Old 08-16-2013, 11:03 AM   #1
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Time to get serious: 17x9.5 (or 10") w/ 275 (or 285)
Now that my car is officially classed as Street Mod in Solo (thanks to the new hairdryer), it's time to go really big.
Car has coilovers w/ 2.25".springs and -2.5 & -2 camber F/R, I'm running 255s on 17x9s with no issues, but wonder what I'll need to do.
I'd imagine some fender rolling @ a minimum. Ultimately, 17x10s on 285/35s is the ideal goal.
I know Phil w/ Element has gone there, but I wanted to start a thread for future searches as all of us continue to develop this car.
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 08-16-2013, 11:55 AM   #2
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I have nothing solid to contribute except to point to the Meaty Tire Thread. A lot of people are getting 265s to fit without a whole lot of issues. So that may give you a starting reference.
285s will be tough however. I think you may have to get flares and do some trimming.
Old 08-16-2013, 01:53 PM   #3
GTB/ZR-1
GTB/ZR-1's Avatar
This is from Phil @ Element he had posted in another thread--good stuff...
Originally Posted by Element Tuning View Post
The front just needs a healthy amount of negative camber and a roll..maybe a slight pull. I was getting some slight rub right at the reflector and at rear corner where the frame rail seam is. I ended up trimming the seam a little and all is good now. Don't forget I'm running "race" spec coilovers (that means very firm).
On the rear substantial roll and pull because you don't want to run too much static negative camber. I'm really not that low so I can get away with it and the flares hide the fact that I'm not low.
He's running 18s, so I'm thinking shorter 17s will help w/ some travel clearance, for softer setups.
Old 08-16-2013, 07:05 PM   #4
xwd
There is only one tire to run in SM, and that's the A6 and the only sizes I would look at running are the 275/35/17 and 285/30/18, which are about the same overall height.
I think you can get away with running the 275/35 on a 17x9.5 without any problems. Finding a non-custom 5x100 wheel in larger than 17x9.5 or 18x9.5 at the right offset is going to be difficult. Rota makes some, I think that's what Phil@Element is running. Plenty of guys are running wheels that size, but not with tires that wide, just going to take measuring and fitting them and see what needs to be pulled/hacked/etc.
Old 08-16-2013, 07:36 PM   #5
GTB/ZR-1
GTB/ZR-1's Avatar
My bad, Phil... I knew better that there's no 285/35 A6 lol
The Rota rims are too weighty. Not sure if the 17x9.5 RPF1 +38s will clear the AP Sprint brake kit I have w/o spacers--but the lbs are right. Those'll probably be the easiest off-the-shelf solution w/ the 275/35s--for now...
Old 09-03-2013, 05:10 PM   #6
FRS_FIEND
Whats next?
FRS_FIEND's Avatar
Drives: '13 Asphalt FRS MT
17x9 +38 fit the ap racing kit. Proved in this thread by ft86speedfactory http://www.ft86club.com/forums/showt...t=27300&page=2
FRS_FIEND is offline   Reply With Quote
Old 09-03-2013, 05:41 PM   #7
UncleFester
You mean +35's.
UncleFester is offline   Reply With Quote
Old 09-03-2013, 06:28 PM   #8
GTB/ZR-1
GTB/ZR-1's Avatar
I already run 17x9s in +35 (Weds) w/ 255s that clear my brakes.
Need bigger!
I think I'm going to start w/ 18x9.5s & 275/35s, since I can get good, used A6s more readily in 18s.
Either the RPF1 (+38), or NT03+ (+40) w/ small spacers for front.
Need to find some used & cheap! lol
17x9 +35 wheels, lower 1". PROBLEMS??? karma003 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 02-26-2016 01:24 PM
Will the FR-S end up on the list of the "10 slowest sports cars of all time"? Davyator Scion FR-S / Toyota 86 GT86 General Forum 30 10-10-2014 07:59 AM
* Axis OG SAN Wheel - 17x8", 17x9" - SALE * GuerillaRacing Wheels and Tires 105 07-31-2014 06:01 PM
Red "Time Attack" stripe on OEM? @Art_Mighty Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 11-18-2013 07:26 PM
Volk Racing TE37RT 17x9.5 +40 / 5x100 Groupbuy - LIMITED TIME CounterSpace Garage Groupbuys 3 07-17-2013 06:53 PM
