Old 08-04-2013, 06:00 PM   #1
diss7
Drives: AE86, 2x GT86, TE27
Gutting out the stock cats
Has anyone gutted out the stock cats?
We used to do this back in the day, and it was always a cheap gain. Admitidly on 10 year old cars with clogged cats.
But, would be interested if someone has tried this. Might get 50% of the gains of a $2000 exhaust system for 1 hours work on a hoist.
I like the idea of it, from a stealth/sleeper point of view.
diss7 is offline   Reply With Quote
Old 08-04-2013, 06:19 PM   #2
wparsons
wparsons's Avatar
You'll get better gains from larger diameter piping than from just gutting the cats in the stock header/front pipe. I would bet you get less than 1-2hp from gutting the stock cats but without replacing anything else.
flickr
Old 08-04-2013, 06:24 PM   #3
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Great idea. You should do it and tell us how that works out.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following 3 Users Say Thank You to Apoc For This Useful Post:
2014scionfrs (01-12-2014), gutbuster (04-02-2018), SloS14 (08-04-2013)
Old 08-04-2013, 06:45 PM   #4
Opposed
You will most likely lose or not gain any power. Your better off with a straight through same diameter pipe. The hollow cat will disrupt the exhaust flow and scavaging effect.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 08-04-2013, 07:25 PM   #5
ML
ML's Avatar
Drives: 13 White MT FR-S
I did this to my front pipe. Louder, and engine seems smoother. Especially at higher rpms
The Following User Says Thank You to ML For This Useful Post:
diss7 (08-04-2013)
Old 08-04-2013, 07:58 PM   #6
mrk1
Drives: Sterling BRZ Ltd
Punching out the cat and inserting a pipe the same diameter of the main pipe could probably show a small gain.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 08-04-2013, 09:21 PM   #7
wparsons
wparsons's Avatar
Good luck getting a pipe through the cat on either the header or the front pipe, too many bends in there.
flickr
Old 08-04-2013, 09:29 PM   #8
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
you wont see any gains gains going any bigger then 2.5 if you stay NA.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 08-04-2013, 09:39 PM   #9
Turbowned
Turbowned's Avatar
Waste of time and ozone, get high flow cat and larger diameter piping.
The Following User Says Thank You to Turbowned For This Useful Post:
SirBrass (12-16-2013)
Old 08-04-2013, 09:58 PM   #10
diss7
Seeing as this will cost nothing, I hardly see how it is a waste of time.
Old 08-04-2013, 10:02 PM   #11
diss7
Understand. But, going for sleeper install. Replacing cat with shiny new decat pipe, is a give away. Gutted out stock cat will still look stock.
Old 08-04-2013, 10:42 PM   #12
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
how many cats do our cars have? 1 header, 1 over pipe, and is there one in the downpipe as well? Ugh i miss only having 1-2 cats being only in the downpipe..
bkblitzed is offline   Reply With Quote
Old 08-04-2013, 11:00 PM   #13
diss7
There is one in the header, one in the front pipe. Removing the one in the header causes issues, as there are sensors before and after the cat, that will then think there is an issue and throw a CEL.
There are ways & means around this CEL, but there is mixed reviews on the success of these methods. Of cuorse you could get a flash/tune to solve this.
The one in the front pipe is not measured in this way, and can be removed without issue.
I'm all about keeping my 5 year warranty. Also, we have to get our cars inspected yearly, and they love failing modified cars.
The Following 2 Users Say Thank You to diss7 For This Useful Post:
lazyluka (12-08-2013), rennlistuser3 (02-24-2018)
Old 08-04-2013, 11:14 PM   #14
bkblitzed
is better than you
bkblitzed's Avatar
ah okay thanks. I might just gut the overpipe cat then.
Gutting primary cat? jordanrw260 Engine, Exhaust, Transmission 6 07-30-2018 10:24 PM
Just replacing the stock cats? brillo Engine, Exhaust, Transmission 4 07-08-2015 11:12 AM
Gutting the BRZ and putting in a Electric Engine? mechaghost BRZ First-Gen (2012+) — General Topics 22 07-31-2014 07:12 PM
I giggled... Cats have it made seven Off-Topic Lounge [WARNING: NO POLITICS] 51 12-21-2012 03:46 PM
Speed cats (or other driving shoes) Symbiont Off-Topic Lounge [WARNING: NO POLITICS] 25 06-14-2012 11:10 PM
