Old 08-15-2013, 03:50 PM   #1
fitcious
Transmission oil change
Anyone change their auto tranny oil yet? Was it hard? Or does it have that "lifetime oil" crap?
fitcious is offline   Reply With Quote
Old 08-15-2013, 04:09 PM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Smile
There was a very good DIY of this made:http://www.ft86club.com/forums/showthread.php?t=19218
But to answer your questions:
1) Yes many people have for lower trans temps, and smoother shifts when the tranny is cold.
2) Not hard if you have some mechanical expertise and have all the proper tools and parts (extremely suggested to have some sort of fluid evacuation tool)
3) As for life no its not that never replace for the lifetime of the tranny crap you see on other more widely sold cars.
But this is from toyota on that last part:
Automatic Transmission: TX6A
This transmission is a 6-speed super ECT multi-mode automatic transmission equipped with paddle shifters, other features include:
-Pattern select switch (SPORT/SNOW mode)
-Flex lock-up control
-Blipping downshift Control
-ATF warmer
Fluid level will not be able to be service without toyota special service tools and toyota specific operating conditions <-ignore this bullcrap they don't want you doing it yourself for free.
Fluid will be inspected every 30,000 miles or 30 months and will be replaced every 60,000 miles or 60 months and uses Toyota Specific World Standard fluid with capacaties of 7.9 quarts
Manual Transmission: TL70
This transmission is a 6-speed manual transmission with clutch start switch and pull collar to access reverse, also features MT shift indicator and shift-up indicator on the combo meter
fluid will be API-GL-3 75w90 and should be inspected every 22.5 months or 22,500 miles, replaced as needed by inspection.
Limited Slip Torsen Differential (if you ever want to replace the gear oil too):
Fluid type: API GL-5 Toyota Genuine Differential Gear oil LX, will hold 1.22 quarts and should be inspected every 7.5 months or 7,500 miles.
So in the end the manual and auto fluid is replaced on an inspection based deal, and doesn't last the lifetime
Old 08-15-2013, 05:14 PM   #3
Jond63
Jond63's Avatar
Drives: FR-S Firestorm 2013
Rear diff only has 1.22 qts? Doesn't seem like a lot... how many for the manual tranny? Is it the same as the auto?
Jond63 is offline   Reply With Quote
Old 08-15-2013, 05:15 PM   #4
Jond63
Jond63's Avatar
"features MT shift indicator and shift-up indicator on the combo meter"
is this one feature? Or 2 separate ones? I've only seen the red light that flashes...
Old 08-15-2013, 06:56 PM   #5
FRSBRZGT86FAN
Smile
No there is quite a difference Auto tranny has 7.5 quarts of atf fluid and the manual takes about 2.2-2.4 you should just fill it till it spills out a bit to be safe.
I do believe it is only one single feature.
Old 08-15-2013, 07:21 PM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
-ATF warmer
Good info, but the day is not helpful for an auto. If you just pop the drain plug maybe 2 qts will come out. I have not done it myself yet, but try YouTube for the various ways to do an AT fluid swap. An extra person seems very helpful.
Old 08-15-2013, 07:29 PM   #7
FRSBRZGT86FAN
Smile
That's why in the diy and in my recommendation I would say its necessary to use one of these:https://www.google.com/search?q=flui...ed=0CAsQ_AUoAw
otherwise there is no guarantee all of the fluid can be removed.
Old 08-15-2013, 08:25 PM   #8
finch1750
finch1750's Avatar
Or you can use the engine as the pump when it comes to the AT and save the money as those pumps are notcheap. If you disconnect the cooling line from the rad you can get the fluid out that way. There are plenty of YouTube DIYs showing how as its an empty pour repeat process as you can't just let it run dry.
Your way would work with the pump, just can be done cheaper if your up to using a little more fluid to make sure its all out. Not trying to argue just trying to give OP his options.
Old 08-15-2013, 09:26 PM   #9
Ghost 86
Drives: 2013 Whiteout FR-S
You can turn on the gear indicator too so you know what gear your in
Ghost 86 is offline   Reply With Quote
Old 08-15-2013, 11:13 PM   #10
FRSBRZGT86FAN
Smile
True that is another method that works well.
Old 08-16-2013, 10:06 AM   #11
buzznasa
LOL PWR
buzznasa's Avatar
Drives: Whiteout FR-S; Scion tC
huh..... I didn't realize trannies had oil in them...
Learn something new everyday
It's not a midlife crisis if you never grow up.
buzznasa is offline   Reply With Quote
Old 08-16-2013, 12:17 PM   #12
pcporo
No Martians here?
pcporo's Avatar
Drives: FR-S Asphalt MT
I assume they are talking about the flashing red light and the little flashing up arrow on the combo meter that shows the mpg, odometer, temp, etc...
Supposedly tells you when to shift for max fuel efficiency.
pcporo is offline   Reply With Quote
Old 08-25-2013, 08:37 PM   #13
alex_86
alex_86's Avatar
Drives: 2013 scion firestorm frs
1.22qts is actually a pretty generous amount. any more and that would be alot.
alex_86 is offline   Reply With Quote
Old 08-25-2013, 10:29 PM   #14
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
It's actually very simple, I should be tackling this pretty soon
[ame="http://www.youtube.com/watch?v=a98b0X0ahIY&feature=c4-overview-vl&list=PLDBDDF23430AFC913"]Differential and Transmission Fluid Swap with Red Line Oil - 2013 Subaru BRZ and Scion FR-S - YouTube[/ame]
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
Anyone change transmission lube yet? BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-21-2012 05:47 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
