Old 08-06-2013, 01:26 AM   #1
Avo1789
Avo1789's Avatar
Drives: Ultramarine FR-S
How to gut the interior?
I want to start my sound deadening project for the entire floor,side panels, and doors of the FRS. I searched but had no luck finding a tutorial on how to disassemble the whole interior. I'm sure quite a few modders have done this. Are there any guides out there?
Avo1789 is offline   Reply With Quote
Old 08-06-2013, 02:10 AM   #2
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
This might better be aimed at the DIY request section.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 08-06-2013, 02:42 AM   #3
Avo1789
Avo1789's Avatar
Tried a month back but no luck
I figured a thread here might catch some attention?
Old 08-06-2013, 12:24 PM   #4
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Ah yeah, I think the information you are looking for is out there but it is not in one place. For example, one user might have removed the back paneling by the rear seats in order to get to a ground wire while another user might have removed the door cards to install courtesy lights. You can try downloading the service manuals (not the user manual that comes with the car) to see if there are any tips in there. Otherwise, you're gonna have to write up a DIY for everyone since it seems you're the first!
φφκα
Old 08-06-2013, 12:46 PM   #5
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
To take out panels:
1) Literally look/feel for fasteners.
2) Remove fasteners
3) Remove component
To install panels:
1) Replace component
2) Replace fastener
It's literally self explanatory. They're either bolted/screwed into place, or snapped in. Generally the bolts/fasteners are visible or accessible with your tools, but this isn't rocket science.
slicktop is offline   Reply With Quote
Old 08-06-2013, 01:03 PM   #6
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
I just finished my sound deadening. This was helpful.
http://www.ft86club.com/forums/showthread.php?t=35604
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 08-06-2013, 07:24 PM   #7
Avo1789
Avo1789's Avatar
Thanks for the input guys! Il probably start with the doors and trunk/wheel well next week. As for the rest of the cabin, Il dedicate one weekend to get it all done.
Old 08-06-2013, 11:14 PM   #8
Tim_Asphalt_FRS
Is it fast? No.
From my experience. The doors, inside the rear quarter panel and then the floor was the most beneficial.
I took some pillows and stuffed them in the opening behind the rear speakers after I put dynamat all over the metal.
DCW Carbon Fiber interior items! Center console Plaques / Interior panels doggy Interior Parts (Incl. Lighting) 143 10-11-2013 11:17 AM
LED interior conversion kits (interior), USA stock & warranty WTF Interior Parts (Incl. Lighting) 0 05-22-2013 10:17 PM
interior fog? munjah Issues | Warranty | Recalls / TSB 7 12-03-2012 05:36 PM
FR-S Interior ph0en1xtk Scion FR-S / Toyota 86 GT86 General Forum 37 07-19-2012 05:03 PM
BRZ vs 86 interior beirouty Scion FR-S / Toyota 86 GT86 General Forum 4 11-30-2011 09:48 AM
