Old 06-28-2012, 01:57 AM   #1
mclevin
Drives: Ae86, gts86 (coming)
5x114.3 hub conversion
Hi all
Sorry disappoint, this is a technical question not a how to.
After any info on how to do this conversion on a fr-s/86. I understand that there are more wheels out there and custom pcds are avail on order. I just want to know if its a viable option.
I have had a brief search but this is limited on my phone so if there is already a tech article please link me, if not I guess this can be it.
Thanks in advance
Chris
mclevin is offline   Reply With Quote
Old 06-28-2012, 02:00 AM   #2
jdmboss86
Drives: scion frs auto paddle shifters whit
greddy is already working on one but we definitely need it
jdmboss86 is offline   Reply With Quote
Old 06-28-2012, 03:42 AM   #3
jamal
jamal's Avatar
Drives: Legacy GT
We recently had a thread about it:
http://www.ft86club.com/forums/showthread.php?t=8296
It's not going to be an easy or inexpensive process.
jamal is offline   Reply With Quote
Old 06-28-2012, 05:32 AM   #4
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
anyone taken the stock discs off and checked to see how much meat is on the stock hubs, to see if it's possible to just redrill them to 5x114.3 and do the same to the discs...
Otherwise I'm sure there will be kits available using stuff from the subaru/toyota parts bin or stuff like this: http://www.licmotorsports.com/produc...i_lic-03079012
JP is offline   Reply With Quote
Old 07-03-2012, 12:04 AM   #5
Skywgn1
Skywgn1's Avatar
Drives: 2013 Scion FR-S (manual)
Greddy did do this but has not put it into production due to the lack of requests. I just sent an email to their product request team. If enough people send an email we may have a solution.
greddyusa@greddy.com
Skywgn1 is offline   Reply With Quote
Old 07-03-2012, 12:19 AM   #6
ebphoto
Drives: FR-S, NA8, S13
could always grind down stock studs and use project kics conversion spacers with studs on them.
bulletproof has the 10mm conversion spacers.
i already ordered 5x100 wheels so im just going to stick with them until i get bored and hope there is a full 5x114 conversion setup down the road.
ebphoto is offline   Reply With Quote
Old 07-03-2012, 12:19 AM   #7
vividracing
vividracing's Avatar
The problem used to be the front hubs did not fit the 5x114.3 coil overs. So it would mean you needed to find a set or redrilled STi hubs.
You would need:
5x114.3 Hubs (new seals and bearings if used)
5x114.3 Brakes (brake lines, Calipers, Brackets, Rotors)
5x114.3 Axles (ends would be different but not sure on the r200)
5x114.3 Wheels
5x114.3 Coil overs (mount point to hub)
What I recommend is for everyone to hang tight. The wheel companies are playing catch up. Once they do the same wheels in 5x114.3 will be here for the 5x100. The nice part of 5x114.3 is the easier bear change, longer service life and wide wheels. Wide wheels are not going to matter much as there is only so much room for them. And your not making enough power to spin them. Remember light wheels for light power.
vividracing is offline   Reply With Quote
Old 07-03-2012, 12:21 AM   #8
vividracing
Exclamation
You do not need to grind anything. They make a 5x100 to 5x114.3 spacer already. But the problem is getting a wheel in the large offset to make up for the spacer.
There really is no need for 5x114.3 on these cars.
Old 07-03-2012, 12:30 AM   #9
jamal
jamal's Avatar
Drives: Legacy GT
Bolt in bearings all around. All Subarus have had bolt in bearings all around since 08/09.
The rear conversion is probably pretty straightforward. Would just need to re-drill the rotors.
The front, not so much. You can't just take an sti upright/bearing and put it on these cars. Ball joint and abs tone ring are completely different plus an sti hub will get pulled right out of the bearing without an axle bolted through it.
There's not. It uses front wrx brakes, and wrx rotors won't fit over an sti hub, and a wrx hub doesn't have the room for 5x114.
Old 07-03-2012, 12:37 AM   #10
Proud of BOXER
Drives: 74 Toyota Celica ST
wrx brakes will fit sti hubs.
Proud of BOXER is offline   Reply With Quote
Old 07-03-2012, 12:46 AM   #11
vividracing
Ha my personal car I did the swap. But it is pre 07.
The hubs are the same on the FRS, I looked on our shop car and you can slid a axle right in there. So your not going to loose a hub without a axle. They made them just like GMC does on the trucks. 2wd and 4wd use same hubs.
Old 07-03-2012, 12:47 AM   #12
jamal
jamal's Avatar
Drives: Legacy GT
hmmm. Pretty sure the wrx hat is smaller than the sti hub but I could be mistaken. Well, still doubt there's room to re-drill the hub and the front sti hub/bearing won't fit in the brz upright.
Old 07-03-2012, 01:55 AM   #13
vividracing
.05 STi 5x100 Front Hub Conversion Kit with Custom Knuckles for WRXs and STis
This upgrade includes 05+ STi hubs that have been machined with a 5x100 bolt pattern as well as knuckles machined to fit WRX and prior year STi struts. This kit will fit STis WRXs (Legacy, RS, and Forester fitment pending). While this kit does not allow users to utilize wide 5x114.3 wheels, it does provide the stronger, bolt on hubs. The kit can also be machined with an offset upright bolt hole to provide additional camber, negating the need for camber plates. We are offering this upgrade as a full kit which includes:
• (2) New 05 STi front knuckles machined to fit WRX and prior STi struts (custom camber settings optional)
• (2) New 05 5x100 STi front hubs/bearings
• (8) New bolts to attach hubs/bearings to knuckle
• (2) New 6 Gun Racing Speedo Gear Adapter Collars
• (10) New OEM lug studs installed in hubs
This is old info and its for subaru wrx to STi swap. I just checked the 6gun kit I have on my own Subaru looks to be rare now days. Didn't know they went under.
Old 07-03-2012, 02:13 AM   #14
jamal
jamal's Avatar
Drives: Legacy GT
Javid's still around, and might still make the parts if you ask. I got a set of tone ring adapters from him not too long ago. Just don't expect a quick turnaround.
LIC does their own conversion uprights now and they are awesome guys so that is the place to get stuff.
But absolutely none of that applies to the FRS.
HID Conversion DIY loong DIY (Do-It-Yourself) Guides 55 06-27-2014 06:27 PM
leather seat conversion stalon320 Interior Parts (Incl. Lighting) 6 07-20-2012 04:36 PM
BRZ HIDs vs FR-S HID Conversion DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 37 06-28-2012 05:20 PM
LED Conversion [M] Cosmetic Modification (Interior/Exterior/Lighting) 38 06-18-2012 08:44 PM
