Drives: Passat
Wheel advice
Hey guys, I could use some help picking a set of wheels for my firestorm FRS. I know I want to stay with 17's and I'm leaning toward 17x8 with 225-45-17 UHP summer tires.
What I need your help with is choosing the best offset to balance handling and aesthetics. I'm not lowered and probably won't be. I don't care about being flush but would like to improve on the oem look without compromising the suspension geometry. I also need some wheel suggestions. I know black looks great on red cars but I'm really partial to hyper black, black chrome, or whatever other name they use. I like the hyper black Rota Grids but what else should I look at?TIA. |
Drives: Passat
Okay, how about opinions on Rota Grid 2 in 17x8 +38 hyper black on my firestorm FRS? Can anyone suggest other wheel manufacturers that offer this color under whatever name? TIA.
Drives: Blue
You need 9 inches on the pavement for maximum grip.
Drives: WR Blue BRZ, 240Z
For street driving, choose the offset that you think looks best. I'm running et35 on 17x8's and don't feel any difference in scrub radius. If you drive a lot on a 300 foot skid pad you will notice the wider track.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Drives: Raven Black
Imho I think 18's is the bare minimum.
#6 | |
Drives: Passat
It's all about compromise. 17x9 with 245-40-17's might look and grip great but 17x8 with 225-45-17 will be lighter, ride better and get better mpg. I also don't want to lose the fun factor with too much grip.
For me at least, it's function over form. 18's look good but make a slow car even slower. |
#7 | |
Drives: '23 BRZ
Michelin Pilot SuperSport: 225/45-17 = 22 lb., 245/40-17 = 23 lb. 1.3 lb. per corner Ever so *slightly* better gearing and lower ride height with 24.7" 245/40s vs. the possibly/theoretically better mpg and ride with the 25" 225/45s! |
Drives: Blue
You don't always have to compromise...at least not where you weren't going to already. In your OP you stated that you probably won't be lowering it. So what a great opportunity to go wider without worrying! Besides, 9's aren't really that wide anyway. As far as weight, do as ZDan said and get some Enkei's. They are the best bang for your buck on a purpose build.
#9 | |
17x8 RPF1 (15.6 lbs) with 225/45 is roughly 2 lbs heavier than the 17x7 combo above. Is the marginal increase in contact patch worth it? 17x8 or 9 with a 245 tire isn't an option for me: +45 disallows the use of camber bolts (rubs the spring perch), +35 pokes. Am I missing another option? |
#10 |
Drives: '23 BRZ
Tire size is fine, but I wouldn't go with the DZ101. Much worse wet grip vs. other UHP or Max perf tires.
I would investigate alternatives: http://www.tirerack.com/tires/TireSe...45&diameter=17 |
#11 |
Good to know, thanks.
#12 |
Drives: Scion FR-S Argento
Can I have some thoughts on these rims? I like the way they look, but I imagine there are folks here that know way more about choosing good rims for you vehicle than I do...
http://www.tirerack.com/wheels/Wheel...nt&showRear=no
#13 |
At 20.6 lbs, slightly heavier than stock. Then again, most wheels in that price range are about 19 lbs.
Looks are... subjective. Personally, I believe god kills a kitten every time these are purchased. I can't help but think the lighter ones look better, the same way I prefer the look of a $100 bill over a 1$ bill. It's about the capability. |
#14 | |||
Drives: Passat
| Tags |
| attention whore, what an ass |
| Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel | Infamous Performance | Wheels and Tires | 122 | 02-13-2014 11:34 AM |
| Thoughts/advice on on wheel setup | jflogerzi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 06-23-2013 01:26 AM |
| Wheel/Tire Advice | mrjester | Tracking / Autocross / HPDE / Drifting | 1 | 05-18-2013 11:48 PM |
| Starting out wheel/tire advice? | rainmonkey | Tracking / Autocross / HPDE / Drifting | 19 | 05-02-2013 01:44 PM |
| Wheel Guys Chime In! Need advice on tire sizing | Pure Automotive | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 01-17-2013 01:21 AM |
