Old 07-30-2013, 06:55 PM   #1
swift996
swift996's Avatar
Cleaning Race Pads off wheels?
I spent an hour with a brillo pad and half a bottle of wheel cleaner. Any super formula that brakes up this crud? Mine is caked on like paint.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-30-2013, 07:13 PM   #2
ModBargains.com
ModBargains.com's Avatar
Don't use wheel cleaners!! Wheel cleaners sure make it easier to take off brake dust, but ultimately they're acidic chemicals, which if used too much, or too often, will over time peel away at the clear coat of wheels. I'd suggest just soap and water, and if that doesn't work out, then get a pressure washer and blast them off. If it's caked on like paint as you say, well then I'd suggest to do your best to get it off, then put a fresh coat of wheel wax over them so that you don't have to do it all over again the next track day.
Or just buy track wheels that you don't care about and leave it dirty as hell... That's what I do.
ModBargains.com is offline   Reply With Quote
Old 07-30-2013, 07:29 PM   #3
What pads were you using? Some pads are wheel friendly, while others are not.
@ModBargains.com: not all wheels utilize a clearcoat...
Old 07-30-2013, 07:32 PM   #4
swift996
swift996's Avatar
I'm running racing pads on the street.
The fronts which cake on the matter are Wilwood BP-30s.
The rears are carbotech xp-10s but those just take a little TLC, the fronts are a mission.
Old 07-30-2013, 07:34 PM   #5
Carbotech dust is super easy to take off, as long as you don't bake it on at a wet track day.
The BP30... good luck
After you're done, I suggest you put sealant on your wheels. It may make the next cleaning easier.
Old 07-30-2013, 07:39 PM   #6
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I used Acetone to clean my wheels. Maybe that's not the right direction for you but it worked really well for me. Acetone or Brakleen work wonders. Heck, if your woman uses Acetone to take off her nail polish you have to believe it's not going to rot away your wheels otherwise... WTF are her nails made of?
PS: My wheels are $130/per and I commonly break 1-2 of them a year.
PRO86 | WTCC | STL
Old 07-30-2013, 08:14 PM   #7
mrk1
Drives: Sterling BRZ Ltd
run dark colored wheels, been doing it for years. If it gets bad I have a young guy who helps out at the shop, he will scrub them if he gets to take the car for a spin.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 07-30-2013, 08:35 PM   #8
donutfilling
donutfilling's Avatar
Drives: frs
My opticoated my wheels when I got them. Waiting for a track day or two and time before I post how effective it is.
donutfilling is offline   Reply With Quote
Old 07-30-2013, 08:46 PM   #9
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Rain?
Oh you mean actually clean them?
Dunno, buy black wheels and roll with it.
<< doesn't clean his track wheels.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 07-30-2013, 08:48 PM   #10
CSG David
CSG David's Avatar
We have a secret video on washing a car with opti-coated wheels. Mind is
Old 07-30-2013, 09:02 PM   #11
donutfilling
Drives: frs
Good to know guess ill offer this service to people more. I did it for my stock wheels and I hated them so I didn't bother to try to clean them too much x_x
Old 07-30-2013, 09:09 PM   #12
mla163
Overthinking it
Drives: BRZ in CS
Try wheel wax to lay down a base coat. Brakleen is not good for paint or finishes. That will take off anything.
mla163 is offline   Reply With Quote
Old 07-30-2013, 10:01 PM   #13
Disclaimer: It was race pad dust under light use conditions.
Old 07-31-2013, 07:57 AM   #14
swift996
swift996's Avatar
FYI - I think I'll pull the wheels off one weekend clean them and apply PoorBoys:
http://www.poorboysworld.com/wheel-sealant.htm
Hopefully that will help out or I need to get some gunmetal wheels.
DIY - Changing Your Brake Pads (Race Pads upgrade) PMok DIY (Do-It-Yourself) Guides 53 09-03-2021 05:17 PM
TF Brake Cooling Kit // Race Pads // Rotors // BBK // Lines // Hardware Touge Factory Brakes, Suspension, Chassis 15 02-17-2015 06:57 PM
Team Dynamics Pro Race 1.3 Wheels (Track wheels) CHEAP!!!! Evasive Motorsports Wheels and Tires 4 07-29-2013 08:46 PM
Is there anything better than a rag for cleaning wheels? qoncept Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 05-21-2013 10:00 PM
Hawk Blue 9012 Race Pads sw20kosh Tracking / Autocross / HPDE / Drifting 15 02-14-2013 10:57 PM
