Old 08-12-2013, 10:16 PM   #1
Kai Uhl
Kai Uhl's Avatar
5x100 to 5x114.3 hub conversion
Has anyone done a 5x100 to 5x114 hub conversion? What would be required in this conversion and what parts as well?
-Thanks
Kai Uhl is offline   Reply With Quote
Old 08-12-2013, 10:23 PM   #2
Knshro13
Drives: 10 series FRS
Megan Racing makes conversion hubs. Front and rear.
Knshro13 is offline   Reply With Quote
Old 08-12-2013, 10:37 PM   #3
Ms. FR-S
Drives: 2013 Scion FR-S, 1993 Mazda RX-7
Ditto. I was told Sunday it would run about $750 for a set of four.
Ms. FR-S is offline   Reply With Quote
Old 08-13-2013, 01:43 AM   #4
86Toyobaru
Drives: 86 & GRB
-Thanks
There are two ways to do it
A: Buy 114.3 HUB
Front hub: aftermarket kit- hardrace , megan
Rear hub: 08+ STi part #: 28473FG010
B: Just get a adapter (spacer). This is cheaper and easier way to covert to 114.3 from 100. But you have to make sure that your new wheel has hole on its back to let stock stud to pass through. (stock stud is 24MM long). Or you can get a 25mm spacer/adapter. Also, you need to pay attention to new wheel offset since you add extra 15mm/25mm to it. (18X9J +50 should be the best fitment for 15mm adapter)
exp: SARD PCD changer 5H100-5H114.3 15mm for BRZ/86
86Toyobaru is offline   Reply With Quote
Old 08-13-2013, 02:02 AM   #5
brz_star21
Drives: DGM BRZ
A: Buy 114.3 HUB
Option B is really only if you'd like to stick with mid-to-high offset wheels. I understand not everyone is looking for low offsets but I'm just pointing that out.
For those looking to run lower offsets, a hub conversion is an aggressive option for most but will allow a wider range of wheel options. Keep in mind it won't be as easy to change back to stock configuration versus using just the spacer route.
brz_star21 is offline   Reply With Quote
Old 08-13-2013, 04:34 PM   #6
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
I wonder if the 114.3 hub will push the wheels outside or not ?
adprokid is offline   Reply With Quote
Old 08-13-2013, 05:12 PM   #7
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
If you do a real hub conversion, no. If you use bolt on adapters, yes.
Sent from my Nexus 4 using Tapatalk 2
Nolan
pheoxs is offline   Reply With Quote
Old 06-03-2019, 05:44 PM   #8
gt7877
Drives: turbo frs
What do you mean??
gt7877 is offline   Reply With Quote
Old 06-03-2019, 06:08 PM   #9
Impureclient
Drives: 2015 FR-S
Originally Posted by gt7877 View Post
What do you mean??
First off....08-13-2013. That comment is almost 6 years ago that you are asking that guy a reply for.
By replacing the the whole 5x100 hub assembly for the 5x114, it will have the same track width as it did before so it will not "push the wheels outside".
By adding the spacer/adapter to the wheel though, it will be pushed out, in this case 25mm more than stock width.
The 25mm spacer option will allow you to use the stock studs and not have to worry about the studs passing through the spacer/adapter and touching the wheel and not allow it to seat properly.
Impureclient is offline   Reply With Quote
Old 06-04-2019, 03:32 AM   #10
gt7877
Drives: turbo frs
Thnx
What about 15mm spacer??
Old 06-04-2019, 08:57 AM   #11
wparsons
wparsons's Avatar
Thnx
That was already covered earlier in the thread...
flickr
Megan Racing's 5x100 Hub Conversion to 5x114.3 R2RO Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 59 09-26-2018 11:46 AM
Project Kics 11mm or 15mm P.C.D. Conversion Spacer - 5x100 to 5x114.3 (12x1.25mm) Evasive Motorsports Wheels and Tires 31 06-13-2015 08:09 PM
CUSTOM Wheel spacers/adapters 5x100 & 5x114 conversion (15mm / 20mm / 25mm) JonMotoring Wheels and Tires 102 04-30-2015 08:22 PM
Project Kics 10mm 5x100 to 5x114.3 Conversion Spacer Hubcentric deedz Wheels and Tires 12 05-22-2013 04:18 AM
5x114.3 hub conversion mclevin Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-03-2012 09:53 AM
