Transmission oil change
Anyone change their auto tranny oil yet? Was it hard? Or does it have that "lifetime oil" crap?
#2 | |
But to answer your questions: 1) Yes many people have for lower trans temps, and smoother shifts when the tranny is cold. 2) Not hard if you have some mechanical expertise and have all the proper tools and parts (extremely suggested to have some sort of fluid evacuation tool) 3) As for life no its not that never replace for the lifetime of the tranny crap you see on other more widely sold cars. But this is from toyota on that last part: Automatic Transmission: TX6A This transmission is a 6-speed super ECT multi-mode automatic transmission equipped with paddle shifters, other features include: -Pattern select switch (SPORT/SNOW mode) -Flex lock-up control -Blipping downshift Control -ATF warmer Fluid level will not be able to be service without toyota special service tools and toyota specific operating conditions <-ignore this bullcrap they don't want you doing it yourself for free. Fluid will be inspected every 30,000 miles or 30 months and will be replaced every 60,000 miles or 60 months and uses Toyota Specific World Standard fluid with capacaties of 7.9 quarts Manual Transmission: TL70 This transmission is a 6-speed manual transmission with clutch start switch and pull collar to access reverse, also features MT shift indicator and shift-up indicator on the combo meter fluid will be API-GL-3 75w90 and should be inspected every 22.5 months or 22,500 miles, replaced as needed by inspection. Limited Slip Torsen Differential (if you ever want to replace the gear oil too): Fluid type: API GL-5 Toyota Genuine Differential Gear oil LX, will hold 1.22 quarts and should be inspected every 7.5 months or 7,500 miles. So in the end the manual and auto fluid is replaced on an inspection based deal, and doesn't last the lifetime
Drives: FR-S Firestorm 2013
Rear diff only has 1.22 qts? Doesn't seem like a lot... how many for the manual tranny? Is it the same as the auto?
"features MT shift indicator and shift-up indicator on the combo meter"
is this one feature? Or 2 separate ones? I've only seen the red light that flashes... |
#5 | |
I do believe it is only one single feature.
#6 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
#7 | |
otherwise there is no guarantee all of the fluid can be removed.
#8 | |
Your way would work with the pump, just can be done cheaper if your up to using a little more fluid to make sure its all out. Not trying to argue just trying to give OP his options. |
Drives: 2013 Whiteout FR-S
You can turn on the gear indicator too so you know what gear your in
#10 | |
#11 | |
LOL PWR
Drives: Whiteout FR-S; Scion tC
![]() Learn something new everyday
It's not a midlife crisis if you never grow up. |
#12 | |
No Martians here?
Drives: FR-S Asphalt MT
Supposedly tells you when to shift for max fuel efficiency. |
#13 |
Drives: 2013 scion firestorm frs
#14 |
Drives: JRSC'd Asphalt FR-S
It's actually very simple, I should be tackling this pretty soon
[ame="http://www.youtube.com/watch?v=a98b0X0ahIY&feature=c4-overview-vl&list=PLDBDDF23430AFC913"]Differential and Transmission Fluid Swap with Red Line Oil - 2013 Subaru BRZ and Scion FR-S - YouTube[/ame] Last edited by Wes; 08-26-2013 at 12:26 AM. |
| DIY - Transmission / Diff Fluid Change Reference Guide | F1point4 | DIY (Do-It-Yourself) Guides | 295 | 05-13-2023 02:34 AM |
| Automatic Transmission Fluid Change | jmaryt | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 169 | 08-26-2018 07:55 PM |
| Transmission and Differential Fluid Change LINK | Amadeus | DIY (Do-It-Yourself) Guides | 1 | 12-23-2012 06:01 PM |
| Anyone change transmission lube yet? | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 08-21-2012 05:47 AM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 07:54 PM |
