Old 07-21-2013, 03:52 PM   #1
karma003
auto-crosser/drifter
karma003's Avatar
Drives: 2013 scion FR-S black M/T
Exclamation 17x9 +35 wheels, lower 1". PROBLEMS???
Ok I'm looking into getting 17x9 +35 wheels & I wanna get the koni struts & tien s shocks. But I've been hearing that's on lowering shocks, at a full lock, the rims will hit the tie rod.. is this true? Plz advise
karma003 is offline   Reply With Quote
Old 07-21-2013, 04:47 PM   #2
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
No no issues. Running 17x9 +35s now. 245 section tire.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following 2 Users Say Thank You to feldy For This Useful Post:
15limited (01-20-2016), karma003 (07-21-2013)
Old 07-21-2013, 05:08 PM   #3
wgnzlz
wgnzlz's Avatar
Drives: 2013 WRB BRZ Limted
I'm also running this setup, but with RCE spring, and don't have any issues rubbing.
Moto-East Tune, Perrin drop-in, P&L Catless Header and Overpipe, Motiv HFC, Invidia Q300, 17x9+35 Enkei RPF1, 245/40 PSS, RCE & Koni Yellows
wgnzlz is offline   Reply With Quote
The Following 2 Users Say Thank You to wgnzlz For This Useful Post:
Old 07-21-2013, 06:40 PM   #4
kster1
kster1's Avatar
If I remember correctly, there are rubbing issues with the tie rod when using the 17x9 +45 rims (but the +35 offset is fine).
kster1 is offline   Reply With Quote
The Following 3 Users Say Thank You to kster1 For This Useful Post:
hmong337 (01-24-2016), karma003 (07-21-2013), wparsons (02-26-2016)
Old 07-21-2013, 06:44 PM   #5
lightdir
Drives: 2013 Raven FRS 6MT
17 X 9 +35 with 245/40/17's work fine on stock, but will poke
lightdir is offline   Reply With Quote
The Following User Says Thank You to lightdir For This Useful Post:
Old 07-21-2013, 06:51 PM   #6
karma003
karma003's Avatar
What about w 235 tires & lowered 1"
Old 07-21-2013, 07:52 PM   #7
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Rub aganst fender but that was when I was at half a finger gap
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 07-21-2013, 08:00 PM   #8
karma003
karma003's Avatar
What do u mean? How low was that
Old 07-21-2013, 08:04 PM   #9
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
I was rubbing both fender lining during full lock when I had about half a finger tip between the tire and fender. I was pretty much slammed. Riased the car to a 1.5 figer gap and no issues anymore.
All heights are much lower than just a 1 inch drop.
Out of the FRS game
The Following User Says Thank You to Mr.Jay For This Useful Post:
Old 07-21-2013, 08:37 PM   #10
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Why can't people use units of measurements? What is this the medieval ages? We gotta use the kings foot as measurements?
The Following 8 Users Say Thank You to dem00n For This Useful Post:
15limited (01-20-2016), Calum (02-27-2016), D5teph (06-09-2016), DocWalt (01-26-2016), finch1750 (02-27-2016), go_a_way1 (02-26-2016), hmong337 (01-24-2016), Keenercarguy (01-27-2016)
Old 07-21-2013, 10:26 PM   #11
xia
Drives: 1995 Supra TT & 2013 FRS
LOL.
1" wont give you issues. I have 17x8.25 +25 fronts and 17x9.75 +25 in the rear and they dont rub and I'm dropped some 2-2.5" (dont remember the drop but I'm at 1 finger gap).
xia is offline   Reply With Quote
Old 01-20-2016, 02:32 PM   #12
Tvars
Tvars's Avatar
Drives: Firestorm
Looking to do this setup as well 17x9 +35 with 245/40/17 with 1inch lowering springs. Best way to get rid of poke? Hopefully get to flush.
Tvars is offline   Reply With Quote
Old 01-20-2016, 02:43 PM   #13
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Camber bolts.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
8R6 (01-20-2016)
Old 01-20-2016, 04:49 PM   #14
15limited
15limited's Avatar
:o:o:o:o
I'm running 17/40/245 +35 with rsr super downs on stock struts and with camber bolts maxed out up front. They've rubbed fender lining on harsh bumps but no other clearance issues yet.
Maybe one larger than average male index finger clearance :o
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
* Axis OG SAN Wheel - 17x8", 17x9" - SALE * GuerillaRacing Wheels and Tires 105 07-31-2014 06:01 PM
Any aftermarket "front bumper garnish" (black that cover lower middle) jacobzking Cosmetic Modification (Interior/Exterior/Lighting) 17 12-09-2013 09:59 PM
Please Close. dizzario Wheels and Tires 15 11-14-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
