecked BRZs? (I live in Canada, so something specific to Canada would be helpful).
Old 04-19-2013, 03:51 AM   #2
Tony Mac
Tony Mac's Avatar
Drives: SWP BRZ
The Retrofit Source has a retrofit kit for the FRS which gives you good HID projector lenses and good ballasts.
http://www.theretrofitsource.com/pro...roducts_id=254
Then check this thread out for a DIY:
http://www.ft86club.com/forums/showthread.php?t=10296
Tony Mac is offline   Reply With Quote
Old 04-19-2013, 05:15 AM   #3
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
What the diffrence between this and other HID kits??
Carlitoz3 is offline   Reply With Quote
Old 04-19-2013, 08:10 AM   #4
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
I believe with the retrofit, you are putting in HID projectors along with the bulbs
vs.
Sticking in HID bulbs in Halogen projectors.
The cut offs and beam pattern are different from HID/Halogen projectors.
This is the only kit I'm aware of that has the projectors included with the bulbs and ballasts for a full retrofit. Every other kit it just The bulbs and ballasts so with every other kit, you'd essentially be sticking HID bulbs in the halogen housing. Which is no bueno.
Enraged21 is offline   Reply With Quote
Old 04-19-2013, 09:20 AM   #5
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
^ which happens all the time cause most people don't care. However if you choose to go that route I still recommend the retrofit source, the morimoto plug and play hid kit is the highest quality standard hid kit I've ever seen. Assuming you don't do a proper hid projected retrofit, you will need to bend the sqirl finders down to compensate for the dif light pattern an stop as much glare as possible. The search function will take you to numerous threads talking about just that.
FRSfan111 is offline   Reply With Quote
Old 04-19-2013, 09:27 AM   #6
Enraged21
#RememberTheBuster
Enraged21's Avatar
yeah its an annoyance when people do that.
I retrofitted my girlfriends civic with the kit from TRS. They definitely have high quality products and will always buy from them whenever I need to.
Old 04-19-2013, 10:37 AM   #7
frslee
Just drive it
Drives: 13' FR-S
hid bulbs in stock projector isn't that bad.
frslee is offline   Reply With Quote
Old 04-19-2013, 12:25 PM   #8
xc0xbc
Drives: Raven Fr-s
I was considering hids for my low beams but then i stumbled across these.
http://automationled.3dcartstores.co...KIT_p_138.html
frs uses h11 bulb btw
xc0xbc is offline   Reply With Quote
Old 04-19-2013, 03:10 PM   #9
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
Diode Dynamics FTW
gatorbushmen is offline   Reply With Quote
Old 04-19-2013, 03:15 PM   #10
Dezoris
Dezoris's Avatar
PM Ken one of the best lighting vendors on here, has quality stuff and is one of the few who takes his ballasts apart to show quality difference between the generic ones.
http://www.ft86club.com/forums/showthread.php?t=8500
Did all of my lighting on my car from him.
Old 04-19-2013, 03:31 PM   #11
jstans84
Drives: Scion FR-S
http://www.theretrofitsource.com/product_info.php?products_id=254
I just got my set from these guys. They are in Atlanta so it worked out perfetly for me. I will be doing my retrofit/demon eye/housing blackout on Saturday night...so that it is ready Sunday for IA, lol.
jstans84 is offline   Reply With Quote
Old 04-19-2013, 04:52 PM   #12
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
DDM tuning.
I've bought 5 sets from them(two for my last car, 55watt was too bright, had to change to 35w, two sets for my bike, and one set for the FRS) Only had 1 set that didn't work(55watt for the last car, one bulb's output was redish).
At $30 for a set, its hard to say no, if one goes out, just buy another.
Trashed675 is offline   Reply With Quote
Old 04-19-2013, 05:00 PM   #13
kALMIGHTY
So are these just LED's instead of either halogen or HIDs? Would there be any problems with sticking LED's for low beams?
Old 04-19-2013, 05:21 PM   #14
kALMIGHTY
What's the best way to just get "white" light instead of the stock yellowish light. Honestly, that's really my end goal, but I do want to do it safely, and do want the mod to last.
Best HIDs/ LESs Vendor L3P47 Cosmetic Modification (Interior/Exterior/Lighting) 39 03-04-2013 04:19 PM
HIDs 8k DAmarcus28 Cosmetic Modification (Interior/Exterior/Lighting) 37 10-31-2012 04:26 AM
Halo HIDs? ExWhyZer0 Cosmetic Modification (Interior/Exterior/Lighting) 1 10-12-2012 01:59 PM
Hids Sh4rp CANADA 3 07-30-2012 12:25 PM
