Old 07-26-2013, 08:31 PM   #1
SeanRTR
C-Street AutoX
SeanRTR's Avatar
high ride height after shock install?
I've got only a few miles on the car after installing koni yellow dampers, the car clearly looks higher....mostly the rear. Is this normal?
SeanRTR is offline   Reply With Quote
Old 07-27-2013, 12:04 AM   #2
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Anyone? Is the rear perch adjustable on these? The perch sits about 2 inches higher from the bottom of the shock in the rear compared to the stock shock.
Old 07-27-2013, 02:48 AM   #3
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I have the Koni Yellow shocks and RCE Yellow springs. I see the same issue. Looks like my ass is sticking up a little. The only thing I can think of is the spot the rear has for the springs to sit must be a little higher. I noticed the springs were pretty tough to get on like they may have sat higher.
If someone knows more I would also like some answers.
Regardless I'm more of a function > form guy so it doesn't bug me. Sort of looks like a drag racer this way.
stockysnail is offline   Reply With Quote
Old 07-27-2013, 03:04 AM   #4
simpleisbest
Senior Citizen
Drives: Scion FR-S
Are you sure you don't have the perch upside down? I have the Koni yellows and am about the same height as stock. Relatively no change in ride height.
simpleisbest is offline   Reply With Quote
Old 07-27-2013, 03:21 AM   #5
stockysnail
Just the tip
They are supposed to point up not down as that was where the lip was to catch the spring, same as OEM perch did. If I flip them down then I don't think the spring would catch that lip. Anyone have pics on what it should look like? Until then I'll see if I can find some. I will also look at my fronts as they were installed by a shop since they were inserts and I did the rear myself.
Old 07-27-2013, 12:49 PM   #6
SeanRTR
C-Street AutoX
SeanRTR's Avatar
bingo! You sir, are correct. My spring seat was upside down.
Old 07-27-2013, 02:18 PM   #7
stockysnail
Just the tip
Looks like that's my issue as well as I just looked at it. Damn it. It is a lot of work just to flip a spring seat and I don't have spring compressors. Guess I'll have a shop do it next time I take my car in.
Old 07-27-2013, 04:07 PM   #8
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
I just did rear springs on my BRZ, no compressors needed. With the spring seat upside down you will have a minimal amount of pressure when you unbolt the top nut (not a dangerous amount). Flip the spring seat over and it will all go together with no compressor. BRZ springs need about 1/4" compression to get the top nut started, FRS springs need nothing.
celica73 is offline   Reply With Quote
Old 07-27-2013, 09:32 PM   #9
OrbitalEllipses
Drives: Attitude
The picture in the little guide provided with the dampers has the spring seat upside down; that has been noted on other forums before.
Stock ride height numbers? xwd Tracking / Autocross / HPDE / Drifting 16 07-11-2018 12:42 PM
Coilover to Raise Ride Height Furtive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 07-28-2014 12:57 PM
Coilover self install, what's the best way to ensure proper ride height? Sensisnow Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 06-05-2013 11:00 AM
coilover shock body height adj garfull Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-19-2013 03:32 AM
Lower ride height in NYC? blur NY / NJ / CT / PA 9 01-19-2012 06:31 PM
