Old 05-18-2013, 06:52 PM   #1
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
coilover shock body height adj
How do you adjust the height on those coilovers with threaded shock bodies. Does the shock tube spin freely or do you have to unbolt the shock to spin the lower shock body?
garfull is offline   Reply With Quote
Old 05-18-2013, 07:21 PM   #2
mrk1
Drives: Sterling BRZ Ltd
Most coilovers have two rings that the springs sit on. Spin them up to raise it, spin them down to lower. When your done tighten them together to lock in place.
Other companies like BC have rings that the springs sit on but that's for spring preload. They also feature threads where the coil over mounts to the knuckle so that you can raise or lower the car by moving the coilovers body up and down relative to the mounting point at the knuckle.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 05-18-2013, 08:03 PM   #3
infinite012
Drives: 13 DGM BRZ Ltd
OP is asking about coilovers where the shock adjusts height at the hub, not the spring adjusting height of the shock.
infinite012 is offline   Reply With Quote
Old 05-19-2013, 03:32 AM   #4
garfull
garfull's Avatar
I found the answer on grimspeeds coilover diy. The height adjustment is done with the car raised, wheel off, loosen lower jam nut and spin the main shock/coil assembly to thread in or out of lower shock body.
Coilover Review: FEAL SUSPENSION 441 coilover kit mr. slim Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-28-2019 06:30 AM
Coilover to Raise Ride Height Furtive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 07-28-2014 12:57 PM
shock/strut replacement sinigang_guy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-19-2013 09:15 PM
Does your FR-S shock the hell out of you when you get out? ortizwyld Scion FR-S / Toyota 86 GT86 General Forum 58 03-10-2013 11:00 AM
