Old 07-31-2013, 08:29 PM   #1
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
Changing camber. Effects on toe?
TL/DR see bold question below
I did a bit of searching and couldn't find the answer to my question. Perhaps someone that is familiar with this cars suspension can answer.
I recently put Eibach Pro-kit springs and OEM camber bolts in my car. I drove it for a bit afterwards. Then I had to go to the dealer to get hail damage repaired, so I told them to do an alignment while they were at it. I specifically told the guy "It probably has around -1 degree of camber in the front, and I'd like to keep it that way. Just adjust the toe." To which he replied "ok."
The next day when I pick up the car, I ask to see the alignment specs. Turns out they adjusted the camber back to damn near 0. I was a bit pissed, but didn't want to make a big deal out of it, so I figured it would be fine.
Well, after driving it in a more spirited fashion recently, I can see that it really wants that camber back. It developed a slight push as compared to driving the car before the alignment, which bothers me.
My question is: If I just loosen the strut bolts and push the hub in before tightening to get the camber back, will it throw the toe off at all? I like the toe where it is at for tire longevity reasons, and would really like that camber back.
FReSh is offline   Reply With Quote
Old 07-31-2013, 08:59 PM   #2
OrbitalEllipses
Drives: Attitude
Problem was you went to the dealer. Go to a speed shop. I have no idea how front camber works on front toe, but in the rear if you adjust from the RLCA then it fucks with the toe. Adjusting from the RUCA does not affect toe.
JordanWho (08-01-2013)
Old 07-31-2013, 09:02 PM   #3
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Your front toe will be changed when you adjust camber at the hub. Not so much from the top of the strut.
Sent from my SCH-I535 using Tapatalk 4 Beta
JDKane527 is offline   Reply With Quote
Old 07-31-2013, 09:13 PM   #4
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
I've asked this many times. So far the best info has been on this thread.
http://www.ft86club.com/forums/showt...t=42160&page=3
garfull is offline   Reply With Quote
The Following User Says Thank You to garfull For This Useful Post:
FReSh (08-01-2013)
Old 08-01-2013, 01:11 AM   #5
FReSh
Dirt Trackin'
FReSh's Avatar
Yeah. I only used the dealer due to convenience. Honestly, until this, the dealer hasn't been to bad and has honored all of my requests. Next time I need an alignment, I'll head to the shop my friend works at and do it with him.
Old 08-01-2013, 01:56 AM   #6
Xauterus
Drives: GTS 86 Galaxy Blue
As soon as you increase the camber the tyres will toe in. Can be quite a lot too.
Xauterus is offline   Reply With Quote
Old 08-01-2013, 01:26 PM   #7
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
I'd take it back to the dealer and ask them to redo it the way you asked in the first place.
Edit: Are you sure you had the camber bolts adjusted right when you installed them? tabs facing in? Normally they have no camber adjustment so the dealer really shouldn't have messed with the camber
FastLane1000 is offline   Reply With Quote
Old 08-01-2013, 01:36 PM   #8
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
To clarify, for the front:
negative camber = toe in because our steering rack is behind the knuckle.
On our cars, 1 degree negative camber = 1/32 toe in
supramkivtt2jz is offline   Reply With Quote
The Following 4 Users Say Thank You to supramkivtt2jz For This Useful Post:
CSG Mike (08-01-2013), garfull (08-01-2013), PikachuBRZ (02-22-2023), troek (08-01-2013)
Old 08-25-2013, 02:20 PM   #9
FReSh
Dirt Trackin'
FReSh's Avatar
I used the OEM crash bolts. They are just a smaller diameter bolt, allowing you to lean the wheels in a bit. From what I've heard, leaning the wheels in ~ 1.0 degree will give between 1/32" and 1/16" toe in per wheel. Anyone know how many turns on the tie rod this equates to?
Old 09-26-2014, 10:01 AM   #10
forwallblakmail
Troll Level: Expert
forwallblakmail's Avatar
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
This. Bump.
Nick K.
NASA ST5/TT5 #130
Southeast Region
forwallblakmail is offline   Reply With Quote
Old 09-26-2014, 12:01 PM   #11
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by forwallblakmail View Post
This. Bump.
I don't remember exactly, but not a lot. I'd start by doing 1/6 of a turn on each side at a time to try to get 1/16" of toe adjusted.
The Following User Says Thank You to solidONE For This Useful Post:
forwallblakmail (09-26-2014)
Old 09-28-2014, 12:51 AM   #12
PPX
How are you people currntly measuring camber and toe?
PPX is offline   Reply With Quote
The Following User Says Thank You to PPX For This Useful Post:
emutcfut (09-08-2017)
Dilemma: Lowering Springs 1" and Ground effects kit for my FR-S OICU812 Scion FR-S / Toyota 86 GT86 General Forum 10 04-08-2013 12:16 AM
250 ~ 300 hp - Cost, Requirements, Effects Froylavin Engine, Exhaust, Transmission 14 07-19-2012 12:55 AM
effects of bigger wheels-video 315FR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 07-01-2012 09:50 AM
