Old 08-09-2013, 08:01 PM   #1
barabia
barabia's Avatar
Will I need an Alignment? Eibach Sportlines
I recently purchased Eibach Sportline springs and Tanabe front and rear sway bars. I've seen some comments here and there about needing camber bolts and an alignment after installing the springs and I just want to clarify if it necessary after installing either of these parts?
barabia is offline   Reply With Quote
Old 08-09-2013, 08:14 PM   #2
whataboutbob
AutoX-10/10ths every run
I'd be very surprised if your alignment is still right after the springs. If you want your tires to last I'd get it checked.
Build thread:Here
Old 08-09-2013, 08:15 PM   #3
barabia
barabia's Avatar
Also should mention Im on stock rims and Michelin pilot super sport tires. I use my car for daily driving and HPDE, so whats the best way to go?
Old 08-09-2013, 08:21 PM   #4
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
springs yes (for the alignment), swaybars no. after dropping the car, it's going to affect your alignment. if you want to adjust the camber, you'll need to add some parts.
shiumai is offline   Reply With Quote
Old 08-09-2013, 08:35 PM   #5
barabia
barabia's Avatar
Alright, so do I just go to the dealer and tell them I need camber bolts front and rear?
Old 08-09-2013, 09:48 PM   #6
whataboutbob
I'd suggest you look into the OEM crash bolts or some aftermarket camber bolts such as the Whiteline units.
Build thread:Here
Old 08-09-2013, 09:51 PM   #7
shiumai
shiumai's Avatar
are you getting someone to install the springs for you? if so, talk to them first about your different options for your particular needs and associated costs.
Old 08-09-2013, 11:24 PM   #8
barabia
barabia's Avatar
A friend of mine is installing them on the side for me. I have to supply everything. My only real need is to re-establish the factory alignment as this is primarily a daily driver and I will only be doing some HPDE stuff with it a few times a year.
Old 08-10-2013, 12:12 AM   #9
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
When you drop this car even an inch which sport lines go bit lower actually yes you will need an alignment and of course should do one. The rears there is the option of whiteline adjust able "top" camber adjustment bushings but be warmed they're a pain in ass to install to say the least. Fronts everyone else has answered on that, ie: crash bolts or WL ones ....
Old 08-10-2013, 01:15 AM   #10
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
wait until the springs break in than do the alignment.
bkblitzed is offline   Reply With Quote
Old 08-12-2013, 08:51 PM   #11
barabia
barabia's Avatar
Are you talking about these:
http://ft86speedfactory.com/whitelin...r-kit-215.html
So far this is the only thing Ive heard anyone sugguest. Do you have any information on how to install them or any tips on how to make it easier? Are there other options?
Old 08-12-2013, 08:52 PM   #12
barabia
barabia's Avatar
How long would you suggest that I let the springs settle?
And do you have any suggestions for camber and toe settings? (daily driver/ HPDE use only)
Old 08-12-2013, 08:56 PM   #13
mswhong
I usually go for a a day or two of mild/passive driving to seat my springs in place! After that it's all yours
mswhong is offline   Reply With Quote
Old 08-12-2013, 09:00 PM   #14
ayau
Drives: Some rust bucket
I think the Sportlines drop the car about 1.5''. You're going to get some massive rear negative camber for a daily driver. Probably somewhere around -2.6.
That's the correct Whiteline kit. Most people say that it's a pain in the ass to install, which means $$$ for labor cost. I don't have any experience myself. The alternative would to get adjustable lower control arms.
Anyone with Eibach Sportlines gatorbushmen Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 12-12-2013 01:55 AM
RCE Yellows or Eibach Sportlines? ChandlerSwyng Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 07-21-2013 04:09 PM
NY: F/S Eibach Sportlines delusional Brakes, Suspension, Chassis 7 04-26-2013 12:35 PM
eibach sportlines clunking.. frsguy707 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 10-24-2012 11:42 AM
Eibach Sportlines Finally Available! PRO Import Tuners Brakes, Suspension, Chassis 1 08-22-2012 07:42 PM
