Old 08-18-2013, 08:38 PM   #1
teamred
Drives: firestorm scion frs
rce yellow lowered...now wheels any size suggestions?
with the rce springs I am lowered about an inch and right now I am pretty much trying to decide on 17s or 18s any pics of a 1 inch drop with both? I am looking to fit 245s or 255s all around if possible, and am leaning toward rays gramlight 57dr's.i want to keep my wheel gap pretty close to how it is now depending on how it looks with the wider tires. some pictures ive found with a 1inch drop with 17s look like too much tire and some of the 18s ive found look like it raised the car too much, while some look perfect...not sure if peoples measurements are correct or what.
teamred is offline   Reply With Quote
Old 08-18-2013, 09:21 PM   #2
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
17s or 18s shouldn't effect ride height. That's all in proper tire selection. 235/40-17 is slightly smaller than stock, 245/40-17 is as close to stock as you'll get with a wider tire on 17s. On 18s, you'd want 245/35-18. Variations on those sizes are up to you. There are lots of good calculators out there.
That said, here's my car with 235/40-17s on 17x8 Wedsport TC105n wheels. I have RCE Yellows installed:
The Following 4 Users Say Thank You to Draco-REX For This Useful Post:
hmong337 (08-19-2013), normancw (08-19-2013), rcm47 (08-19-2013), suaveflooder (02-20-2014)
Old 08-18-2013, 09:26 PM   #3
teamred
looks great, I might just have to stick with 17s after all
Old 08-19-2013, 11:08 AM   #4
infinite012
Drives: 13 DGM BRZ Ltd
I have 18x8 +48 wheels with 245/35/18 tires lowered with RCE yellows. I like the look.
infinite012 is offline   Reply With Quote
Old 08-20-2013, 03:01 AM   #5
teamred
Draco-rex- ya sold me on 17s I really like that look,Just bought the gramlight 57dr 17x9+35, plus the 17's are slightly cheaper, now to see how much rubber I can fit on this thing without rubbing.
infinite012-yeah looks really good,there were definitely some mistakes with other peoples measuring skills cuz your 18s look like it kept the same height as the stock wheel setup .
Old 02-12-2018, 11:02 PM   #6
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
im lowered on rce yellows, im looking to buy new wheels and tires. Im thinking on goin with a staggered look.
front 18x8 45mm offset
rear 18x9.5 45 offset
take advantage of wider and sticker tire, only downside is that i wont b able to rotate them.
thoughts on this setup?
Jfheisenberg is offline   Reply With Quote
Old 02-14-2018, 11:05 AM   #7
tyler_win_photo
tyler_win_photo's Avatar
That's a pretty aggressive stagger for an NA car. Personally I would keep the stagger a bit closer together to retain the twin's handling characteristics. With that setup you're bound to get a lot of understeer.
tyler_win_photo is offline   Reply With Quote
The Following 4 Users Say Thank You to tyler_win_photo For This Useful Post:
Jfheisenberg (02-14-2018), Racecomp Engineering (02-14-2018), Tcoat (02-14-2018), Tristor (04-30-2018)
Old 02-14-2018, 11:26 AM   #8
Jfheisenberg
Thanks , yes im reconsidering the staggered setup. Im thinking on going with 18x8 45mm off set in all four tires.
Im trying to find the right tire size rn.
The Following User Says Thank You to Jfheisenberg For This Useful Post:
Old 02-14-2018, 11:57 AM   #9
tyler_win_photo
Depending on how much tire you want you can go from 225/40 to 245/35
Old 02-14-2018, 12:45 PM   #10
Jfheisenberg
Yes, AZP is suggesting to go with "225/40-18" tire size. Thinking on going with the pilot sports 4s.
As this set up is going to be bit more heavier due to bigger wheels and wider tire, should i be okay with my oem brake set up?
Old 02-14-2018, 01:03 PM   #11
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I went staggered. 18x8 & 18x9. Everyone talks about how its going to "ruin" the car; it does not. I had 4 different square setups before I went staggered. Anyway, if it is the look you want, it is fine for DD. I can't get my car to understeer. Oversteer is no problem. I drive my car for pleasure and to work. No track or AutoX.
+45 offset is not optimal. I added a 10mm spacer in the front on my 18x8 +45 and a 5mm spacer to my 18x9 +42. (making them +35 and +37) They are flush now.
I have 225/40 and 245/35 MPSS. And am on Eibach prokit springs.
What wheels are you considering?
I LIKE TIRES!
Old 02-14-2018, 03:11 PM   #12
gtpvette
Drives: 2015 FRS - FFR GTM
17x9's all the way around
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
The Following User Says Thank You to gtpvette For This Useful Post:
jmark (02-14-2018)
Old 02-14-2018, 07:46 PM   #13
tyler_win_photo
Yes, as long as long as you are not planning on tracking or autox. I was running 18x9.5 on stock brakes for quite a while, but have since gone with upgraded pads and fluid for track duty.
Old 02-15-2018, 09:31 AM   #14
Jfheisenberg
yea I do want to track the car at some point and also I do enjoy some mountain run sprints during the summer..
However my budget is not to expend more money buying BBKs. Maybe I can budget for some upgrade pads and mayybe rotors.
Seeking lowered 86 with stock wheels DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 10-12-2014 08:12 PM
-Sold- FS: ASSEMBLED Koni Yellow + RCE Yellow combo; lightly used! OrbitalEllipses Mid-Atlantic 21 06-14-2013 12:10 PM
need suggestions for lightweight forged 17x7 wheels hankster Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 11-15-2012 01:40 PM
Does anyone have pics of FR-s Lowered with stock wheels and and fatter tires?> Mrqb22 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 10-09-2012 11:24 AM
enkei suggestions and size help CharlieChaos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 10-03-2012 07:23 PM
